Question about Cannon Office Equipment & Supplies
How to install precision roller on the cannon image runner 3025n
Screwed on the nut
  • 3,866 Answers
You need a service manual for this to basically guide you on how to remove the old roller.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Nov 26, 2014
  • 11 Answers
SOURCE: Cannon Copier image Runner 400/330 series error 051
E 051 problem is registration horizontal position gear is broken. this gear seem to paper pick up deck back side. remove paper pick up deck and see one small moter and see small gear is there u change it u r problem is solved
Posted on Oct 01, 2008
  • 153 Answers
SOURCE: Scan documents on a network folder
yes it is providing it has a send kit installed on the machine, its called windows SMB scanning, and fairly easy to set up should be in your user manual on how to do it.
Canon Tech
Posted on May 20, 2009
techbuster
  • 5081 Answers
SOURCE: E000
A E000 code means the error history has detected any one of the following error codes 4 times :E001;E002;E003. Here's the definitive reset procedure Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
please rate my answer after trying if satisfied
Posted on Jul 06, 2009
SOURCE: Cannon image runner 2200 error code E000002-0000,
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom E002/E000/E003/E261/E733: due to AC line noise. Description E002/E000/E003/E261/E733 occur due to AC line noise.
If the above error codes are frequently recorded in the error log, they might concern AC line noise. Cause When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times. Field Remedy Replace the Switching Regulator PCB ***'y with a new one.
120V: FH3-2613
220V/240V: FH3-2614
The circuit has been modified to resist a noise. REMEDY Caution
 Press (* then 2 and 8 together then *)you are in service mode monitor:
To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
GOOD LUCK MATE ......KINDLY RATE ME !!!! THANKS.
Posted on Sep 26, 2009
spinal
  • 287 Answers
SOURCE: I have an error code
Hi Scott,
It means that the "reader" cannot communicate with the "printer". That is to say, your device theoretically could be purely a printer as a stand alone device. But, it knows it has a scanner and document feeder attached and therefore expects to easily communicate with these external devices. Please check the communication cables between the 'reader" and the the "print engine". If your copier has been moved or shoved recently, the communication cables may have been disconnected or slightly disengeaged.Power off the device using the "REAL" power switch. If You are in doubt on where the true power switch is, pull the plug. Locate the cable that the doument feeder uses to connect to the main copier. Remove and re seat this plug. This "should" fix the problem unless you have deeper, uglier, expensive problems.I truly wish you well, and can assure you that the communication problem is an accurate description of the code. But you of course understand that WE are hoping for the most simple problem as opposed to the distinct possibility that you have circuit boards that that don't want to talk to each other anymore or a wiring harness issue. I'll say a digital prayer for you. :-) SPINAL
Posted on Mar 02, 2011
Cannon ir 3025n some part not printed when printing or photocopying
Dear
pl. check the drum unit life, clean the drum and its cleaning blade.
Also check the developer roller for uniform toner flowing.
Thanks
Feb 14, 2015 | Cannon Office Equipment & Supplies
How to install cannon imase runner 3025N
Mirriam, what part of the install has you stumped? Print drivers? Scanning? Hardware assembly? I need more information so I can try to help.
Thank you,
Andy
Nov 25, 2014 | Canon ImageRunner 3025 Black and White...
How to i solve problem on E000007-0000 on cannon IR 3025N
The fuser assembly upper roller is actually a thin film. The fixing film is probably torn and needs to be replaced. Very common problem on that model.
Nov 11, 2014 | Office Equipment & Supplies
WHAT Cannon image runner 2525 ERROR CODE 000002
The main thermistor (TH1) has poor contact or open circuit. The thermal switch (TP1) has open circuit. The SSR is faulty. the DC controller is faulty.
The temperature of the fixing roller does not reach 100C with 2 min after it has exceeded 70C.
Apr 28, 2014 | Canon imageRUNNER C6800 Copier
Scanning using canon image runner 3025N
Hi Swandi,
Have you installed the scanner utility software before?. If yes, you can use the software or uses other application such as photoshop :)
Have a nice day!
Printer Clinic
Jan 13, 2014 | Canon ImageRunner 3025 Black and White...
I have cannon image runner 4570 that I cleaned
The transfer roller is cleaning use to a vacuum cleaner.The black lines is caused to dirty charge corona or charge roller.Clean the charge unit.
Aug 19, 2009 | Canon Office Equipment & Supplies
Canon Tech
May 18, 2009 | Canon ImageRunner 3025 Black and White...
Top Cannon Office Equipment & Supplies Experts
Iqbal Husain
Iqbal Husain
Victorman
Victorman
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
