I have a big problem with my SAGA tv. When i put it on after some minutes it will turn off. Then this happens all the time I try watching tv. What to I do? Is there a setting or something I need to ch
I have a big problem with my SAGA tv. When i put it on after some minutes it will turn off. Then this happens all the time I try watching tv. What to I do? Is there a setting or something I need to change? Ive tried nearly everything Im capable of.
  • 61 Answers
It really feels like bad power supply issue. I don't believe a reset would help.
good luck!
Posted on Nov 26, 2014
    Genius:
  • 1,342 Answers
Never heard of that brand. How old is it? Getting it fixed might cost more than a new model.
  • 8 Answers
SOURCE: Channels change by themselves after 20-30 minutes of tv being on
Have you tried covering the IR eye on the front of the TV when this starts occuring? Sometimes other devices in your home can emit infrared light that in rare cases can be picked up by your TV as a command from the remote. If covering the eye seems to stop the problem, I would say my guess is correct. If the problem continues even with the IR eye blocked I would say that the internal tuner of the TV might be defective. good luck!
Posted on Jun 17, 2008
  • 4234 Answers
SOURCE: green interference on Panasonic TH-PX75U
Since the set is only 8 months old, it should still be under warranty. This may only be an internal connection problem, but opening up the unit will void the warranty. I would suggest that you call for warranty service. This is a problem with the set and has nothing to do with external devices or interference.
Keep us posted.
Dan
Posted on Jul 10, 2008
  • 304 Answers
SOURCE: Hi.. ive got a samsung le40r7 and whenever i try to turn tv on by
Since your tv is a new model it will be IN Warranty. Call 1-800-Samsung and they will set up a service call and send your ticket to a Qualified ASC in your area. Ask if they can send a Samsung Field Engineer to repair your tv. They are nmch more highly trained and you will have a better repair experience.
Posted on Jul 17, 2009
  • 4090 Answers
SOURCE: picture is too big for the screen
go to page 37 of the manual and read through to RESET TO FACTORY SETTINGS
Thanks for using FIXYA
Posted on Sep 28, 2009
SOURCE: Insignia NS-LCD32 - 32" 720p Flat-Panel LCD Turns itself off, resets, then turns back on
It's haunted. You must appease the spirits with a virgin sacrifice.
Posted on Jan 15, 2010
Why does my reciever keep turning off by itself?
try looking into the Timer section on the TV. also on Dish if it is left unattended (like stay on same channel etc) it will go in to sleep mode, U then just hit the Select button.. U can go in the Dish menu and set the Sleep mode (inactivate mode ) to a longer time, I usually set my for 8 hours.
Jul 09, 2014 | DISH Network DVR-625 DTV Receiver /...
When watching TV the video will go black for 3 to 4 seconds then come back on. When this happens the audio continues. Some times this happens every 5 to 10 minutes then other times it happens every 2 to...
Try a new HDMI cable. Digital signals don't tolerate static in the line & would result in no video (as opposed to static in the output allowed by analog signals).
Jan 27, 2014 | Marantz SR7002 6.1 Channels Receiver
TV Takes Forever to Turn on
There is a fault with the power supply inside your tv, It could be a simple solder joint problem or could be a more serious issue.
Mar 06, 2012 | Televison & Video
Not working
Did you try to physically unplug the TV? Leave it unplugged for a few minutes then plug it back in.
Apr 03, 2010 | Hitachi 51S500 51" Rear Projection...
TV will turn on, but not respond
Good Day, mistymiles;
Try this before calling a factory authorized service center:
Press " menu 2 > 4 > 7 > 0 > enter", on remote. After settings have been initialized > press the system reset button on the front, once the LED stops blinking > reprogram settings and tuner channels (if not using box). IF NOT fixed call for service (get estimate before repair) and suspect repair of DM PCB (printed circuit board).
Good Luck, big IRISH.
Jul 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Incorrect power management
Dear u have a problem with VGA or Monitor...U should try to put new vga in you'r mother board and try.If still wont work then you have a problem with monitor
Oct 11, 2007 | ASUS P5LD2-VM Motherboard
Power on problem, very strange.
I want to know if I can fix this myself or if I have to pay big bucks to get it fixed and rather just toss this one) as you are not tech person so you can not do it. it is not a big problem there might be problem in power supply. you need not have to big bucks.
Sep 21, 2007 | Sanyo DS20930 20" TV
Power light does not turn off
This happened to me once and it was still under warranty. The warranty people came in and replaced a relay which seemed to fix the problem. Like yours mine seemed to work just fine when watching TV but I was worried that the power on all the time was putting undue wear on the components so that made me uneasy. Sorry I can't give you any more specifics.
Oct 23, 2006 | Hitachi 53UDX10B 53" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
