Question about Kenmore Vacuums
HOW TO REPAIR THE RECOIL POWER CORD ON A KENMORE MOD 116.23613300 VACUUM
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 61 Answers
Generally you need to replace the spring mechanism. contact the manufacture for parts/cost. Most local shops don't carry parts to repair vacuums, unless it's a new model, most vacuums are designed to work until they don't then you replace. unless you spend more than 400-500 bucks on it that is.
Posted on Nov 26, 2014
5 Suggested Answers
SOURCE: power cord recoil
Well, there were two problems, the first being that the cord got jammed and I did not know how to get inside to clear it up. Finally we got under a dark gray cover which exposed screws which I was able to open everything up and fix it.
Then the motor for the brush stopped working. We kept playing with it and it intermitantly operated. Obviously a connection that opened up from time to time. I may need to get another vacuum. I cleaned all the obvious connections.
Posted on Jul 22, 2008
  • 744 Answers
SOURCE: power cord reel problem with a kenmore canister vacuum whisperti
Pull the cord all the way out and see if it's contaminated with anything sticky. Also check the guide rollers that the cord rides in and see if they are rolling smoothly and without resistance - they may also need cleaning. If so, clean it off and try again.
If not, it may be the spring reel itself in which case you may need to replace it.
Posted on Apr 30, 2009
  • 10 Answers
SOURCE: cord rewind nonoperational
sounds like the spring is either over stretched or broken. you may have to have the spring replaced
Posted on May 11, 2009
SOURCE: Dead Miracle Mate Vacuum cleaner
remove the screws at the bottom and take a flat screw driver and trace around the rubber bumper to break the seal. You then have full access to the recoil.
Posted on Jan 18, 2011
How do you repair the cord recoil when it won't retract the cord on a vintage Electrolux?
It's very difficult to repair a cord wheel that's not working properly. There is a tightly wound spring that can cause harm if it comes uncoiled. It's best to try to find a replacement cord reel.
Jan 14, 2017 | Vacuums
Kenmore vacuum repair
You have to check the AC cord for any break circuit.if you wish to get more derails then check the below added link.
http://electro-medical.blogspot.com/
Jul 04, 2016 | Kenmore Vacuums
My cord wont rewind
The rewind tension spring may be broken or fully extended. Try to yank hard on the cord and pull toward you with some force. Pull until the line will no longer come out and if it won\'t recoil then it needs to be repaired.
Apr 01, 2014 | Electrolux Vacuums
The power cord does not retract or rewind when the button is pushed. How can I repair this?
Sometimes you can help get the springs working again, by gently pulling the cord out a little further and then let it slowly in while pushing the cord retract button.
Nov 08, 2012 | Kenmore 25512/ 25513 Progressive Canister...
I have a kenmore vaccum i changed the power cord for the powermate and still not working the model # 11652512202 it work for a second then stop working
1) test the for loose connection in the power cord terminal tight or resolder
2) test the thermical fuse, for loose or defective
3) test for motor brush, repair, clean, and lubricate.
4) test for bel, loose, worn, or breake and replace.
God bless you
Sep 07, 2012 | Kenmore 28614 Canister Vacuum
Have just purchased vax c90 vacuum cleaner,have a problem re-coiling the power lead.have followed instructions to press down on designated button,but power lead does not recoil.
On pressing the cord has to coil into the holder and if this wont happen there is some mechanical fault in the recoiler or spring.
You can pull the power cord once again outside and let it slide inside, repeat this sequence to allow the winder to respond and then it might pick up.
Apr 06, 2011 | Vacuums
Power cord recoil
Jul 20, 2008 | Kenmore 22812 Bagged Canister Vacuum
Kenmore vacum wand power cord
http://www.vacsew.com/vacuum-cleaners/kenmore-vacuum-parts.html/
Try here
Jul 16, 2008 | Vacuums
Power cord retrieval
Depending on which model you have, take the bag door or lid off by pushing it back and it will unhook and come off, there are 4 screws that hold the cover on over the where the cord rewind button is, take that cover off and you can get to the cord reel.
Feb 12, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Vacuums Logo
98 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
