Question about Reddy Heating & Cooling
R150B kerosene reddy heater, every 2 to 3 seconds It has spurts of flame, why?
    Problem Solver:
  • 7 Answers
Try what thy call a dry burn ,burn heater till almost all fuel is gone then take outside remove catalytic converter and raise wick ,lite and let burn till no more fuel is in wick it will smoke but that common then start the heater like you usually would .good luck
Posted on Nov 26, 2014
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 61 Answers
Generally water or air in the line will interrupt the flame momentarily.
SOURCE: kerosene reddy heater flame is intermitent
Heater had a cracked fuel line that was not visiable on original inspection.
Posted on Jan 26, 2009
tbugger
  • 232 Answers
SOURCE: R150B Kerosene Reddy Heater-
Neither of you state the model of heater that is giving you starting problems. many of the motors have an external starting capacitor (relay). If so, you may just need that part, if your heater is equipped with one. On the other hand, many have an internal capacitor , which is not servicable.
Posted on Feb 16, 2009
tbugger
  • 232 Answers
SOURCE: kersone reddy heater won't start, just buzzes
The R150B uses motor #097308-06, has a split phase motor. The secondary windings, which give the armature a jump-start, have gone bad. The motor is not serviceable. Try reddyparts.com - they seem to have the most parts.
Posted on Feb 25, 2009
koolbreezes
  • 540 Answers
SOURCE: Reddy Heater Kerosene 50,000 BTU produces TOO
There are2- adjustment screws on the back 1--air---#2-fuel. adjust it while running for the perfect combination for the fuel/ air ratio.!
Posted on Dec 22, 2009
  • 58 Answers
SOURCE: i have a reddy heater ,60,000btu kerosene heater
check the thermo coupler, it is the cooper tube looking thing you see when you look down the inside of the tube, it must be in contact with the flame, what is happing is this sensor is not detecting flame and shutting the system down, may need replaced, easy to do and cost about $10.00
Posted on Jan 13, 2010
It is kerosene, it ignites, runs from 1 - 5 minutes and loses flame
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Dec 14, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
My kerosene 50,000 btu reddy heater fires up for about five seconds and then shuts off. I put no. 1 kerosene in so it burns cleaner. It's 2/3s full. the drywallers used it last so it's a little dusty. ...
There is a sensor inside that tells the heater that the flame is lit...if it doesn't "see" the flame it will shut down...this may be caused by the filter in the rear being clogged and it is not allowing the pump to produce enough pressure to ensure a good flame or the pump inside may have sucked up some debris and is now not producing the proper pressure required. Another possibility is that there may be enough dust on the sensor itself to cause it to not "see" the flame...if you take the cover off you can find this sensor...it will have 2 wires coming off of it and it looks like a photocell...it should be located just in front of the jet where the fuel comes out...a word of caution...the ignitor(and the spark plug looking thing) have very high voltage on them(around 5000Volts) so I would avoid touching these parts while in operation.
Dec 08, 2010 | Reddy Heater 60,000 BTU Kerosene...
55000 reddy heater unsteady flame
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 03, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
I just put a new fan on a R150B reddy heater and the flame increases thas goes out and on again Is position of fan wrong? It worked fine before the fan broke
The position of the fan is very critical to proper operation. The pressure is also very critical and if you replaced the fan you will also now have to check and adjust the pressure.
This shows how to replace the rotor.
http://www.reddyparts.com/rotor%20replacement.htm
This shows how to check and set your pressure.
http://www.reddyparts.com/pressure.htm
I also have wrote a tip that kind of summarizes everything.
http://www.fixya.com/support/r3818299-reddy_heater_troubleshooting_torpedo
Take your time and go through every step and you will get your heater back up and running again.
Heatman101
Jan 11, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Feb 15, 2009 | Desa International ReddyHeater® R115DT...
Kerosene reddy heater flame is intermitent
Jan 25, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Igniter lites up fan kicks on and within 5 sec shuts off
Dustin, The ignitor only glows for 5 seconds, just long enough to ignite the fuel. The heater is shutting down because the photocell does not see the correct flame color.
Since you say "comes on for 5 seconds", I can only assume that there is a flame. You do not specify a lack of flame. I am also assuming that you have had the heater running this heater season and the problem just started.
YOU must find out if the problem is fuel delivery related or electronics related. Start by checking the pump pressure.
Follow these troubleshooting tips
Dec 21, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Heating & Cooling Logo
82 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
