Question about Microwave Ovens
I have the combination micro/oven..C-970-419532, s/n NF34332819
Mircowave turntable rotates on start up and the complete system shuts down after approx 4 seconds....I'm getting hungry
    Sergeant:
  • 216 Answers
When a microwave oven shuts down prematurely it is often due to a defective high voltage component such as the diode string, a high voltage capacitor or, more likely, a defective magnatron (microwave power generator). If your microwave oven is more than four years old, consider it a sign from God that recalcitrant electronic pariah has yet to burn your house down!
If you are a cheap weasle and willing to possibly die for hot food, you can buy a replacement magnatron and spring new life into that old, slime-filled microwave oven! It's ture! (I've done it.)
There are just four manufacturers in the world for such things and all of them do what they do far from American soil. For about $60 you can beget a repalcement magnatron then wade into the exciting world of microwave energy production, waveguide and antenna theory, and the wonders of high voltage power electronics. (I'd mention embedded microcontroller theory but everyone knows that today.)
On the other hand, a busy executive person or similar form of incurious being would have just gotten off the phone to Best Buy, having been imbued with the many exciting and wife-pleasing possibilites that are innately manifest in a microwave oven you have yet to own.
In short, all your hot food wants is money. Give it money and hot food will be yours again!
Posted on Nov 26, 2014
2 Suggested Answers
rickbrashear
  • 176 Answers
SOURCE: igniter goes on blower runs
there should be a flame detector sensor. it is in the flame. this will need to be cleaned with a wire brush or scrapped with something to get the carbon build up off of it.
you will see something that in in the flame area that is kind of charred and black with a wire coming out of it.
this is designed to tell the unit that there is a flame present and if that flame is not there after serveral attempts it will shut it down. because it there was no flame there you would get gas fumes pumped into you house.
you could change it out or usually you can just clean it and it will work fine.
hope this helps
rick
Posted on Jul 15, 2011
How can I keep the turntable from revolving when using a dish that is too large to turn?
Try removing the M/W turntable and placing a shallow bowl upside down centered over the rotating device. Then place your plate on top of the bottom of the bowl. The device will still rotate but will not be in contact with anything.
Nov 21, 2015 | Kenmore Elite Black 1.5 Cu. Ft. Convection...
Why would the turntable stop turning and the unit stop heating?
hi,
there is a micro switch that signals when the door is closed. this tells the machine that it's okay to start the turntable and heating process.. if the micro switch breaks or shorts out then the switch does not send the signal so the machine does not work.
hank
Sep 06, 2014 | Sharp R-1505 Microwave Oven
Replace mircowave turntable motor
The replacement of the turntable motor is a tricky repair, and there are lethal voltages present. I highly recommend a professional because of the degree of difficulty and the present dangers inside the item.
Mar 09, 2012 | Panasonic NN-SN657S Microwave Oven
Frigidaire FMT 148GP Microwave oven. Turntable
1. the motor to rotate the glass table in the micro wave may have stop working or the switch to the motor is defective.
Mar 13, 2010 | Frigidaire FMT148GP Microwave Oven
Turntabable in mircowave is not going round only used couple of time had it for 2years
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can find helpful exploded view diagrams and order parts by entering your full model number here, but if your brand is not listed, try Encompass or call them toll-free at 866-779-5835.
Oct 05, 2009 | Microwave Ovens
Turntable stopped rotating.
this microwave has a turntable motor that can be accessed from under the micro.. usually a $15-30part.. put your modle number on partsdirect.com and you can see how it comes apart
Feb 28, 2009 | GE JVM1651 Microwave Oven
Sharp 1505 over counter microwave
It's almost certainly not a switch issue. If the primary interlock (lower door switch) were bad, the turntable and cooling fan would not come on and it would not heat.
If it heats, but the turntable won't work, the motor is likely bad.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
We have the complete service manual for this model and have uploaded it to our site here to help you.
You will need the free Acrobat Reader to view or print it in case you don't have it already.
Nov 07, 2008 | Sharp R-1505 Microwave Oven
Goldstar MV-1501 1000 Watts... Problem:
if micro. new then its defective
if micro. old then you need replacement or service the heating element and turn table motor
Jun 02, 2008 | Goldstar MV-1501 Microwave Oven
Dacor PMOR 30SS 1100
jamison665 was you using the microwave when this happened? Reason I ask is that all microwaves over the range have a temp sensor so if you are using the cooktop and don't have the vent fan on the OTR running, it will turn on the fan if it gets to hot. Once this cools off, the fan will quit running. When this happens, it is only the fan that is running. I think this may be it since the turntable will rotate when the mircowave cooking section is in use.
Feb 04, 2008 | Dacor PMOR30SS Microwave Oven
Microwave Ovens Logo
73 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
