Question about Peavey Music
Circuit diagram for peavey ul15 pa bins
Rxe040 has blown
4 Suggested Answers
  • 15 Answers
SOURCE: Peavey 400SC
You can find Peavey's manuals in their archives at
http://www.peavey.com/support/searchmanuals/archived.cfm
They are grouped alphabeticaly across the top.
Go Fer' It,
FixThemAll.........
Posted on Dec 15, 2008
  • 1137 Answers
SOURCE: circuit diagram for a Peavey 130 special
Try http://www.peavey.com/support/contactinfo/ You may be able to get one from them. When I was doing repairs they would only release schematics to Peavey dealers but you can always ask.
Posted on Jun 25, 2009
  • 88 Answers
SOURCE: how do i connect the cables between peavey vocal
if you mean effects loop try graphic out to ultraverb input and output to power amp in. this will effect all channels of the xr500c
Posted on Feb 04, 2010
What is the value of rex040 on a peavey ul15 protection board
Is this discussion any use to you Cliff ? it mentions contacting Peavey, which you might try...
http://peavey.com/forum/viewtopic.php?f=26&t=2260&p=19183
25.November.2014
Nov 25, 2014 | Peavey Music
Peavey problems
I assume you mean the Pr-12RX passive? That seems wrong to me, too. Put an ohm meter across the terminals of the horn driver and the woofer seperatly to see which, if either, is blown. If they're OK, look for a bad solder joint on the crossover.
Jul 28, 2014 | Peavey PR 12 Speaker PA Passive
Sp4 blown fuse
It's not a fuse, it is a lamp and I suggest ordering replacements directly from Peavey.
Dec 10, 2013 | Peavey SP4 2-Way PA Cabinet (2000 Watts,...
Wiring diagram for peavey sp4g
Contact Peavey toll free at 877-732-8391 or by email at customerservice@peavey.com,
Feb 07, 2013 | Peavey SP4 2-Way PA Cabinet (2000 Watts,...
Peavey SP3 (older model) Can not get any sound thru horn.
They have a "soundgard" protection network that uses a polyfuse and an automotive lamp. Open the unit and check the circuitry. Both the polyfuse and he lamp may be blown. Do ohmmeter check of these, otherwise the horn is blown.
Aug 08, 2011 | Peavey New Peavey Sp3 15" 3 Way PA Speaker
No sound thru horn.
Either components in the SoundGard circuit are blown or the horn driver... VERY SLIGHT chance wires have become disconnected. Open unit an inspect. Use ohmmeter to check the polyfuse and the lamp for open circuit indicating they are blown. Your amplifier should be rated at NO MORE than 150 Watts RMS continuous for safety of the horn. Speaker ratings are based on advertising... so don't believe the specs on power handling... If you dig into the specs you will find for the horn a max of 150 Watts continuous.
What was the glowing inside my peavy pr 15 pa cabinet when I turned up my treble on my pa amp by accident? There was no damage I was just curieous as to what that glowing was
There is a speaker protection circuit that uses a lamp that will light IF you are driving the spoeakler TOO HARD !!! You can search for "Peavey speaker protection" circuiot online.
Jun 13, 2011 | Peavey XR 8600 / PR 15 PA Package
The power of the Peavey Escort 3000 Portable PA Sound System went off while in use, and since then power is not showing any more
A failure probably occured in one of the power amps and has blown the fuse or worse. DO NOT replace the fuse and try to operate it as further damage may occur. Take it in for repair.
Feb 15, 2011 | Peavey Escort 3000 300 Watt Portable PA...
Could u please send me a circuit diagram of Peavey sp2 crossover with the exact rattings or values of the parts? cos the image of the bulb you have sent is different from the one in my speakers
Here is a link to forum that someone has posted the soundguard protection circuit down the page:
http://forums.peavey.com/viewtopic.php?f=26&t=2168&view=previous
The 1156 lamp MAY have slightly different shapes but is an automotive lamp. If the bulb is blown, the polyswitch fuse is likely blown as well.
Jan 14, 2011 | Peavey SP2 PA Passive Speaker
Whats the wattage of the bulb used in peavey sp2 crossover, my sp2 peavey speaker bulb is blown
The lamp is an "1156" lamp... replace with that part number. Here :
http://search.digikey.com/scripts/DkSearch/dksus.dll?Cat=524517&k=lamp%201156
Or you can find it at auto parts store.
LIKELY the polyfuse device is ALSO gone... Probably similar to this one (1.1 amp, trip 2.2 amp):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=F2010-ND
or this one (1.85 amp, trip 3.7 amp):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=F2013-ND
Jan 11, 2011 | Peavey SP2 PA Passive Speaker
Music Logo
27 people viewed this question
Top Peavey Music Experts
Ben Armstrong
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
