Question about Continental Refrigerators
Where can I purchase replacement parts fro a Continental Electric water dispense Model EC29101
I need to know how to contact customer support or a place to purchase parts for a EC29101 Continental Electric water dispenser
  • 81 Answers
Right here
http://www.appliancepartspros.com/search.aspx?model=ec29101
Posted on Nov 26, 2014
SOURCE: water dispenser lever on Frigidaire
My Frigidaire side by side is a little different from tech17's solution. It has no slots for a screwdriver to pry it off. It is a model FLSC23F6D55 manufactured 3/05. There is a semicircular spill tray in the bottom of the recessed water station. Just pry out the tray, from the bottom corner of the frame from the side and or bottom. (I did this with a knife blade.) This tray is a snap-in fit. Then you will see three phillips head screws in the bottom of the frame. Take out these three screws and remove the frame by lifting up on it and pulling out at the bottom. Then take out three more phillips mounting screws to remove the processor card and key pad. You will then see the top of the water lever mounting. The lever comes out by removing two more screws that hold the pivot shaft of the lever. (These last screws are a little more diffiucult to get to, but not anywhere near impossible.) I wish you well.
Posted on Jul 13, 2008
SOURCE: Ice and Water Dispenser not working on KSCS25FKSS01 KIT.AIDE MODEL
This is a known manufacturing defect. The problem is that the wire that some of the wires that run between the door and the rest of the refrigerator have broken and, believe it or not, the only solution is to replace the entire freezer door. Whirlpool is covering the cost under a hidden warranty...call them and describe the problem.
Posted on Jul 20, 2008
SOURCE: Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Posted on Sep 20, 2008
  • 531 Answers
SOURCE: Taste of water from water dispenser has "plastic taste"
you have to flush dispense water on till taste gone
Posted on Apr 02, 2009
  • 14 Answers
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Posted on Apr 04, 2009
I have a primo bottom load water cooler model # 900130 the pump is not working. How do I fix it
I have missing or damaged parts. + - Select parts are available for your dispenser. Please complete the Contact Us form and provide the dispenser model number, serial number, and note the replacement part needed in the comments field. A Care Specialist will follow up with your request. A replacement fee will apply to out of warranty part requests.
900130 Primo Water Store
Dec 26, 2015 | Unknown Primo Deluxe Stainless Steel...
2001 lincoln continental over heating all ready replaced water pump and thermostat
Should scan your car's computer for proper diagnostics. Look fro proper service who has the scanner, Might save you money replacing innecessarily parts
Jun 22, 2015 | 2001 Lincoln Continental
How to repair refridgerator ice water dispenser paddle
Not a person in this world can help you without a model number? If you have questions please let me know, Thanks John Tripp Appliance 911
Contact Me Here
Sep 04, 2014 | Whirlpool Refrigerators
How and where do you change water filter
From the KitchenAid Manual:
The water filter is located in the upper right-hand corner of the
refrigerator compartment.
Replacing the Water Filter
To purchase a replacement water filter, model 67003523 Part
Number 4396395, contact your dealer or call 1-800-442-9991
U.S.A. or 1-800-807-6777 Canada.
IMPORTANT: Air trapped in the water system may cause water
and filter to eject. Always dispense water for at least 2 minutes
before removing the filter or blue bypass cap.
1. Turn filter counterclockwise to remove.
2. Remove sealing label from replacement filter and insert the
filter end into the filter head.
3. Turn the filter clockwise until it stops. Snap the filter cover
closed.
4. Flush the water system. Depending on your model, see
"Water Dispenser" or "Water and Ice Dispensers."
NOTE: The dispenser feature may be used without a water filter
installed. Your water will not be filtered. If this option is chosen,
replace the filter with the blue bypass cap.
http://www.kitchenaid.com/digitalassets/KFCS22EVMS/Use%20and%20Care_EN.pdf
May 16, 2014 | KitchenAid KFCS22EVMS French Door Bottom...
WHERE CAN I PURCHASE PARTS FOR THE PROFESSIONAL SERIES PS78111 ICE MAKER? THE GO TO THE TROUBLE OF SHOWING A PARTS BREAKDOWN IN THE MANUAL BUT DO NOT PROVIDE A SOURCE FOR PARTS. THANKS G W ABNEY
I need a new circuit board for my Continental Proffessional Series portable Ice maker.Model Ps78111 120v/60hz ref.R134a/37.Need to know where to purchase part and priceThanks Jim .email me at jimjo@cyberback.com
Jun 27, 2011 | Continental PS78111 Compact Refrigerator
Part needed
I finally found contact info for the maker and I have a number to call in Canada to order the part.
May 29, 2009 | Whynter FX-6SB Free Standing Hot & Cold...
How do I replace soap dispenser pump mechanism?
Our brand new Avalon model had this problem. It sure appears to be a design defect or defective part. After contacting customer support, they sent a replacement pump (the internal part, not the whole unit).
After removing the unit from your sink, holding the top pull firmly with constant pressure on the pump assembly. It will pop off, but you have to pull pretty hard.
I suggest running water through the top of your unit before putting the new pump assembly on it. Ours had black 'junk' inside even though it was brand new. The new unit just slides on in the reverse process of removing the old one.
Oct 30, 2008 | Price Pfister Marielle Kitchen Faucet with...
Ice/water dispenser broke
I need the model # from the inside of the refrigerator i will let you know plz post it here
Jan 08, 2008 | GALAXY Microsystems 55622
Refrigerators Logo
Top Continental Refrigerators Experts
John Tripp
John Tripp
Tom Chichester
Are you a Continental Refrigerator Expert? Answer questions, earn points and help others
