Ptac amana model on heat mode will heat for a while , then will shut off when it's a the correct temp, but then when it starts back , the heat will start blowing cold air, but the room remains basically normal temp ? Do I need to tell my landlord it's broken or is this normal ?
    Master:
  • 359 Answers
I would just ask the landlord the same question you asked us. It should always blow warm air if it is working properly.
Posted on Nov 26, 2014
  • 6 Answers
SOURCE: amana ptac shuts on and off constantly
your control board is shot and your ac can't tell the room is cold enough. 1-888-855-9987
Posted on Sep 09, 2008
kf4rwe
  • 25 Answers
SOURCE: Heat pump blows heat half the time and cold half the time
It sounds like it is just going into the defrost cycle. Go outside and see if it is iced up. If it is, it reverses itself to melt the ice. Heat strips should come on if unit has them
Posted on Dec 03, 2008
  • 3 Answers
SOURCE: ptac not heating
the board or the heater need to be replaced
Posted on Jan 06, 2009
pierre1811
  • 144 Answers
SOURCE: WHEN THE HEATER COMES ON THE FAN STARTS INSTANTLY AND BLOWS COLD
Do you have a heat pump? If so this is normal. You are probably used to a gas furnace. There are heat pumps that do have a delay though. Look on the circuit board in the air handler. There may be a set of pins that say 0-30-60-90 yours may be at 0. Also some digital T-stats offer that function for delay off to get the extra heat or cold from the system. Find out what the model number of the air handler and call the Goodman supplier in your area to see if you have these options.
If you have a gas furnace and it's not delaying the blower there is definately something wrong.
Posted on Mar 17, 2009
bobicehouse
  • 1524 Answers
SOURCE: Ruud Heat Pump blows room temp on Heat and AC setting
A "Heat-Pump" is also known as a reverse cycle air conditioner, this means on heat the outdoor unit acts like the indoor section and vice versa. So in all probability you need to have it leak checked and recharged.
Posted on Apr 27, 2009
PTAC stops running after a short time
Sounds like a voltage or amp draw issue. So how about if you only try to run the blower??
Jun 05, 2017 | Heating & Cooling
My amana ptac is not heating....the code "np" is displayed....how do I correct this...we just installed the unit and know little about operation. Thanks
I don't see this error code in the manual. I do see nP as an error code for Window Switch lockout. I just had this happen to me and they had me reset the control board.
Remove case, flick master switch to OFF for 10 seconds. Press Heat/Cool same time turn switch back on HOLD until off light comes on.
You should be fixed. Just had to do this for my unit. I was playing around with the settings and turned on the window switch option by accident.
Feb 02, 2013 | Amana In Wall Install Kit For Digismart...
Amana PTAC will cool but fan will not go up in speed
Change the thermostat wire , if not change your board.
Jun 02, 2012 | Amana PTH123B25AJ Heat Pump Air...
Amana PTAC unit will not cool or heat. Tried reseting, checked supply voltage, ohms checked the heating element, voltage checked off of circuit borad (power everywhere except the two heater terminals)
Compressor working ?
Please follow this tips:
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Please specify, if any error code..........
Thanks. Helpful?
Jan 19, 2011 | Heating & Cooling
Amana PTAC unit when in the heat mode only blows cold air.
check heater coil may be faulty may be a faulty thermostat or temp sensor
Dec 08, 2010 | Amana Heating & Cooling
Looking for manuel reset on heater amana ptac unit heat won't come on new control board
I dont know about this model but in general electric heat wont have a reset button the heat is controled by a sequencer and each elememt has a safty limit switch incase the sequencer sticks in the on mode here is a link to where you can get more info on this model http://www.fixya.com/support/p51773-amana_ptc153b35aj_air_conditioner
Oct 30, 2009 | Amana PTC153B35AJ Air Conditioner
I HAVE A AMANA PTH153B50AE PTACT UNIT. ANOTHER
Do you think you have a heat pump outside ?If so then I would call the installer back and show me how to operate the control.They should have did that when it was install.
Apr 06, 2009 | Amana PTC153B50AJ Electric Heat Air...
How to disable the energy saver of the amana ptac unit. Once the AC reach the lowest temp on the room , the unit turn off, then when room temp raise it turn on.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=PTH153B50AJ&siteCd=AMA
This is the link to find the manual for your unit. Make sure the model number is correct. You should be able to find the info you are looking for if it is possible to disable the energy saver. Hopefully this will help.
Mar 20, 2009 | Amana PTH153B50AJ Heat Pump Air...
Heating & Cooling Logo
145 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
