Question about Dishwashers
How do I fix it?
The failure light indicates and the pump light doesn't come on when the switch is turned on with giving power?
  • 3 Answers
Make sure there are no restrictions on the hoses because had that problem with a blocked hose that was restricting fluid
Posted on Nov 26, 2014
How to turn off floor lights
Hi Bill,
This sound like a simple switch failure.
1. Isolate the power.
2. Disconnect the load from the switch and make safe.
3. Reinstate power.
The lights should be off thus indicating switch failure. Replace the switch. If the lights are still on then you have a double feed to the circuit which requires further investigation by a competent person.
Apr 22, 2016 | Miscellaneous
Why would gould water pump red trouble light indicator come on when power switch turned back on after having been off for a few hours? Had to turn off power to pump earlier in day due to volatile elec
check and prime the pump as the light may indicate no water and so the pump will not run
foot valves leak back the water so it may need priming again
Jul 21, 2017 | Cars & Trucks
Green light blinking very fadley pc will not turn on
Sounds like you might have a partial power supply failure. Try unplugging the power supply from everything. Ther should be a switch on the back that is red and says something like 115/220 just flip that switch over to 220 and wait 5 minutes then switch it back to 115 and replug everything in and then try it. If it doesn't work then unplug everything again and let it sit for about 30 minutes (this resets the power supply) and reconnect the wires and if that doesn't work try getting a new power supply. In partial PCB (Power Supply Board) failures the problem is that trere isn't enough power going to the system to start up so sometimes resetting the PCB will fix it temporary. You should get a new one anyway. that one will fail completely soon. Good luck!
Mar 15, 2012 | Dell Computers & Internet
Do not turn on. Power failure. Replaced all the electrolytic capacitors, but still does not work.
good day check if their is a stand by 5v voltage at the power supply and a light indicator on the front panel. now if no stand by voltage and indicator light the problem is with in only at power supply. check for shorted mosfet transistor and bad regulators. now if their is an stand by voltage but doesn't turn on check the inverter board and back light for shorted parts because the main board will not turn on. check also for bad processor. hope this will solved the problem thanks for consulting the fixya.
Aug 09, 2011 | Televison & Video
Check engine light comes on after approx. one minute. My code reader gives me a 214 in continuous memory ( cylinder ID circuit failure). I clear the code and it comes back. What is giving me this code?...
look 214 is not a valid code for a 1995 escort, this is an OBD1 system. here is a list of trouble codes for this year of ford no matter the model.
You should find the diagnostic connector under your hood normally by the fender on the battery side. By just using your test light and a jumper wire, it will tell you what kind of problem you got.
KEY ON ENGINE OFF (KOEO) TEST
Model years 1984-1995 all models of Ford
1. Make sure engine is fully warmed. If in doubt, run engine at 2000 rpm for 2 minutes.
2. Turn ignition off and wait 10 seconds for system to shut off. Make sure A/C is off and transmission is in Park (automatic) or Neutral (manual).
3. Hook up light and jumper (or a tester if you have one). Turn key to ON (do not start engine). Read the codes.
How to do it?
Example code 23: your test light should flash 2 long consecutive flashes followed by 3 short pulses.
Ford's common codes for OBD1 (vehicles made before 1995)
11 system pass
12 idle control fault
13 dc motor did not move
14 engine rpm signal fault or PIP circuit failure
15 eec processor or power to KAM interrupted
16 rpm to low to check oxygen sensor test or fuel control error
17 cfi fuel control system fault or rich/lean condition indicated
18 ignition diagnostic monitor (IDM) circuit failure
19 cylinder identification (CID) sensor input failure
21 engine coolant temperature (ECT) out of self-test range
22 manifold absolute pressure (MAP) sensor circuit out of range
23 throttle positioner sensor out of self-test range
24 air charge temperature (ACT) sensor out of self-test range
25 knock not sensed during dynamic response test
26 transmission fluid temperature out of self-test range
28 loss of primary tach, right side
29 insufficient input from vehicle speed sensor
31 egr positioner sensor below minimum voltage
32 egr positioner sensor below closed limit
33 throttle positioner sensor noisy/harsh on line
34 egr valve circuit out of self-test range
35 egr valve circuit above maximum voltage
38 idle track switch circuit open
39 axod torque converter or bypass clutch not applying properly
41 oxygen sensor circuit indicates system always lean
42 oxygen sensor circuit indicates system always rich
43 oxygen sensor out of self-test range
44 air injection control system failure
45 coil 1 primary circuit failure
46 coil primary circuit failure
47 4X4 switch is closed or oxygen sensor failure
48 coil primary circuit failure
49 electronic transmission shift error
51 engine coolant temperature sensor circuit open
52 power steering pressure switch circuit open
53 throttle position circuit above maximum voltage
54 air charge temperature circuit open
55 key power input to processor open circuit
56 mass air flow circuit above maximum voltage
57 axod circuit failure
58 idle tracking switch circuit fault
59 automatic transmission shift error
61 engine coolant temperature circuit grounded
62 converter clutch error
63 throttle positioner circuit below minimum voltage
64 air charge temperature circuit grounded
65 charging system over voltage
66 mass air flow sensor circuit below minimum voltage
67 neutral/drive switch circuit open
68 transmission fluid temperature over temperature range
69 transmission shift error
70 data circuit communication link circuit failure
71 message center circuit circuit failure
72 insufficient manifold absolute pressure (MAP) change during dynamic response test
73 insufficient throttle positioner (TPS) change during dynamic response test
74 brake on/off (BOO) circuit open
75 brake on/off (BOO) circuit closed
76 insufficient air flow output change during test
77 brief wide open throttle not sensed during test
78 power interrupt detected
79 a/c on/defrost on during self test
81 map has not changed normally
82 super charger bypass circuit failure
83 OIC-low speed fuel pump relay circuit failure
84 egr vacuum regulator (EVR) circuit failure
85 canister purge circuit failure
86 shift solenoid circuit failure
87 fuel pump circuit failure
88 electro drive fan circuit failure
89 transmission solenoid circuit failure
91 no oxygen sensor switching detected
92 shift solenoid circuit failure
93 throttle positioner sensor input low
94 torque converter clutch solenoid circuit failure
95 fuel pump secondary circuit failure
96 fuel pump secondary circuit failure
97 transmission indicator circuit failure
98 electronic pressure control circuit failure
99 eec has not learned to control idle
Jan 14, 2010 | 1995 Ford Escort
What does the " Power " light on the dash indicate when it is lit on my Forester 2.0 Turbo S auto ? The manual doesn`t mention it !
Do you have a switch (usually a push button) on or near your shifter labeled "Power" or "Performance"? Some cars have a button that can turn on a different shift program for the transmission, usually holding gears longer and firming up shifts. Once you locate this button press it again and the light should turn off.
Oct 25, 2009 | 1999 Subaru Forester
VFR800-2 Bike cuts out when lights,indicators or pass flash
I don't think you have a short. It sounds like the earth cable is broken somewhere and is arcing when you start drawing a bit of current.
Aug 17, 2009 | 2002 Honda VFR 800
Dell latidue D610
The light indicator for the battery is; green-charging, yellow-battery failure, and red-charging system failure. The charging system failure happens when the power management chip fails. The pm chip regulates and controls the power input & usage, allows the machine to switch from AC to battery, and cotrols the charging. This will also cause the problem with the power button not workin or being hard to start. Unfortunately, the motherboard will have to be replaced in order to fix this.
Jul 26, 2008 | Dell (F2273) Motherboard
Dishwashers Logo
41 people viewed this question
Top Dishwashers Experts
