Question about Curtis Sno-Pro 3000 Trip Edge Snow Plow
My plow don't work: replaced a bad hose. It was working. It might need a battery, and I have one charging.
  • 31 Answers
Check your remote or your wiring could be a possible pinched wire or remote could be acting up
Posted on Nov 26, 2014
My plow quit working, just after I replaced a bad hose.
It appears that you have a vapor lock, Might have to work it some and release hose slightkly to get air out.
Nov 26, 2014 | Curtis Sno-Pro Home Pro 3000 Snow Plow
Battery goes dead sense the plow has been installed with it on or off.
Check all battery cells to see if specific gravity in each cell is nearly the same. Check charging voltage (about 14 volts). Make sure something is not left on.
Mar 29, 2014 | 2008 Ford F-350
Will not keep a charge in my battrey when im plowing snow
Test your battery to make sure your voltage regulator is working.Plows do drain batteries,but they are supposed to recharge.
Jan 10, 2014 | Polaris 2004 Sportsman 400
Hand drill
You could have a bad battery (most likely), bad charger or bad drill. The only way to be 100% sure is to try another battery in the drill and/or try charging the battey on another charger. If you don't have a second battery but do have a service center in your area, they can test your drill to make sure it works. Chargers either work or they don't, there are very few that can be repaired and usually have to be replaced. Batteries do go bad eventually depending on age and number of times discharged and recharged.
Mar 13, 2012 | Craftsman Drills
I have an 88 chevy blazer with a myers snow plow when i raise the plow all the lights go out and the motor gets real sluggish i have been trying to figure it out but cant can you help me please
snow plows use alot of juice check state of battery if battery good check altnernator output may need to go with higher amp alternator or add a second battery
first thing to do is clean all connections leading to plow power and grounds (all of them ) and make sure there tight clean battery cables as well
next thing i would do is have battery load tested as this is probley the main cause as alternaotr working so hard to keep up it takeing all power from motor
if battery test out ok replace alternator with higher amp alternator
if still have problem after all that add a second battery to truck
Jan 29, 2011 | Chevrolet Blazer Cars & Trucks
Battery goes dead when plowing snow
change alt. have it check at autozone free of charge
Dec 26, 2009 | 1986 Dodge Pickup 4WD
97 Ford F350 XLT, worked fine, but will crank but won't start --
Start the car and when truck runs disconnect one of the Battery terminal, if engine quits You need an alternator
Jan 22, 2009 | 2006 Ford F 350 Super Duty
Battery Not charging
I believe I can help you. There are a few things to check.
First, are you running the plow a lot when you're having these problems? If so, you MAY need to install a second battery designated for just using the plow with it's own alternator. Hydraulic pumps use a lot of electricity to run.
Second, there may be a short in your electrical system, try installing a battery disconnect and disconnect the battery every time you shut the truck off for extended periods of time (more than a day).
Finally, check the voltage regulator (or have a shop look at it). If it is not working properly, the batteries may not re-charge correctly. The cheapest way to solve the problem is with a battery disconnect, but it may get annoying after a while, especially if you forget to disconnect it and your battery goes dead. Finding a short in an electrical system is a long and tedious process that may not always solve the problem. And installing a second battery and alternator for the plow can get expensive.
I hope I could help you with your problem and good luck.
Jan 05, 2009 | 1992 Chevrolet Camaro
Curtis Sno-Pro 3000 Trip Edge Snow Plow Logo
121 people viewed this question
Top Curtis Garden Experts
Dennis Key
Dennis Key
john h
Are you a Curtis Garden Expert? Answer questions, earn points and help others
