I have a Maytag staclabel/water won't drain/Model no. Lsg1000 series 10
    New Friend:
  • 29 Answers
First, take off the panel to the pump area so you can see the pump, belts and pulley, unplug the machine check the belts by hand to the pump you should have two; one is a pump belt thee other is a drive belt make sure they are taught enough to drive the pump. While you are there, checking the belts check the pulley if those are fine your pump may need replacing and if you notice wear and tear on the belts replace them as well.
To double check remove your hand and plug the machine back in and run it through the pumping cycle with water just as if you were washing cloths and while using a flashlight watch it run; if it runs fine kicking on and off like it suppose too replace the pump. If it does not cycle on and off check the fuse if you have an electronic issue it would be best to call a technician.
Things to look for;
Broken belts, burnt belts from slipping, cracks in the belts, loose screws or bolts, loose or broken pulley, leaks in the hoses and pump housing etc.
If you find a broken belt, your pump may or may not be fine. Time to repair 1 hour cost $100 or less, however, if it is in the control board call a technician.
Here is a little secrete if your warranty has expired some places would still sale one to you, pending how long it has been out dated all you have to do is call them and ask and in most cases the cost of the extended warranty is cheaper than the cost of repairs.
Sears have been good me over the years with refrigerators, washing machines, dryers and TV's furthermore, so has JVC with camcorders when I could not get an extended service contract they had no issues helping me when I contact them directly. Therefore, if you cannot get the extended contract, contact LG directly they may help you as well. In fact, when the electronic store where I bought my JVC would not sell me an extended contract to get a repair JVC contacted them directly and told them to sell me one the next day the store called me and told me to pick up my new service contract and a refurbish replacement camcorder. The manager thought I had some clout when in actuality a little respect and tact goes a long way. Truthfully, when I called JVC service center I was in a good mood although the person at the other end was not although remaining professional and polite the whole time, anyhow by the time our conversation was over they were laughing and feeling much better.
Billy of Hayward, CA.
Posted on Nov 26, 2014
    Problem Solver:
  • 12 Answers
Sounds like a drain pump issue but check the outlet hose for kinks or blockage before you call repairman. Parts diagrams do not show any consumer servicable pump filters like the newer machines.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
If you still have this problem, and you haven't solved it locally, write me here or at alanwkelly at the Gmail.com and provide as much as you can about the machines. Are they new? Used? Have you known them to work without problems before? Are the hoses kinked, that is, blocked? Are the pipes into which the washer hoses attached - clean and free of blockage? Info like that would be helpful to answer your question so far away. Methinks you need someone close, local. RSVP
5 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: I need to find out the year my maytag was made -
HOW OLD IS MY APPLIANCE?
Posted on Jan 04, 2011
langman_kevi
  • 3 Answers
SOURCE: My frigidare crown series washer won't drain the
Remove the back cover and later the drum drain pipe. If a filter is present, dismantle and clean out. Most often the cause is a object that that is hindering the operation of the spinning pump. Dismantle and clean the pump.
Posted on Feb 29, 2012
alicantecoli
  • 22326 Answers
SOURCE: my La 882 washing machine water does not drain and cycles takes longer? please advise?
most likely cause on modern machines is the fact that you cannot home diagnose them ,they can only be checked out by the agent as they use a mini computer with encrypted software like a car .sorry for not being able to help
Posted on May 26, 2012
SOURCE: maytag front load washer model 6500AWQ won't drain completely
Try using the extra rise cycle.I hope that helps.
Posted on Oct 18, 2012
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Maytag quiet series 200 dishwasher spray arms won't turn
Have you tried tighten the spray arms? They may have come lose at the fittings so need to be tightened up. You can normally tighten them with your hand. Take any traps/filters out of the dishwasher and clean them.
You may find answers here: https://www.maytag.com
Jan 15, 2013 | Maytag 24 in. MDB4000 Built-in Dishwasher
Maytag top load washer water runs but doesn't fill.
Drain is to low. You will have to raise the drain hose above the top of the washer. Whats happening is the water is siphoning out as fast as it goes in.
Please rate this solution
Sep 02, 2009 | Washing Machines
Goes through cycle, but doesn't drain. Will drain manually
Hi, Sounds like it could be timer. Does the timer advance to the off position? There could be a partial plug in the hose or pump also. You can add water again and then go to spin cycle. Lift the drain hose out of the drain pipe just enough that you can see the water flow. You should see water draining out with a bit of force and the stream should be the sizt of the drain hose.
I hope this helps you. Please let me know if I can be of more assistance.
Thanks
Vic
May 11, 2009 | Maytag Legacy Series Top Load Washer
Burned belt?
Yes, smell like your belt.. if there is water in tub, try to get it out... (wet vac)... slide your washer out and tilt it back so you can see under... there should be 2 belts.. 1 for gear and 1 for water drain pump... and you can check Sears.com for parts.. good luck...
Jan 23, 2009 | Maytag SAV5710 Top Load Washer
Maytag top laoder stacked washer LSG1000
If it only leaks in drain it has to be a hole in the drain hose or a plugged up house drain.
Dec 15, 2007 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
78 people viewed this question
Top Washing Machines Experts
