My UR5U -9020L remote won't change channels or pull up the guide?
I have unplugged the dvr. I have tried what little I know about this remote but can't get it to work.
    Master:
  • 379 Answers
How long have have you had the remote and is this the first time this has happened and when was the last time you changed the batteries?
Posted on Nov 26, 2014
Testimonial: "This is a new unit. But I changed the batteries with no change."
SOURCE: Comcast Remote requires 3 digits be entered to change channels
l. Push the "Menu button"
2. Push the "Menu button" again
3. Scroll to "Setup" and push "OK"
4. Scroll to "Guide setup" and push "OK"
5. Scroll to"No Auto Tune"
6. Click on arrow next to "No Auto Tune". This will change it to "Auto Tune".
7. Now exit, or just punch in any channel number.
You should now be able to go directly to a channel without entering zeros.
Posted on Apr 11, 2009
SOURCE: Just got a HDDUEAL Turner DVR DCH6416....problem with certain channels...
spdif out
Posted on Mar 14, 2008
SOURCE: remote will not work
Use your box and go into Menu then to Setup then Select, next Syst Setup go to Reset then go to Reset defaults use the mute select buttons at same time after double flash press 961 then go back and press mute select after the double flash press 00001 and presto the remote worked again!
Yeah I didn't have to reset everything.
Read all your screens first before just calling DirectTV!
Posted on Apr 24, 2009
  • 5 Answers
SOURCE: motorola dvr dct6412 locked channels
Check with your provider to ensure that you are in expanded services, or limited. Because being on limited services the box will lock you out of those channels. If you are in billing for those services and you checked the batteries on your remote and they are good and you get a solid red blink when you change channels not a double blink (indicating that your batteries are dying), Then try power cycling your DVR by, removing the power supply and waiting 3sec then plug it back in. Your box should shut off, turn itself back on, then go into the load screen, then, once the load screen display shows on your tv and on box display, wait for your box to completely load (don't touch nothing until the correct time shows up, meaning that it has completed the load process) Once the process is complete turn box back on and you should have you guide back up and (No Data) on your program schedule(Don't Worry!!) it will populate, with 15-20 mins.
Now try to ch. up and down and see if that fixed the problem. also make sure nothing is blocking the sensor. If all else fails and you changed the battery, called your cable provider and request a box swap, (be sure to watch all your recorded shows because they go bye, bye with the cable guy!)
Posted on Oct 27, 2009
  • 44 Answers
SOURCE: I have amotorola dual tuner
Hi, My name is Tina and I am with Suddenlink. Are you still having this issue? If so, please feel free to email me at tina-AT-suddenlink-DOT-com for resolution.
Posted on Nov 08, 2010
I'm trying to program a magnavox converter box with a universal remote model UR5U-8780L-TWT. I need the code for this please.
Hi Jerry, This is from the link below.........
The Time Warner Cable CLIKR-5 is designed to offer complete control for all digital, HD and DVR set-top boxes. The UR5U-8780L is factory programmed to operate Scientific Atlanta/Cisco and Samsung set-top boxes while the UR5U-8790L is factory programmed for Motorola set-top boxes.
Time Warner Cable CLIKR 5 Universal Remote Control
May 01, 2016 | Magnavox Televison & Video
USING MOTOROLA BOX TRYING TO FIND REMOTE CODE FOR TCL - REMOTE UR5U-9020l
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Try a search by type in the brand name of your device, in the search box & press enter.
Sep 24, 2014 | Televison & Video
UR5U-8780L DVR remote won't work with Hanspree HSG1102 TV.
no, this is common with remotes, if they program for another unit key features may be missing. Look to see if remote has a search mode that allows you to try each and every code it has one at a time.
Nov 05, 2012 | Televison & Video
Froze
To see if the problem is with your remote control, go to the receiver and use the channel up/down buttons on the receiver itself. If you can change your channels with the buttons on the receiver, the batteries in your remote control probably need to be changed.
If you can't change channels from the receiver, turn off the receiver. Then unplug it for at least 15 seconds. Plug the receiver back it and turn it on. Again, try changing channels from the receiver itself.
Tune to a channel, and while programming is playing, try tuning to the missing channel by entering the channel number on the remote control keypad to see if channels change. Do not try to select the channel from a channel list, program guide, or favorites list.
If this approach takes you to the correct channel, you need to adjust your favorites list function. Press the "guide" button on your remote. Look for a button on your remote called "fav" or "list." Press it several times and watch for an indication at the top of the guide that you are moving from "all channels" to a particular favorites list.
If you are locked on one channel only, your Channel Lock feature is likely active. Consult your owner's manual to unlock the rest of your channels. See your owner's manual for information on managing favorite channel lists and locking out channels. Enter your password, if necessary.
Jul 30, 2012 | Coby TFTV1925 19 in. LCD TV
Program ur5u/mdvr to sony rdr gx357
Possibly, it won't hurt to try, the machine will not be harmed.
May 21, 2012 | Sony Televison & Video
My remote only turns channels but its dosent go to the guide on my dvr box
Check the remote manual, it problem loose the code for your device. When this problem occurs, the remote only perform the basics functions. Maybe the TV company can give you this support, giving the REMOTE'S Program CODE , usually a code like 0000, XXXX... XYZT...
Apr 07, 2012 | DISH Network 721 DVR Remote Control
Ur5u-8780l not operating channels on Magnavox TV. Tried all codes and switched channel control to TV, still nothing.
If you are using a universal do not expect it to even if it programs to have all the functions you need or want or had with the original remote.
Universal remotes are far from UNIVERSAL.
The best argument for an original remote is even if it programs it will just not have all the features needed or wanted that the original had.
Hope this clears things up a little.
Apr 03, 2012 | Televison & Video
I have a new UR5U-8780L-TWS universal remote and am unable to program my Magnavox DVD/VCR combo (I know, old school). Does any one have the codes needed to program my remote for both DVD and VCR...
Try this website:
http://www.universalremote.com/resources/software/tutorial/UR5U-8700-Series.htm
I just used their "web app" to program my UR5U-8780L-TWS remote (from Time Warner). It's fairly simple to do, just follow the directions. Good luck!
Nov 18, 2010 | Televison & Video
I have the gray Comcast DVR remote control-it is so unresponsive!
I called Comcast about this today and they had me turn off the TV, unplug the DVR, unplug the coaxle cable, wait a second, rescrew in the coaxle cable, replug in the DVR. It worked! The DVR is snappy like it used to be. Such a relief because it was soooo annoying. Good luck.
Feb 28, 2010 | Televison & Video
Televison & Video Logo
268 people viewed this question
Top Televison & Video Experts
