Question about Kenmore Kitchen Ranges
I am unable to use the downward arrow to change oven temperature on my Kenmore stove and oven model #55632. Please advise.
I have never used the down arrow since I bought the stove.
  • 937 Answers
The contractor for that portion of the touchpad may have developed a little corrosion from lack of use. Work that button intensively for a few minutes, perhaps you can regain its functionality. Otherwise you are looking at either attempting to dig in and clean the contact, replacing the keypad, or simply living with it.
Posted on Nov 26, 2014
fridgetech
  • 473 Answers
SOURCE: Oven not heating to correct temperature
First thing that should be checked is proper voltage.  Low voltage can cause this problem.  Have that checked by a professional first then let me know what you find.
Posted on Oct 18, 2007
jessee007
  • 310 Answers
SOURCE: Kenmore electric range 911.9369181
F8 Failure of Electronic Range Control (ERC) Replace Electronic Range Control/Clock (ERC)
Posted on Jan 01, 2008
  • 150 Answers
SOURCE: frigdaire gallery stove
lock mechanism is acting up. happens sometimes. you can get to it from the back and get the thing open to use until you get the part
Posted on Apr 22, 2008
aborcass
  • 2651 Answers
SOURCE: CRG9700 - OVEN TEMPERATURE BIG FLUCTUATIONS
biggest issue with any gas oven is a faulty ignitor, not maintaining oven temp, too long to preheat, taking too long to cook, possible slight gas smell during operation, all signs of a bad ( or going bad) ignitor
Posted on Nov 11, 2008
  • 95 Answers
SOURCE: Kenmore gas stove. Oven burns big flame which soots
The manifold needs to be cleaned and adjusted could have rust etc in it Not a good thing to do yourself unless you know what you are doing
Posted on Jan 24, 2009
How do get rid of F10 which is on the window of my Kenmore stove
The F10 error means that the high temperature sensor is reporting a runaway temperature and shut down to avoid a potential fire. Try unplugging the stove or tripping the circuit breaker to reset the code.
If the error recurs, unplug the stove (or turn off the circuit breaker) again. Look at the broiler and bake elements with a flashlight. If it has any damage (breaks, char, melting), you will need to replace the element. Check where the elements connect to the oven and replace them if there is any charring on the back wall.
If the elements are undamaged, you need to check the wiring to identify if the problem is at the elements, the high temperature sensor, wiring or the control board. You will need to access the wiring from the back of the stove. Disconnect the wires to the heating elements. Then disconnect the wiring connections at the high temperature sensor and the control board. Without a model number, I can't be completely sure of the resistance that should be seen at various points. Please post a comment with the model number of the stove and I'll try to confirm the expected and faulty resistance values. Most likely, the resistance should be under 50 ohms but above zero between the left and right contacts of the elements and the violet wires in the wiring harness at the control board. The high temperature sensor should probably have a resistance between 1,000 and 1,200 ohms. If the resistance is high, you'll need to replace the appropriate parts. (Note: if the wiring at the control board gives a reading similar to the resistance of the high temperature sensor, the control board is the likely suspect.)
I hope this helps. If your stove is under warranty, contact Sears/Kenmore to fix the issue. If you aren't comfortable testing the wiring, contact Kenmore for a service call.
Feb 04, 2015 | Kenmore Ovens
Frigidaire stove model number FEF355DQE how to adjust the temperature
Hey Damieon Garner, thanks for your post! Typically to adjust the temperature within your Frigidaire range you would use the knobs for the cooktop and the "Up" and "Down" arrows for the oven. If you are having any additional troubles with your range could you please provide that information? I look forward to assisting you further if need be. -Matt
Oct 13, 2014 | Kitchen Ranges
How to change the temperature display from Celcius to Farenheit
Hello Friend, that's a great question!
Please follow the steps below to change the temperature to Celsius to Fahrenheit on your Frigidaire range, FEF366CCA.
    ·Press BROIL. "-" appears in the display.
    ·Press and hold the UP arrow until "HI" appears in the display
    ·Press and hold BROIL until F or C appears in the display.
    ·Press the UP arrow or DOWN arrow to change F to C or C to F.
    ·Press any control pad to return to normal operating mode.
    Hope this helps! - Z
Sep 03, 2014 | Frigidaire Gas & Electric Stove/Oven/Range...
How do turn on oven
Good Afternoon Friend,
I understand you want to know how to turn on your Frigidaire range, model# FGF378AC. First, you will need to make sure you have set the clock, by pressing the clock button and then pressing and holding down either the up or down arrows until the correct time displays.
Secondly, you will turn your oven on by pressing the "Bake" button and then pressing and holding down either the up or down arrows until the correct temperature displays. Once you release the up or down arrow, your oven should begin heating to the desired temperature. The control will beep three times, once the temperature has been reached.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 29, 2014 | Frigidaire FGF378AC Gas Kitchen Range
How to turn on electric frigidaire oven; fgf337gud?
Good Morning Friend,
I understand you want to know how to turn on the oven on your Frigidaire range, model# FGF337GUD. First, make sure you have set the clock. You will do this by pressing the "Clock Set" button and then press and hold down the up or down arrows, until the correct time shows. After you have set the clock, you are ready to turn your oven on.
To set the temperature for your oven, you will press the "Bake" button and three dashes will appear. Press the up and down arrows to change the temperature. Note: The temperature will begin at a default temperature of 350 degrees. Once you have released the up or down arrow, your oven will begin heating to the selected temperature. When your oven reaches the desired temperature, it will beep once.
To cancel the baking function, you will press the "Clear/Off" button.
If you wish to change the temperature after baking has begun, you will press the bake button again, and then change the temperature by pressing the up or down arrows to either increase or decrease the temperature.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
I sthere a way to calibrate my oven temperature? It is off by about 35 degrees. Temperature is lower than display.
Sorry to read about your problem, I hope this helps you out.
To Adjust the Oven Temperature (do not use Bake or Broil while adjusting the oven temperature): note: Your oven control was factory set in the (Fahrenheit) °F Temperature Display Mode. To change for (Celsius) °C, see page 15.
1. Press & hold the BAKE key pad and release after the display shows the factory temperature setting of 00. note: If the oven temperature has been previously adjusted from the factory setting, the current temperature adjusted value will appear in the display instead.
2. You may increase the oven temperature in 5°F (1°C) increments with each press of the uP arroW pad to a maximum oven adjustment of +35°F (+18°C). You may also adjust the oven temperature downward in 5°F (1°C) increments with each press of the doWn arroW pad (total range of -35°F to +35°F (-18°C to +18°C).
3. If you do not want to keep the display adjustment, press the clear oFF pad before the oven control beeps. This will cancel the temperature adjustment procedure. To start this procedure over again begin with step 1 above OR;
4. If you want to keep the adjustment, wait until the oven control beeps once.
5. The oven temperature adjustment has be accepted by the oven control and the display will return to the time of day.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Frigidaire FEB24S2AB Single Oven
What the code f3 mean my stove model # is 911.9584991
This model ( Kenmore ) has been built by Roper ( 911 - First 3 digits tell you the manufacturer's name ).
F3 refers to Oven temperature sensor open.
You need to check the oven temperature sensor.The value of oven temperature sensor should be around 1100 ohms at room temperature. In case, it is too high or low, you need to replace that.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 05, 2010 | Kenmore Microwave Ovens
Electric Diagram for Kenmore Model 790
Has the oven run out of control or gotten too hot? The 790 series is made by Frigidaire and those fault codes are F0 to F8. F2 indicates the temperature sensor is reading too hot. Now with the double oven models, some manufactures add an extra digit to the fault codes to indicate which oven created the fault.
Your most likely fix is to replace the temperature sensor. The most probable locations for the wiring diagram is taped inside the bottom drawer, on the back or under side of the oven, or behind one of the panels on the back of the oven. This might tell you the room temperature resistance for the temperature sensor so you can test it with an ohmmeter and be sure that it is faulty. Try Appliance Parts Pros for replacement sensors.
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Electric Kenmore Ultra Bake Oven
I finally found my manual to the range, and to change from celsius to fahrenheit press the BROIL button for 5 seconds. A tone will sound, and the temperature should switch to Fahrenheit.
As far as the code PF 5ab--it could be PF Sab which means the power went out during Sabbath mode. Try pressing and holding TIMER OFF for 5 seconds. If that doesn't work, then open the oven door, press STOP/CLEAR, press both the HOUR "up" and "down" arrow pad at the same time and hold for 5 seconds, "Sab OFF" should appear. Press START to accept the change, then close the oven door.
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Nov 24, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
66 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
