Question about Frigidare Ovens
Frigidare double wall oven, both heating elements not getting hot.
I've changed the electronic front dispaly and installed one new heating element in the upper oven
    Genius:
  • Frigidare Master
  • 2,432 Answers
Check the mains voltage at the socket it may be blown fuse or faulty circuit braker, If ok check the oven on off switch for voltage.
Posted on Nov 26, 2014
catriver
  • 878 Answers
SOURCE: Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Posted on Dec 27, 2006
dgjtex
  • 405 Answers
SOURCE: Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Posted on Dec 27, 2008
kachbibi1
  • 979 Answers
SOURCE: Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Posted on Jan 30, 2009
  • 135 Answers
SOURCE: frigidaire wall oven will not heat up very fast
The clock control has a relay that turns on the element. It could be failed and would require a new clock control.
Posted on Aug 27, 2009
  • 291 Answers
SOURCE: Oven doesn't reach temperature setting
It could be the plug/receptacle that the element plugs into. It could also be that the elements have separate thermostats and that the one for the lower element is bad. If you can post the model number I can look at the electrical schematic and know for sure if it has one or two thermostats.
Posted on Aug 31, 2009
How to change the electric oven GE 168947 elements
Basically you unplug the oven and remove the back, you should see two wires connected to the elements where they come through the oven wall in the back. Unhook those wires. The elements are held in place with nuts on the portions that poke through, remove the nuts and pull the element out through the front, and install the new one. Note that if you break one of the connections on the wires to the heating element, they can be a real chore to repair because they are high heat connections.
Feb 18, 2017 | GE Ovens
The top oven is over-heating with no change in temp display. A red-hot heating element on the left side of the oven (facing it) shows through the floor of the oven.
Good Morning Eileen, thank you for your inquiry!
I understand that your Electrolux double wall oven is having over heating issues. It is possible that this could be a faulty thermostat, control panel, or element. Since it could be anyone of these underlying having a technician out would help avoid any unnecessary part purchases. If you need help locating a technician you can visit your manufacturer's website for additional assistance with locating a technician. I hope this information is helpful to you. -Matt
Aug 09, 2015 | Electrolux 27" Built-In Double Electric...
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Slow to heat on convection mode, bottom element not get as hot as
Check to see that the convection element is heating. If not, ohm it out, either the element is bad or it is not getting power from the control.
Jun 25, 2010 | Frigidaire 30 in. Electric Gallery Series...
Jennair model WW2780 Double oven. Top oven will not heat. Turn on with controls and immediately just shuts off again. Assume it is the heating element. Not sure how to replace element and reading advise on...
This is not your heating element. If the element comes on at all, it is not out. This is your electronic control board that is going out.
We have parts and instructions on how to replace the parts on your Jenn-Air oven.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
and we will get the correct parts out to you asap.
We look forward to getting you cooking again soon!
Nov 07, 2009 | Ovens
Aug 31, 2009 | Frigidaire 30 in. Electric Double...
Oven not heating
If the element only works partially or not getting red hot at the "Hi" setting, the problem might be with a burned out receptacle that the element plugs into. If this is the case, replace both the element and the receptacle.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
Jun 22, 2009 | Frigidaire 30 in. Electric Gallery Series...
I have a GE Single Wall electric oven.(JTP25SOH2) The heating elements just stop getting hot. unit is about 4 years old purchased brand new. first the broiler stop getting hot then the baking heating...
First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
Jun 11, 2009 | Ovens
Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
nguyen@ite.net
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Viking Double Electric Oven VEDO127T
Probably a faulty heater element, some ovens have more than one element in the compartment, so it is possible you only have part heat.
Dec 01, 2008 | Viking 27" Professional Select Built-in...
Ovens Logo
79 people viewed this question
Top Frigidare Ovens Experts
Dan Webster
Dan Webster
bobalix
Are you a Frigidare Oven Expert? Answer questions, earn points and help others
