Question about Drills
GLENTANNER MODEL ZQ116 DRILL PRESS. how do Iknow what size belts are as they are old, cracked and frayed.
  • 44 Answers
Your best bet is to take the old belt with you when you shop for a new one. The sales clerk should be able to match it up.
Posted on Nov 26, 2014
  • 10865 Answers
SOURCE: Replace drill chuck on 23 year old Craftsman 8" drill press
Yes it does have a Morse taper and you can remove it by gently hitting it with a rubber or nylon mallet.
Posted on Feb 08, 2009
SRF518
  • 232 Answers
SOURCE: Hi I'm looking for a part for a drill press
check out this url:
www.jalopyjournal.com/forum/showthread.php?t=237685
Posted on Oct 20, 2009
  • 302 Answers
SOURCE: I have a old stand up drill press ss 1 944 with a
Walker - turner has been out of business for a long time. You should be able to move the motor mount toward the spindle to loosen the belt and change without removing the pulley. hope this helps you.
Posted on Oct 26, 2009
rowdy45176
  • 2176 Answers
SOURCE: drill press
No there isnt. the chuck has a taper fit and needs to be cleaned and installed correctly. Use something like a brake clean or carb cleaner and spray the shaft and the internal socket of the chuck, wipe both clean with a paper towel and then move the table out of the way and with the chuck jaws fully retracted use a piece of wood and "seat the chuck" I usually strike the wood a couple of times. this should work as long as the tapers are not that worn.
Posted on Jul 18, 2010
  • 11 Answers
SOURCE: Delta 12" Variable Speed Drill
try cleaning the pulleys buy a good belt (gates) install belt and make sure you have good belt tension
Posted on Mar 18, 2011
I have no belts on this drill press and can't seem to find the size or length of them
You don't give make and model, but a quick look shows these links. For length, pull string tight around the pulleys with slipknot. Use the pulley release lever to remove the string, cut it and pull it taught. Measure the length and subtract a half inch. With a make and model, it would be easy.
http://www.bing.com/search?q=drill+press+drive+belts&qs=n&form=QBRE&pq=drill+press+drive+belts&sc=0-16&sp=-1&sk=&cvid=26514024d4d84952af826318901d12f9
Sep 12, 2015 | Drills
Hi I have a peerless pedestal drill press model #1516f. I cannot find the replacement belt sizes for the 2 belts? Can anyone help? Cheers Jason
hi jason try going to a car fan belt specialist ,, one that stocks many sizes..take your old ones in to match them with.. as an example search on line as i don't know where you are i can not give more specific info on location.. as an example this web site http://www.totalrubber.com.au/
or try repco car spare parts
Rubber Hose PVC Hose Rubber Matting
i assume your belt is an "A" size
regards pete
Feb 26, 2015 | Drills
Why alternator belt making noise specially when engine is cold?(on 206 1.4)
noisy alternator belts generally indicate out of tension limits or old and cracked and in need of replacement. Inspect the belt and check for cracks ,frayed edges and loose. As the belt heats up it tends to grip better but the problems will still, be there.
Oct 31, 2014 | Peugeot 206 Cars & Trucks
I have an old Guardian Power floor model drill press and do not know how to change belt positions to change speed. help please.
See the picture below. The small red circle shows the locking screw on the right side of the drill. There is another locking screw on the left side of the drill. Loosen them both a half turn. The larger red oval is the handle to pull the motor closer to the spindle, thereby loosening the belt. Once loosened, it is easy to move the belt. Then use the handle to push the motor back, which tightens the belt. Keep pushing on that handle with your right hand while you tighten the locking screw on the left side of the drill with your left hand. Once you have that tight then tighten the right side locking screw.
Good luck! I hope this helps.
Jul 12, 2012 | Drills
Changing speeds on Powermatic Drill Press
Katie,
Refer to the picture below. Loosen the locknuts (the one on the right side of the drill is shown, there is another on the left side). Use the lever to move the motor toward you, thereby loosening the drive belt(s). Open the top cover to expose the belt(s) and sheaves (most people incorrectly call them pulleys). You might have one belt and two sheaves, or you have two belts and three sheaves. The drill will go fastest when the belt is on the biggest motor sheave and the smallest sheave on the drill spindle. Of course the opposite sizes apply for the slowest speeds. Make sure the belt uses a pair of sheaves that are at the same height as each other (the belt has to stay in one plane). Now tighten the belt(s) by pushing the lever pretty hard away from you, and while holding it with your right hand tighten the left side locknut with your left hand. Now tighten the right locknut. Close the cover. ----- OK, so now you know how to CHANGE speeds, what about drilling glass? This can be tricky. You must use a pretty slow speed (maybe the slowest, depending on the size of hole you are drilling. And you must keep the spot you are drilling flooded with water to keep the glass cool. And you must apply pretty gentle pressure. And the use of a drill bit intended for drilling glass helps a lot. And don't try the first hole in something expensive! Practice on something disposable first. Take your time. AND WEAR SAFETY GLASSES!
Jun 15, 2012 | Powermatic Drills
Need a product number for a Dayton model 3Z235 drill press variable speed belt. Can you help?
Gates 5M1150 Polyflex V-Belt 89021150
This is for a drill press with stepped pulleys. I wouldn't call it a variable speed belt, but it is the belt that I am getting for my Dayton 3Z235 drill press.
May 12, 2011 | Garden
Need part number for belt for dayton drill press #3z918f please
If you have the old one, take it to auto parts store and they can size it for you.
Oct 06, 2010 | Garden
What makes a drive belt on a dodge nitro frey and crack
All belts eventualy crack and fray with use. This is normal. Heat and oxidation cause this.
Also, if the pulleys are misaligned, fraying may occur. Or if a pulley is locking up a little bit.
Jul 03, 2010 | 2007 Dodge Nitro R/T New Cars
Oct 25, 2009 | Drills
How to change belt
THERE IS A LITTLE HANDLE AT THE SIDE
PUSH IT UP THEN TAKE OUT THE OLD ONE
AND REPLACED
May 10, 2009 | Delta DP350 Shopmaster 1/3 Horsepower 12...
Drills Logo
200 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
