Question about Water Water Heaters
What do I do if the Therm x tell is pulling away from the water heater?
  • Mary Oliveau Nov 26, 2014
    Hi Mary Blank, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Scholar:
  • 94 Answers
What kind of water heater is it and is it electric or gas? Also how old is it?
Posted on Nov 26, 2014
My bocsh 830es water heater will be running normal then will kick into a A3 mode no more hot water
Check for a green wire near the top right of your machine. It would loop back to itself with a little black heat shrink on it. This should be far away from the heat exchanger. if its near it, I would recommend pulling it out of the wire clips, and relocating it to behind the control unit on the right side of the machine. Keep it away from heat....its a resistor, and will pop random A3 codes if the heat increases its resistance. Reset your code and you'll be good to go.
Jan 01, 2014 | Bosch Therm 830 ES NG Internal Tankless...
I'm getting an er3 reading on my water heater tank , what does that mean
It tells you that your water heater called for heat for more than an hr and never got hot enough to meet the demand.
CAUSES
-bad sensors
-no hot water from boiler
-bad thermal transfer
-low delta T across water heater
Apr 21, 2011 | Amtrol ST-120V-C THERM-X-TROL ASME...
Burner lights for a couple of minutes and then goes out. it keeps repeating this every 15 to 20 minutes. is it the gas valve, the circuit board or what?
More than likely the thermostat, and/or ECO. When you drop cover down look for Therm, and ECO marked on a foam piece under pressure relief valve area. Shut ignition off first, then Carefully pull that foam piece off after removing spade connectors from THERM. Make sure little disc (thermostat) is up against tank good and making good contact. There should be a spring and clear retainer holding it up against the tank. If all looks good there, pick up another thermostat and replace it. They usually come on a card with both THERM and ECO and aren't too expensive. Don't mix the 2 up when changing them, as they are set at different temperatures.
Jan 09, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
Armitrol boiler mate hot water maker has code er3 and we have not hot water. can u tell us what that code means?
It tells you that your water heater called for heat for more than an hr and never got hot enough to meet the demand. multiple scenarios can cause this
CAUSES
-bad sensors
Dec 02, 2010 | Amtrol ST-120V-C THERM-X-TROL ASME...
My Amtrol Therm-x-trol tank has dropped 6 to 8 inches since it was installed, and a few drops of water are coming from the washer where is attached to the water heater. It is very heavy now. Could it be...
Sounds like the internal diaphragm has ruptured. The tank should be replaced immediately. You should disconnect the electrical power to the water heater and close off the incoming water supply to the heater. Open a HW faucet to relieve the pressure and remove the tank. Be careful cause you are going to get wet. Replace with a new tank.
Sep 30, 2010 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
I have a ER3 message. How can I fix this
CAUSES
-bad sensors
Mar 15, 2010 | Amtrol ST-120V-C THERM-X-TROL ASME...
Caluclation
This requires a little math....
BTU - amount of heat it takes to raise one pound of water 1 degree F.
I gallon of water = about 8.54 pounds
91 gallons of water = about 777 pounds = 777 pounds x 70 degree rise = 54,390 BTU.
1 Therm (what the gas company measuers in) is 100,000 btus
1 therm costs about $.45 (45 cents) depending on where you are
54,390/100,000 x $.45 = about $.25 per hour
This cost can vary somewhat depending on the inlet water temperature, gas cost, and the efficiency of the hot water heater
Apr 08, 2009 | Water Heaters
Therm-x-trol st-12 leaking
Never seen one leak other from the seam or the top or bottom.
Mar 14, 2009 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
Water Heaters Logo
46 people viewed this question
Top Water Heaters Experts
freddyfox
Kenneth Walker
Are you a Water Heater Expert? Answer questions, earn points and help others
