Question about Vizio M3D650SV 65-inch 1080p 3D LED TV Refurbished M3D650SV
My TV don't have no power
TV don't have no power on,I replace new power supply ,but still have no power on or any light or sound on. M3D650SV VIZIO
    Genius:
  • 1,003 Answers
Replace the main board not the power supply!
Posted on Nov 26, 2014
  • 5 Answers
READ THE TROUBLE SHOOTING SECTION OF THE OWNERS MANUAL
  • 37 Answers
Start from your power outlet, check.your plug fuse, if it's fine then try your internal fuses if it has any, they are usually clear tubes. Failing that replace main power board.
    Problem Solver:
  • 19 Answers
There is a small rectangular transformer which gets busted after few years. Find it and replace it. Very few mechanics do this kind of work. There will be copper coil wrapped ....if u don't know what to look for.
Testimonial: "How do I find out where is the transformer is locate.?"
  • 20 Answers
Have you tried turning the power point on?
ginko
  • 19396 Answers
SOURCE: 42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
Posted on May 04, 2009
  • 92 Answers
SOURCE: vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
Posted on May 20, 2009
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
kidsasuke
  • 121 Answers
SOURCE: no sound and no picture
It may well be the power supply. Filter capacitors have a nasty tendency of blowing, as well as voltage control ICs. If the filter blows, you end up with a shaky DC signal that can't be effectively used by digital components (which make up about 80% of modern TV circuits). If you're within warranty/exchange then go for the manufacturer. If not, and you're comfortable with opening these things, then you can carefully (after unplugging and allowing it to discharge) take a glance inside. If any capacitor(s) are visibly blown out, then there's your problem.
Posted on Jun 03, 2010
SOURCE: Vizio 42 LCD turns on but no picture or sound
32 in vizio turns on but but no picture only blue screen and cant turn channels up or down
Posted on Oct 21, 2010
My vizio m3d650sv turns on and plays fine for any where from 5 mins or maybe even an hour. And then makes a loud popping noise and the screen goes all distorted and shuts it's self off. I can immediately...
Vizio 0500-0507-0920 (DPS-353AP) Power Supply for M3D650SV are the part numbers. The actual part number is on the board. The item is not in stock and may be obsolete.
Jul 19, 2017 | Vizio Televison & Video
M3d650sv t con board half screen out
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Nov 22, 2016 | Vizio M3D650SV 65-inch 1080p 3D LED TV...
How can I connect VCR?
Hi if U just want to play videos the easy way is to connect 3 RCA VIDEO CABLES colour coded red white yellow yellow is picture red & white r left & right audio from the output sockets of VCR to input of TV ..then set TV to AV INPUT good luck
Mar 08, 2016 | Vizio M3D650SV 65-inch 1080p 3D LED TV...
Has sound. Why did screen go black?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
Dec 24, 2015 | Vizio M3D650SV 65" 3D 1080p LED-LCD TV -...
Why do i have vertical lines on my vizio ?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 01, 2014 | Vizio M3D650SV 65-inch 1080p 3D LED TV...
Can't connect vizio smart tv with belkin n750 dual band router
In your TV's menu there should be a wireless setup. You didn't supply the Model of the TV. Here's a manual for a Vizio: http://store.vizio.com/documents/downloads/hdtv/M3D650SV/1185QSG_M3D650SV_B.pdf
Dec 10, 2012 | Computers & Internet
No power, tried plugging in different outlet
When it's plugged in is there a light anywhere on the T.V. that is on?
May 04, 2011 | Vizio 42 in. LCD TV
Vizio M3D650SV 65-inch 1080p 3D LED TV Refurbished M3D650SV Logo
144 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
