Question about Cycling
I want to order a hose for the Airstrike Bell 1900 bicycle floor pump
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Resistance when I try to pump, no air enters tire.
Make sure that the end isn't bent and connects to tire good. You will here a little air escaping if hooked up correctly. If that isn't it make sure there is no obstuction in the air line. Release relief valve and let air out.
It could just be the end, your connection to the tire, or at worse a bad pump.
May 29, 2016 | Bell Airstrike 1000 Gauge Frame Pump
Airstrike Bell 1900 , the hose is ripped. What do I need to do? How to replace it?
Always a good idea to contact the manufacturer: The Bell Garage or a bike shop may be able to help. The pump may accept a different brand hose.
Sep 13, 2013 | Airstrike Bell 1800 Floor Bike Pump
I have a "Judge"
Sure, A new O-ring and a little grease, the same you use on your bearings to make a good seal.
Without seeing and feeling the actual pump, a sloppy O-ring will cause a loss of pressure.
You will also want to check the head and make sure the rubber still makes a seal around the tube valve, if not then that will need to be replaced as well.
Mar 20, 2011 | Airstrike Bell 1800 Floor Bike Pump
The tubing that leads from the pump to the tire is broken off right at the base? Can it be repaired? HOW?
Most Bike Shops carry repair kits for common pump brands and I wouldn't be surprised if some cross brand parts would work. eBay has many for sale.
"floor pump hose"
You might even be able to go to an automotive supply store and get some pressure hose yourself real cheap.
Mar 13, 2011 | Airstrike Bell 1800 Floor Bike Pump
How do i remove a broken needle stump from the pump?
I un-wound a paper clip and formed it into the shape of a the number "1" with one side being about a 1/4" and the other side being the remainder of the length of the clip. I covered the 1/4" length in super glue and inserted it into the hole where the needle had broken off. I let the glue set for 10 minutes. I was than able to unscrew what was left of the needle using the long end as my handle/leverage point. It worked perfectly and unscrewed in seconds.
Mar 03, 2011 | Airstrike Bell 1800 Floor Bike Pump
Need new hose , where can I find this for airstrike 1800 model
Has anyone found a replacement hose for the Airstrike 1900? And/or instructions on how to replace it?
Jun 15, 2010 | Airstrike Bell 1800 Floor Bike Pump
How do I use the Bell AirStrike Digital Floor Pump
The gauge measures three different amounts. Be certain that you have it set to PSI. Then set the target PSI. The green LED indicator will then flash when you are within 5 PSI of your target and will flash constant when the target PSI is reached.
Jan 02, 2010 | Airstrike Bell 1800 Floor Bike Pump
Should I add oil to the top opening (where pump shaft enters same) if it's losing air out this opening when I go above 40 psi?
It's not the opening that is the culprit. Those bell bicycle pumps have an o-ring for a piston seal, and this ring needs oil from time to time. The oil that should be used is as thin an oil as you can find, something like 3 in 1. You should disassemble it to check to see if the plastic piston isn't cracked. (They do crack from time to time, and might be what is wrong with your pump.)
Nov 25, 2009 | Airstrike Bell 1800 Floor Bike Pump
Bicycle tire pump won't pump.
If you can? unscrew the two pieces of the pump clean and oil it. W/D40 works pretty good.
Apr 24, 2009 | Airstrike Bell 800 Frame Mount Bicycle...
Cycling Logo
105 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
