My pace hd DVR is all hooked up to my Philips tv, all things work as they should. However, on every channel a message displays, "One Moment Please, your service has been temporarily interrupted. It should be restored momentarily." The kicker is its already been an hour. I just set this up why is it not working?
  • 139 Answers
Check cable that brings signal into DVR then reboot DVR,
Posted on Nov 26, 2014
jerryg50
  • 1689 Answers
SOURCE: TV only will play HD Channels
This must be the setup for your TV box. Contact the support for your TV box.
Normaly, the TV should auto select the proper operation mode.
Jerry G.
Posted on Jun 28, 2008
  • 1779 Answers
SOURCE: I can only get 2 channels on my TV hooked to Cable
Please do the Auto Channel Program once again and let me know.
Posted on Aug 28, 2009
JT92677
  • 13 Answers
SOURCE: I have a VIZIO LED/LCD VF551XVT hooked up to a
I have the same set, same problem with one of my MOTOROLA boxes, but not with another. I have a SONY TV that works fine with this new MOTO box, but the new VIZIO does not. The audio is coming through the HDMI cable just fine, and the fact that it works when you cycle power on your TV means it's the SYNC between the TV and the BOX. I have the identical problem and am taking back the MOTO box for another one. I spoke to VIZIO for about 45 minutes trying different things. They think it's the MOTOROLA box, COX (my cable company) thinks it's this particular box, who knows.
Posted on Feb 04, 2010
SOURCE: Our new Pace HD dvr
Mine kept doing this
Posted on Oct 09, 2010
budmrtn
  • 11361 Answers
SOURCE: Comcast TV cable adapter problem:
You can call COMCAST to have them do the reset for you or you can call the comcast automate setup on the phone, just make sure to have the serieal numbers and the MAC address. I had to do on my a couple times in about every 3 months, you can also have bad box also.
I guess you already try another box to this same cable outlet?
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Nov 10, 2010
The other day my plasma was on and everything was fine. Connected to it is a charter DVR. Suddenly the picture and sound went out. I have a PS3 also hooked up to it and it displays and sounds fine. I...
Most likelly it is your DVR that has a problem. Their are a lot of issues with those DVR's from the cable or satellite companies. I would recomend swapping it out.
Jun 08, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
I have surroundsound. I have dish network with hd dvr. I have a sony bravia hd tv. I have a dvd player, and cd player. I have a magnavox dvd recorder. I want to record from my dvr to my dvd recorder. ...
To get the functionality you're looking for you'll need to to take the cable running from your DVR output and connect it to the input on your DVD recorder. Next you want to connect a cable from your DVD recorder output and connect it to your TV. If this is an HD set up you want to use HD Cables for all of the connections.
Daniel Busa
DISH Network Customer Service
Jan 03, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a Philips DVDR 3575H. using Comcast's
Try this set up-
Use an RCA audio/video cable for this set up (Yellow/Red/White).
Connect from the Video out (Yellow) connection on the back of the cable box to the Video in on the back of the DVR.
Connect the audio (Red/White) cables from audio out connection on the back of the cable box to the "Audio in" on the back of the DVR.
This should still get you a decent picture but not a true HD picture for your recordings.
When you set the timer to record set it to record either E1 or E2 depending on which input you connected the cable box to and ensure that the cable box is tuned to the channel you wish to record.
*** NOTE: If you keep the HDMI cable connected as you have for the cable box and watch normal TV through the HDMI input on the TV you will get HD programming for your general viewing but still have the option to record with the DVR at a lower quality. ***
Good Luck and please rate this solution....
Jan 07, 2010 | Philips DVDR3575H/37
61A61 TV IS WILL ONLY PICK UP ONE CHANNEL #66 AND NOT CABLE INPUT
Cable companies are slowly but surely reducing the channels you can get without a digital box, which they will supply. You will need to cantact them and rent a HD cable box or converter from them that will work with your displays built-in tuner. However, if your display is HD compatible, then I would just asked your cable company for and non-DVR HD cabe box and connect it to your display with component cables....
May 30, 2009 | Toshiba 61A61 61" Rear Projection...
Can't record from Cable DVR
Here is a diagram of an option for you to hook up a cable box, to a VCR, then a TV. I took out all the other things and kept it simple. You can always hook up more later. The cable should go straight into the DVR as it is, then hook the yellow A/V cables from the DVR/cable box output to the VCR input then anther set of A/V cables from the VCR out to the AV1 on your television.
You will have to select the A/V input on the Go Video, then you should be able to see a picture. The only drawback on this option. You will have to watch what you record.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 30, 2009 | Televison & Video
Channel displaying on Samsung 32"LCD TV
Most remote controls have a "display" button. Pressing that is what gets that channel number on the screen. Try pressing it again and the display should turn off. On some brands the display may cycle through various combinations (channel number only, channell and time, etc.) before it goes away, so it may take more than one press of the button.
Dec 03, 2008 | Samsung 32 in. LCD Monitor TV
Inputs for HD on tv
Do you have the composite cables(red, blue, green) hooked up too the back?
Jan 09, 2008 | Philips Magnavox 51MP392H Rear Projection...
"Not supported Mode" message
Hook up the component cables on the tv and the dtv box
go to set up on the menu select HDTV or display and deselect all of the 480i and 480p and in some cases also the 720 and only select 1080i to be display. you can then hook up your hdmi cable again and it shoud be supported. Let me know if that works.
Nov 18, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
