Question about Cameras
"error" message has replaced the image in many of my thumbnail images and the photo will not open
Is there a way to recover the images.
    Scholar:
  • 62 Answers
Probably the images are not lost and do not need to be "recovered". Sounds like something happened to interfere with the operation of the program that knows how to display those images. Perhaps some other software was installed that messed up the program in question, or messed up the "file associations" (the thing that tells the computer that a particular program is used to work with a particular kind of file). I would try reinstalling whatever software program you had been using to view the images in question, i.e. before this problem occurred, when you used to open one of the photos, what program was it that appeared with the photo? That's the program I would reinstall.
Posted on Nov 26, 2014
Testimonial: "I'm afraid that if I uninstall and reinstall the Photofunstudio software that I will lose all the images in the process. Maybe this is not a risk, but I don't want to lose 5 plus years of images!"
  • 2 more comments
  • martinmarty Nov 26, 2014
    Understandable. How about this: Right-click on one of the image files that is having the problem and look for option "Open with" and see if Photofunstudio is one of the choices. If so, select it, if not, try "Choose Default Program" and then look for Photofunstudio. You may have to browse or click Other Programs to locate Photofunstudio. You may also find that you can select some other program to open your files, which would demonstrate that the files are indeed intact and just the software to view the files is messed up. Also please note, in my original response, I never said Uninstall, only reinstall, i.e. install again over top of what's already there. I do understand your hesitation. You are right not to do anything that would delete the folders containing your image files.
  • Stephen Felts
    Stephen Felts Nov 26, 2014
    Many thanks to all for giving their time and expertise.
  • Stephen Felts
    While in Photofunstudio 8.1 some of my images added recetly display ok. Others have Error in the tile where the picture thumbnail should displayj. Other tile on the same screen display pictures ok. When Ieither right or left click on a tile saying Error it dsplays below the tile the image number and "file type still picture' I just don't know where to go from here.
    The only thing I could find was:http://answers.informer.com/13314/some-p... THAT suggests that you should attempt to determine if the image files still exist in the same locations (Windows folders) outside of Photofunstudio. If they have been moved, perhaps they can be imported from their new location. If they are gone, where have they gone and why and do you have backups? Unfortunately, it is usually a hard-learned lesson to learn to make backups. I hope that nothing has happened to your PC recently to effect the integrity of the file system (you would probably be seeing other problems as well). Is there any chance that some automated (or manual) "cleanup" software moved, deleted (or even compressed) some folders containing your picture files? If I were you, I would try to determine which Windows folders were being used to store your files, and then use Windows Explorer (not Photofunstudio) to see if those files still exist, or find out where they have moved to. You may find that all of the files that now have an error were stored in the same folder and that folder was moved or deleted. If your files have been deleted or if the file system has been corrupted, this is most likely going to come down to what kind of backups you have available. Let's hope maybe your files have just been moved. What version of Windows do you have? Unfortunately Windows' file Search facility is terrible in the last couple releases, but you may be able to use it to find your files.
    New Friend:
    Problem Solver:
Sounds like some incompatibility issue between the images and the program which you have chosen to open these images have caused the problem. I also would recommend to either use the right software or re-installing the software you are using to open the files.
Another solution could be to recover the images using a recovery software. You can go for retrievephotos.com
Posted on Dec 19, 2014
  • 84 Answers
Is this happening in a cd or dvd? or on a drive? if it is a cd/dvd wrongly written data is the reason, you will see the file names etc and when you open it you get the error message. you have to rewrite if you have the original files. even if you use a data recovery software like iso buster, it will go through the motions of recovery, raising false hopes with the long time it takes and then you still have these empty files. you can try isobuster with the drives, you may recover- no guarantees. that error may have happened during partitioning? easeus may help.
Testimonial: "The "error" message appears in the thumbnail which should show the picture. This is on my desktop using Photofunstudio 8.1 software. where many of the affected images have been stored for years and were always accessible until now"
SOURCE: error messages "cannot display image" or memory card error, etc.
Try a different SD card to start.
Posted on Dec 26, 2008
SOURCE: unidentified images
I have the same problem with my Canon Powershot SX110IS. images dissapear with the notation "unidentified image". I brought my camera in to a local camera shop, and they were able to save the lost images. They told me I had an inexpensive, low quality memory card that is causing this problem. I upgraded to a high quality one and haven't had the problem since.
Posted on Feb 13, 2009
SOURCE: Problem downloading image
One of the images did not finish writing to the card properly (usually in the last 4 or 5 images, or the last video)
Try selecting all but the last 10 images and chose import selected. This should work. Then delete those from the card.
This bit is important
Put the card back in the camera (if it's in a usb reader) if not, disconnect the camera and put it into playback mode. View the remaining 10 images/video.
Try re importing and it should work fine! I've had this problem since ilife '09 and this method always fixes it. It seems to happen when the cards get full. Try not to completely fill a memory card and you should not get the problem.
Posted on May 31, 2009
  • 81 Answers
SOURCE: Is it possible to recover my pictures?
I have had success with this... Download the program
http://www.asoftech.com/apr/
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
Posted on Nov 07, 2012
  • 200 Answers
Lost movies can be recovered if your data are not covered, and it's not a hard thing now .
And this guide will help you:
http://www.goshareware.com/resource/recover-deleted-videos.html
Posted on Jul 16, 2013
Damaged jpeg images
you might need to download some revovery software
http://download.cnet.com/data-recovery-assist/3000-2248_4-75104099.html
Data Recovery Assist allows you to recover lost, deleted, and formatted data on local and network drives, as well as removable drives. Data Recovery Assist supports Hard Disk, USB Drive, SD Card, MMC Card, Sony Memory Stick. Data Recovery Assist can recover deleted files emptied from Recycle Bin, lost data due to partition damaged, software crash, virus infection, unexpected shutdown or other unknown reasons. Data Recovery Assist provides a comprehensive data recovery solution for computer users to recover lost data. Data Recovery Assist Supports FAT16, FAT32, NTFS and other file system. Data Recovery Assist Supported all major file types, include text, exl, pdf, bmp, exe, html, jpg, avi, mp3, email, word and so on. You can preview deleted file before recover it. Operating System Support: Windows7, Windows Vista, Windows XP, Windows 2003 and Windows 2000 Release Note: 2009-10-28 Add deleted files written-over caution,It's very important! 20010-01-01 Update skin and support vista and win7
Mar 18, 2012 | PNY 4GB Secure Digital High Capacity...
I have a Compact Flash card of 512mb (CF card) i use this card in my nikon D70, i went to my friend house and tried connection my camera to his comp to download image, but my friend machine was infected by...
Guide to recover deleted photos from Nikon D70?
Connect Nikon with PC
Using a USB cable or putting SD card into an SD card reader to connect Nikon with Computer.
Scan Nikon d70- Running the Nikon Photo Recovery,you can choose Nikon media drive and click "Start Scan" for scanning
Recover deleted photos
After scanning, you will see all recoverable media photos and videos with file type. At last, click "Recover" to recovering deleted Nikon D70 photos.
This Photo Recovery also can recover all photos files from Nikon D3100 like JPEG, BMP, TIFF, GIF, etc. Support all Nikon camera.
For full details please refer to Nikon D70 Manual.- https://guideusermanual.com/product-name-d70-manual&po=4425&lang=English
Mar 28, 2017 | Computers & Internet
An 'error' message kept on appearing when scrolling through images. The next day all the images were deleted.
If you are using a memory card, take no more pics until you've recovered the photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that are available to help you recover your photos. This blog article reviews and outlines several of the better ones. AFTER you've recovered your photos, format your card IN YOUR CAMERA to prevent this from happening again.
Aug 17, 2010 | Fuji FinePix F10 Digital Camera
How do I recover images that I accidently deleted?
Yes, with a good image recovery software like asoftech photo recovery, it will be an easy job to recover deleted images from camera's memory card. follow the instructions here
http://www.asoftech.com/articles/how-to-recover-deleted-photos-from-camera.html
Dec 19, 2009 | Canon PowerShot A550 Digital Camera
No picture on thumbnail
I have had the same issue. There is some setting up on top that addresses this but I do not have the patience to look for it.
Sep 06, 2017 | Microsoft Digital Image Suite 2006 for PC
Unidentified images
You think you can try photo recovery software to see if you can rescue the lost photos or movies, here are some you may rely on. Both programs can also recover videos and music.
Photo Recovery Software (for Windows)
Mac Photo Recovery Software (for Mac OS X)
Be careful: Before your pictures and videos are recovered, do not attempt to save more files to the memory card in case the original files(your pictures) are overwritten.
Jun 16, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Cannot View Uploaded File
try opening the photos with any other viewing software you have - paint, windows picture and fax viewer to name but 2. If you get the same results then the files are probably corrupt, and the probability is that your memory card could be causing the problem, try another card and see if pictures you take can be viewed. Try uninstalling and reinstalling the camera and the olympus software, it just might help. If this doesn't work please post again and we could give you some info on software for recovering corrupt and deleted files. Hope this helps :)
Mar 17, 2007 | Olympus Stylus 710 Digital Camera
How can I print multiple images on one page using the direct print feature?
Follow these steps: 1. Connect the camera to the printer. 2. Turn on the printer. 3. Turn the Mode dial to Playback mode and turn the camera on. 4. Press the (+) button on the camera. 5. Press the up or down button, choose Select images, then press the OK button. Note: If you see the message “Use previous print order selection?” select No, then press the OK button. 6. The images display as thumbnails. Select the first photo to print using the < or > button. 7. Select the number of copies to print using the up or down button, press OK. The screen displays the print settings and the number of copies selected. 8. Press the MENU button to return to thumbnails. 9. Repeat steps 6, 7, and 8 to select additional images. 10. After you select all the images to print, press the MENU button. 11. Press the up or down button to select Print an Album. 12. Select the number of photos per page using the < or > button, then press the OK button. Note: To determine the maximum number of images your printer can print per page see the table below. If you select more images per page than the printer supports, the camera will display the error “This function is not available”.
Sep 13, 2005 | Epson PhotoPC L410 Digital Camera
Cameras Logo
63 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
