I'll try to solder all of loose contact but was no happen and the picture become vertical line like a pes of peper
  • 20 Answers
Pay sum1
Posted on Nov 26, 2014
    Sergeant:
    Champion:
  • 282 Answers
You probably caused a solder bridge and shorted something out. Go over all of your solder points and see if you can spot it. If not then you will need a professional to fix it.
Good moring ! Ma'am or sir I'm repairing my TV set sharp 21V-W70M the problem is green picture, ill try to changes the degosing coil, and then try to testing to open to picture to become...
If this were a degaussing issue then I would expect to see red, green, and blue but with distortion. That isn't what you're reporting. As has been suggested already, you likely have a component area (like vertical or horizontal sweep) that is malfunctioning because of a failure. The failure could be system voltage oriented or a component board or combination of both. Here is the bottom line, how much are you willing to spend to fix an older TV? If you aren't willing to spend a few hundred dollars then consider why a repairman would want to work for less? By the time a technician puts the set on his bench, opens it, and does preliminary system check you've got an hour invested. If a system power voltage failure caused other components to fail then the problem along with cost to repair quickly escalates.
Nov 26, 2014 | Sharp Televison & Video
I have half a picture or no picture at all. Other TV's in house are fine. Friend said this minght be a chip. Picture will come on but then goes away. Thanks!
you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board ( also on CRT circuit board ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or abnormal width, or rolls etc .so solution is .....TV main board & CRT circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that.in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again ................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer & just ask him to resolder joints .............
Aug 21, 2011 | Sony KV-27S40 27" TV
Model 32A40. Picture periodically reduces to one narrow horizontal line. Becoming more frequent. Does this mean picture tube is going. What might potential repair cost be? thanks in advance.
No it is not a tube problem .............hit your TV on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board ( also on CRT circuit board ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or abnormal width, or rolls etc ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears normally for some time............so solution is .....TV main board & CRT circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again ................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer & just ask him to resolder joints .............iam from bangalore - computers, laptop, printers, etc ) ----- good TV service engineer will charge less .........
Aug 06, 2011 | Toshiba 32A40 32" TV
HORIZONTAL LINES THAT MAKE THE PICUTRE SMALLER AND SMALLER FOR A FEW MINUTES AND THEN IT STOPS AND THE PICTURE IS FINE. THIS ONLY HAPPENS WHEN I TURN IT ON WHEN THE TV IS COLD. THANKS
hit your TV on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board ( also on CRT circuit board ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or abnormal width, or rolls etc ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears normally for some time............so solution is .....TV main board & CRT circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again ................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer .............iam from bangalore - 09986222774 - sathyavijayasarathibabu@ymail.com ( computers, laptop, printers, etc ).
May 22, 2011 | JVC AV-27820 27" TV
Hi I have a 27 C240 Sharp tv that the picture rolls vertically on. If I hold the channel change button or any button while in menu mode with the remote, it shuts off and will only come back on after...
hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board ( also on CRT circuit board ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or abnormal width, or rolls etc ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears normally for some time............so solution is .....TV main board & CRT circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again ................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer .............iam from bangalore - 09986222774 - sathyavijayasarathibabu@ymail.com ( computers, laptop, printers, etc ).
May 13, 2011 | Sharp 27C-240 27" TV
JVC AV32920 Horizontal black lines running thru picture. Picture condenses to a single horizontal line in the middle of the screen, audio is fine. When I bang the sides of the set (old fashioned manual...
hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board ( also on CRT circuit board ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or abnormal width, or rolls etc ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears normally for some time............so solution is .....TV main board & CRT circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again ................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer ........good TV service engineer will charge very less ...absolutely there is no need for new TV........if soldering joints are properly soldered then your TV will work for 1 more year ( minimum )......iam from bangalore - 09986222774 - sathyavijayasarathibabu@ymail.com ( computers, laptop, printers, etc )..............
May 12, 2011 | Televison & Video
I have a 36inch panasonic tv thats not a flatscreen its bulky. after a few mins of watching tv or playing games the screen gets black cept for this horizontal line with the picture in there i gave it a...
hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board ( also on CRT circuit board ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or abnormal width, or rolls etc ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears normally for some time............so solution is .....TV main board & CRT circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again ................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer .............iam from bangalore - 09986222774 - sathyavijayasarathibabu@ymail.com ( computers, laptop, printers, etc )..............
May 12, 2011 | Panasonic CT-36D20 36" TV
After we have switched the TV on a dark line appears around the edge of the whole screen and then it gets bigger and bigger making the picture smaller and smaller - is there a simple solution please
hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size or abnormal width,etc ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting monitor lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again ................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer .............iam from bangalore - 09986222774 - sathyavijayasarathibabu@ymail.com ( computers, laptop, printers, etc )
Apr 25, 2011 | Panasonic Televison & Video
Symphonic WF27F4 (an old tv??) How to restore the video which is sometimes just a horizontal bar or line, and if you hit a good wallop it may recover the picture for an hour, a day, or a week until it...
hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board (also on circuit board that is fixed to CRT TUBE ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears or rolls ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Apr 19, 2011 | Symphonic ST427FF TV
About 2 inches of the top of my screen won't show. Sometimes it will turn into a line that runs through the center horizontally. If I hit it it will go back to normal except still missing the top 2 inches
hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again (2inch on top will also gets solved )................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Apr 18, 2011 | JVC Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
