Question about Garden
The brake pedal on my Viking MT880 has broken off at the end of the stem. I cannpot now start the mower as the brake needs to be on for the ignition to work. Where do I get a new brake pedal/ lever
The brake pedal on my Viking MT880 has broken off at the end of the stem. I cannpot now start the mower as the brake needs to be on for the ignition to work. Where do I get a new brake pedal/ lever and is it hard to repair? Tony F
    Sergeant:
    Champion:
  • 282 Answers
See if you can get someone to arc weld it together.
Posted on Nov 26, 2014
    New Friend:
  • 52 Answers
Which country are you in?
  • 109 Answers
SOURCE: engine stalls when clutch/brake pedal is released
Under the seat, there is a operator presence switch, if this switch fails, the mower will shut off when the brake is released, or put in any gear.
Posted on Apr 23, 2009
  • 115 Answers
SOURCE: engine dies when brake is released
check if the switch for the blades or the brake is not releasing.
Posted on Jul 04, 2009
mowerman1857
  • 389 Answers
SOURCE: I have a model 42515X92 Murray mower with two
You can go to www.murray.com/manuals/ , put in your model number and download the manuals. As for teh brakes, there is a 1/2 inch nut in the center of the brake caliper that you tighten or losen to adjust the brakes. Put your tractor in neutral on a flat surface, tighten the nut just until you can no longer roll the tractor freely, stop as soon as you reach this point then back the nut off 1/2 turn and you should have good brakes again.
Posted on Sep 14, 2009
  • 13 Answers
SOURCE: ferris zero mower;eng.dies when releasing brake or control levers
Check seat SW.
Posted on Sep 29, 2009
Testimonial: "Thanks, I've had problems w/that sw. before,I'am going to run an ohms test on it. That tells me where to start."
braintrust
  • 62 Answers
SOURCE: after replacing the belt, new pulleys, and bolts,
sounds like the linkage to your blades, check your lever, to make sure its working right may need some grease, it may be sticking and not fully engaging, or doing its job when its supposed to
Posted on Oct 27, 2009
How to make mower stop when clutch/brake pedal depressed
Depending on the model and manufacturer of your mower, but it seems like the brakes are the problem.
I have a Murry and it has one disk brake on the rear wheel shaft. The master mechanism for this disk brake needed to be cleaned of dirt and grass clippings. In my case, this helped but brakes only 50% effecient so I use reverse when on an incline.
Mar 25, 2016 | Cars & Trucks
The only way my brakes lights will go off is to take the fuse out. They stay on all the time. Even with the ignition off. Help
THE BRAKE LIGHT SWITCH IS FAULTY OR OUT OF ADJUSTMENT LOOSE FELL OUT THE BRACKET.CHECK UNDER THE DASH WHERE BRAKE PEDAL ARM IS YOU SHOULD SEE A PLUNGER STEM LIKE SWITCH TOUCHING BRAKE PEDAL ARM.IF NOT SWITCH FELL OFF SUPPORT BRACKET.IF BRAKE SWITCH STILL IN PLACE MORE LIKELY BRAKE LIGHT SWITCH IS FAULTY.
Aug 29, 2011 | 1995 Nissan Pickup
Had a defective brake light switch replaced on a 1999 Escort SE. A friend managed to removed the old one ( had to kind of twist it out) but was too fat to fit under the dash to install new one. I had a...
WEll, if the switch were to be too far down, essentially pressing on the brakes, this can happen, release the brake light switch and allow the pedal to come to it's normal stop, then adjust the switch for that position.
Aside from heat of brakes, other damage very unlikely.
Sep 06, 2010 | 1997 Ford Escort
Riding mower will not start or brake
The two are seperate issues. The switch on the brake pedal is on the frame and is accuated by the pedal, not the rod or spring. If you are not confident with a voltmeter or test light, then the Sears tech will be the fastest thing to mowing again.
Nov 08, 2009 | Craftsman Garden
Craftsman garden tractor quits when brake released.
It sounds like your throttle cable is caught up with the brake pedal.
Oct 01, 2009 | Garden
Rear lights stays on but the ignition is off
CHECK BRAKE LIGHT SWITCH.IT COULD BE OUT OF ADJUSTMENT IT COULD BE TOO FAR FROM BRAKE PEDAL.LOOK AT BRAKE SWITCH ON BRAKE PEDAL.THE BRAKE SWITCH HAS A STEM LIKE SWITCH.THE STEM SHOULD BE TOUCHING PEDAL ARM.IF NOT ADJUST IT SO SWITCH WILL TOUCH THE PEDAL ARM.IF ALL IS GOOD. THE PROBLEM COULD BE THE COMBINATION SWITCH.
Aug 04, 2009 | 1995 Toyota Tacoma
My Viking 5710 starts to sew without any pressure on foot pedal
Mine does the exact same thing. I think the problem might lie in the cord to the foot pedal. The cord packs into the foot pedal for storage, which forces the cord to to remain bent during storage. I believe the wires in mind became damaged and broken so I took it apart and reconnected the wires at the spot where the connector meets with the wires. But I still don't leave it plugged in if I'm not using it, it could be a fire hazard.
Mar 14, 2009 | Husqvarna Viking 1
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
