Question about Optoma ML300 Mobile LED Projector
When turning on the projector it shows the Optoma logo but will not boot to the home screen. Is there a way to reload the home screen software?
When turning on the projector it shows the Optoma logo but will not boot to the home screen. A little fan appeared while in use it shut down and hasn't loaded the home screen since. Both fans are working.
  • Optoma Master
  • 698 Answers
Depends on the model. If you saw a little fan, then there is a fan problem. There might be 3 fans. 2 square ones and one blower fan. Look for plugs with 3 wires(red/white/black or red/yellow/black). Those will lead to the fans from the mainboard. Occasionally the fan will spin but the tachometer lead will stop reporting the fan status and the projector shuts down. To being with I would clean out the projector fans and ducts thoroughly. That may clear up the issue. Otherwise there is a button press sequence to enable the service menu, but you cannot upload new firmware without special optoma software that isnt available. Another possibility is you have failing filter capacitors in the power supply. Be careful poking around under the hood. There is lethal high voltage possibly stored even when unplugged.
Posted on Nov 26, 2014
Optoma EP719 Projector "Pulse"
It is one of the fan, it is bent or out of place and cause reptead disturbance at cyclic intervals. The projector must be taken apart and examined on the inside
Jul 22, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Projector powers up as normal, bulb comes on, displays Optoma logo on screen and menu will show on screen. The issue is that although I have 3 devices plugged into the HDMI port of the device using a HDMI...
There is a source lock and source button I would unlock source lock button and the push source button until you get to your hdmi input you are using. You also may just plug in one input first and once you get the input right play with the multiple hdmis
Aug 11, 2011 | Optoma HD20 DLP Projector
I need to reset my projector. It is bazook after I disconnected it incorrectly from my MacBook. It now shows the grid and then it twinkles maddly and the gris reappears, and the whole sequence is...
hy , i have an optoma pk 102 projektor and i have a promblem i start the projektor , shows me the "optoma logo" and than it's starts flashing and restarting , and show again the optoma logo. i try to connect to the laptop and show me the extend monitor for 10 secounds and restarting again, how can i fix the problem,maybe i cand upgrade the firmware?.Thanks
Apr 26, 2011 | Optoma PK102 Projector
Optoma EZ Pro does not connect to laptop. Tried Control Panel / connect to laptop / dual display, but computer will not recognise projector.
reload software and reboot entire system after make sure Optoma power is turned on before turning on computer
Jul 21, 2010 | Samsung Computers & Internet
I have the Optoma Model EP719 running. When I turn on my computer the projector shows my computer screen as it boots up. As soon as my desktop wallpaper and icons appear on the laptop screen, the...
right click on main screen, then go to properties, then you can adjust resolution, color, contrast, hue, and much more. You can also do this from control panel and under display.
Oct 08, 2009 | Optoma Office Equipment & Supplies
Replaced lamp now projecter will not turn on hd70
I had a similar situation, but we fixed it.  I can't exactly tell you why it worked nor whether or not it will for you.  Here's the deal.
First, take your lamp out and re-seat it.  This is one of the easiest ways to get a projector not to power up.
In our case, the thing would fire up, show us the Optoma logo, the blue screen, and then within about 15 seconds, it shut down, lamp fail light came on, and only a hard power reset would let us try again.  The bulb was good; after all, it came on, right?
So, we kept playing this game of power up, fail, unplug, replug.  I gave up and went to do something else.  I came back to the projector, needing it to let me see a screen to configure (weird I know, but that's how it was).  Anyhow, at this point, the projector stayed on, no problems.  So, I kept it running through the night with a kitchen timer on.  After 5 1/2 hours without failure, we knew we were set.
The point?  If it's powering up and showing picture for even a brief period, try cycling it several times.  However, if it's overheating or showing any other signs of distress, you may make it worse using my approach.  I think we may have just been lucky or the projector gnomes came in the night.
Jun 25, 2009 | Optoma HD70 DLP Projector
Dvd10 optoma projector makes a loud noise
Hi, I'm not sure if it's the same problem I had..
I had it on picture mute, for maybe 15 mins, which may not have been a good idea. While it was muted, it made a sparking sound, and then a very loud grinding noise. When turned off, the lound noise stops, and the fan continues as usual for about a minute. As soon as it's turned back on, the grinding noise is back. But the logo seemed to display ok.
I took it in for repairs, and they said they needed to replace the color wheel to fix the problem.
optoma dv10 mode
Sep 26, 2008 | Optoma H30 Multimedia Projector
Optoma ML300 Mobile LED Projector Logo
192 people viewed this question
Top Optoma Computers & Internet Experts
rostit
richie46
Scott Samson
Scott Samson
Level 1 Expert
Are you an Optoma Computer and Internet Expert? Answer questions, earn points and help others
