Question about Samsung DMT400RHS Builtin Dishwasher
Hi my dishwasher does not turn on to cycle modeDMT400RHS samsung
    New Friend:
  • 87 Answers
Sounds silly...is it plugged in and is there power? Are there any lights on the unit? Assuming yes then there could be a defective safety switch. There are several on these units beginning with the door closure switch.
Posted on Nov 26, 2014
Samsung dishwasher wont turn off
Does the washer complete the cycle but remains on? Do you know that it's supposed to turn off? If it is not completing the cycle, it might be due to a failing water inlet valve, a failing heater, or something similar.
-Rod
Nov 22, 2016 | Samsung Dishwashers
Noise on wash cycle
Support - Dishwashers DW80F600UTS/AA ' Samsung ...
www.samsung.com > Home > Support > Dishwashers
Samsung ElectronicsVisit Samsung today for DW80F600UTS Top Control Dishwasher with Stainless Steel Tub (Stainless Steel). You'll find product ... Yes; Sound Level (dBa) 48 dBa; NSF Certification Yes; Total Number of Cycles 4; Total Number of Wash Options 2 ...Multiple wash arms ensure even water distribution during a cycle. 3 (Upper ...
Oct 01, 2015 | Samsung Dishwashers
My dishwasher(samsung DW7933LRABB) wont fill, it will drain if i put water in the tub. supply is on.
You either have a bad water valve, or a bad case-brake assembly (in which case you should have an error code or blinking light on your console).
Mar 06, 2015 | Samsung Appliance DW7933LRABB 24" Tall Tub...
Samsung Dishwasher model DW80F800UWS with Error code 5E or "SE" error code.
The 5E error code on this Samsung dishwasher means a drain error. Most often this is caused by a clogged drain hose, or some foreign object getting caught in the drain pump impeller. But it can also mean you have a bad ECS sensor. If this is Greek to you, then you should probably call a professional dishwasher repairman.
Jan 10, 2015 | Samsung Dishwashers
Samsung DMT300RFW Builtin Dishwasher will not run past wash cycle. I start it and it fills and the wash cycle starts but won't cycle past the wash cycle. No error codes.
What do you mean, it won't "run past the wash cycle"? Do you mean it stays in the wash cycle forever? Or do you mean it quits in the wash cycle and doesn't rinse or dry?
Oct 18, 2014 | Samsung DMT300RFW Builtin Dishwasher
MY BRAND NEW SAMSUNG DISHWASHER HAS POWER BUT WONT START THE WASH THE WASH CYCLE THE TWO CYCLE LIGHTS JUST KEEP BLINKING
What 2 cycle lights? Samsung dishwashers indicate problems and errors by making different lights light up and/or flash. We would need to know the model number too.
Oct 07, 2014 | Samsung DMR78AHS 6 Cycle Stainless...
Samsung dishwasher flashing heavy light
Had a look in the user manual for your dishwasher.http://downloadcenter.samsung.com/content/UM/201211/20121101114232459/DW7933LRASR-00141A-02.pdf
Page 26 shows blinking Heavy light means there is leakage in the dishwasher. Most likely there is water in the base under the drain sump which could cause the flood switch to trip. Turn mains power to dishwasher off. Pull it out from under kitchen bench without breaking the hoses. Put some towels on the floor and turn dishwasher back and forth on incline to get water out. Wait a little and turn on. If no difference then you need to dry the base and find the source of the leak. More likely the door seal.
Apr 03, 2014 | Samsung DW7933LRAWW 24" Tall Tub Built-In...
Samsung Dishwasher (DMR57LFS): Error code oE. Fills...fills some more...then drains.
Samsung Dishwasher 0E Error - We had other appliances on that circuit. We believe when those appliances were turned on it created an undervoltage condition in the dishwasher, causing another sensor to send the high level error code 0E. We believe this is the problem because it only started after we added the new hot water dispenser on the same circuit. The problem went away when we leave it off for the whole dishwasher cycle. I'm guessing it could also be caused by brown-outs and other large electrical loads cycling in the same household. That's the theory anyway. The folks who sold us the dishwasher suggested turning off the breaker, to reset the computer. Good idea, but not for our particular case.
Nov 14, 2011 | Samsung DMR57LFS Stainless Steel Builtin...
Had a Samsung DMT800RHS dishwasher installed by Sears 2 weeks ago. Used it approx. 4 times. Worked well. Today it doesn't turn on. None of the "touch-type" buttons on the console work. Home...
Hi. We have the same problem. Dishwasher was installed about 3 months ago. There is an easy 'temporary' fix.
Completely turn off the dishwasher by flipping the circuit breaker to the off position. Wait a couple of seconds, and flip the circuit breaker back to the on position.
The dishwasher console must be getting into a bad state and not sensing the console panel buttons. The circuitry in the dishwasher is never really "off" as some amount of power has to be "on" to be ready to sense the touch panel. Turning the circuit breaker off and back on likely resets all the functions and makes the unit operable. We have been operating the dishwasher this way for about a month now. Luckily for us, the circuit panel is 3 steps away from the dishwasher...but this is getting old.
Hopefully this solves your problem ... reply back here one way or another...if this turns out to be a common problem & solution,it will give me more faith that Samsung will be convinced of a problem when I call them after the holidays.
Dec 21, 2010 | Samsung Dishwashers
I have a samsung washer sw65asp2 faulf code 1E
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 05, 2010 | Samsung SW62ASP Top Load Washer
Samsung DMT400RHS Builtin Dishwasher Logo
244 people viewed this question
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
