Question about Yamaha HTR-5730 Receiver
How do I turn the subtitles off for the yamaha HTR-5730 AV receiver? When I hook the cable up directly to the TV, there are no subtitles, but when the video output goes through the receiver, subtitles
I've tried reading the manual, but it doesn't say anything about subtitles... I've tried a few different settings as well with no luck. I can't find anyone else having this issue online either, but the subtitles only show up when the video source goes through the receiver
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
The receiver manual may list it under "CC" (closed captions) instead of subtitles. Also, don't just check your AV receiver; try checking the setup menu on your TV, and look at the TV remote. See if there's a CC setting that may be turned on, either through the TV setup (probably under the "Display" or "Video" tab) or because you've accidentally pushed the CC (or Subtitles) button on the TV remote.
Posted on Nov 26, 2014
Noggin
  • 944 Answers
SOURCE: Yahama HTR-5730
Here's the manual; http://www.yamaha.ca/av/PDFs/Manuals/2004_receivers/HTR5730E.asp See if you find a solution in there - if not please ask again and we will see what we can do :)
Posted on Apr 16, 2007
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
honeybaked74
SOURCE: the HDMI "input" ports damage output ports of connecting devices
i know this sounds stupid, but have you "toggled" or "played" with the HDMI cables? are they the same manufacturer? HDMI channel connections are very fickle. If just one connection is not exactly correct, they go to a limp, no go status. Since they run at such a minimal voltage, i can't see them "blowing" the outputs on the devices.however....if your cable has a serial type output for video only, I would connect the hdmi convertor to it and see if it works.
Posted on Jan 10, 2009
smarthome2
  • 1114 Answers
SOURCE: Video signal drops out
Well, I have a solution and a question. First, why do you have S-Video hooked up from the sat receiver? is it a non- HD unit? Does it have component out? if so use it. Next; your receiver, as awesome as it is,it is 3 model years old and the HDMI firmware that was used in 2005-06 was version 1.1 which unfortunately for all of us was a "failed" format when using DSS,Cable, or FIOS. The problem was passing the DHCP copyright protection format from one source thru another to a third. Sounds complicated, I know, but that's what the issue is. The Good news is; the human eye cannot tell the difference between 720p and 1080p on any TV set 50" or smaller, and that is a fact. and the 2600 would only convert from s-video to 1080i which is equal to 540p. So, to make a long story short and understandable, if you use a good quality component cable to your TV set (Monster, Phoenix Gold, Apatchure, etc) your picture quality will not suffer and there is no reason to be upset at your receiver since it was firmware provided by HDMI not Yamaha and was a problem on every receiver made with 1.1 firmware. So here's what you do Hook up your Sat receiver component (if you have it) S-vid if you have to, and any other sources that are going to pass video thru your receiver either s-vid,component, or standard vid. The only exception would be a blu-ray DVD. I would run HDMI direct to your TV, then run digital coaxial for audio to the DVD Digital audio input of your receiver. You have an awesome receiver that has lots of cool features and a bullet-proof electronics! enjoy it! Hope this helps. If you have any more questions, post a comment and I will help some more.
Posted on Jun 07, 2009
satavlad
  • 405 Answers
SOURCE: Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Posted on Nov 28, 2009
Receiver does not respond to remote, will not turn off or on with the remote what is wrong?
Dear sir my name prakash my won us Yamaha AV Receivers Model RX-V673 Go To died mode what this problem please sir?
Jan 06, 2014 | Yamaha HTR-5730 Receiver
How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Jan 15, 2011 | Yamaha HTR-5730 Receiver
Humming coming from the speakers
From all speakers?
How is the audio connected to the TV (be specific)?
Keep in mind that a TV is not generally an audio source as its programming always comes from something higher up the audio food chain than itself. Get the audio to your receiver from whatever THAT is, not the TV.
May 29, 2010 | Yamaha HTR-5730 Receiver
I'm only getting analog sound when tv is on, optical cable is hooked up properly, maybe a bad cable?
Name the TV model and define the routing of said optical audio cable.
Digital audio is rarely originated at the TV but it usually comes conveniently from the source you're watching on it. Try routing the digital audio directly from the source to the Yamaha and bypass any limitations imposed by marginal TV electronics.
May 20, 2010 | Yamaha HTR-5730 Receiver
Yamaha HTR-5750 no sound when I turn to the DTV/Cable setting
If you are not getting sound on "Any" input except "multi channel" you have a bad DSP chip in the receiver.In short, you need a new receiver, it's a 500.00 repair. If you get sound on "All" inputs except "DTV/CBL" You need to get into the main menu of the Yamaha and select audio, toggle to input, then DTV/CBL and select "Auto". If you still do not get audio, it would be due to the version of HDMI software in your receiver. If it's under warranty, Yamaha will update hardware and software for you at N/C. If it's out of warranty, use digital coaxial or optical as your audio input for TV and run your HDMI directly to the TV. (The repair for this too would run 250-350) I hope I've covered all the possibilities. If you need further help, post a comment and I can help you more.
Aug 25, 2009 | Yamaha HTR-5730 Receiver
AV Receiver
Hello MCKing,
This is the place you need!!! Just send your question(s) and I'll be happy to help you find a solution.
cancerags
Jan 01, 2008 | Yamaha HTR-5730 Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Composite Video hook-up question
Generally, you only need one 'full' set of connections. If you are using s-video, you'll still need audio red and white or fiber...not both. Fiber is better. Where are you going to get your audio from? That's where you'll want to direct your feed. Some people cheat and run the red/white to the TV when they're too lazy to turn on the receiver! Mute it if it annoys you.
Dec 28, 2007 | Yamaha HTR-5730 Receiver
Connecting a Yamaha VX7 Subwoofer on my Yamaha HTR 5730 AV Receiver
Hello srqwrk,
You can connect the VX7 to the 5730 using an RCA Y cable like the one shown in the picture below. You get your one connection for the receiver and 2 for the VX7. These are available at any electronics store. Remember that the cable should be long enough to go from the receiver to where subwoofer will be placed.
Hope this helps. Let me know.
cancerags
Nov 26, 2007 | Yamaha HTR-5730 Receiver
Yahama HTR-5730
Apr 16, 2007 | Yamaha HTR-5730 Receiver
Yamaha HTR-5730 Receiver Logo
188 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
