Watching T V and screen went black, Is it junk or is their a way to reset it ? Power light is on , but that is all. No sound.
    New Friend:
  • 57 Answers
Sometime after powering up, the power light will blink a number of times and any pattern (like say 5 blinks pause 5 blinks etc) should be noted since these are 'fault codes'
Posted on Nov 26, 2014
    Scholar:
    New Friend:
  • 61 Answers
Most TVs these days are computer-controlled, and the computer stays on, even when the TV is "off" so it can receive commands from the remote. Sometimes the computer gets hung up, particularly if there was a short-term power failure (a drop of a few seconds).
The way to reset it is to unplug the TV for a few minutes. See if that helps.
dgjtex
  • 405 Answers
SOURCE: screen went black while watching, no sound
Almost for certain your power supply board is bad, Can be repaired at the component level only if you have some electronics savy! Good Luck!
Posted on Dec 26, 2008
SOURCE: power led blinks but no picture or sound
Had the same problem myself. Took some doing but I managed to find a service bulletin that I downloaded. The problem is with the siene module and all you need to do is unplug connector JP63A from the main board and your TV will work again.
Take the back off the TV (there are a lot of screws) and look on the left hand side of the main circuit board that is mounted in the center of the TV. You will see a small white connector that is labelled JP63A, simply unplug it. Plug the TV back in and let it reboot. That's it, should be able to watch immediately.
Posted on Mar 15, 2009
  • 187 Answers
SOURCE: Green light but no picture, no sound
Your mainboard is damaged, replace it and that will solve your issue.
Posted on Jun 06, 2009
ginko
  • 19396 Answers
SOURCE: Sanyo DP42746 - Screen went black and no sound. Power light on.
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Jun 16, 2009
  • 534 Answers
SOURCE: Red light blinking three times in a row
Service manual says 3 flashing red leds = eeprom error (main digital / video pcb).
Suggest you start by implementation of Fujitsu Service Bulletin PDP 0068-01 Main Digital pcb see:-ttp://www.eserviceinfo.com/download.php?fileid=43450
Posted on Aug 21, 2009
Panasonic Plasma 50 TH-P50U30A blacked out with no sound
Appears to be a power supply issue with everything being so dead.
Jan 22, 2017 | Panasonic Televison & Video
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Oct 02, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Ive got sound and power but black screen
Could be the cable your using to connect to whatever viewing device your using.
May 06, 2015 | Seiki Televison & Video
My 26" LCD tv has black screen When I was watching it screen went black unplug ova nite still Same thing barely see movement IN back Ground up really close so but it have sound But black screen can...
Good day!
LCD screens have very thin fluorescent light tubes. if you can barely make out an image its most likely that the Power inverter board that powers the lights is damaged.
Aug 24, 2010 | Televison & Video
Blank Black Screen but with sound
ITS A Y SUSTAIN BOARD BEFORE REPLACING IT CHECK LDVS CABLE UNPLUG IT AND PLUG BACK IN IF IT FIXES IT IF NOT REPLACE THE BOARD.
Jul 15, 2010 | Samsung Televison & Video
Tv screen went black and no sound
Look at the power supply first; look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find. It sounds like at least you do have the 5V standby power supply working but the main supply is not getting the 'ON' command from the main board, or the power supply is gettin ght e 'ON' signal but failed to turn on.
Sep 25, 2009 | Audiovox FPE3206 32 in. LCD Television
TV screen went black as I was watching.
if theres nothing at all (sound and vedeo) then the power supply section may check, fuse, power I.C. or transistor
Jul 31, 2009 | Televison & Video
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
