Please, i'm warried, i need a help
SOURCE: hp laserjet makes a continuous screeching noise when plugged in and will not print.
I have an identical situation. I have isolated the source of the loud screech to the (laser scanner assembly) p/n RGO-1041. The unit is located underneath the top cover, where the printed paper rests after it is ejected. I had to remove the right and left side covers, then remove the three screws holding down the top cover. There are two screws up front and one to the rear, it then lifts straight up. The laser scanner has a ribbon cable, and four purple wires going to it, oh yeah there is a big yellow warning label, so you can't miss it. I hope this helps. Sorry, I accidentally posted this in problem section.
SOURCE: Using JETCET Print with OKI C5200n Printer
The OKI 5200 is a 'GDI' or Windows only printer and does not support PCL or PostScript languages.
Most if not all of the printers listed support either PCL or PS or an inkjet based language.
I'm afraid you will not be able to print the the 5200 without it's driver loaded on the PDA.
If the 5200 supported PCL you would be able to choose any of the
Color HP Deskjets.
SOURCE: changing ink cartridges in hp laserjet 1200 printer
melanie3, heres a screneshot of the step, download the PDF for more information on changing some parts of your printer.
the screneshot:
http://i32.tinypic.com/211qpmb.jpg
the manual:
http://cob.fsu.edu/tech/printermanuals/laserprinters/HP1200.pdf
SOURCE: Hp printer displays offline
I resolved the problem by restarting the Print Spooler service.
Click Start/Run
Type services.msc and press enter
In the Services dialog scroll down to Print Spooler
Click to select it and Click Restart Service.
The system will stop and restart the service.
Close the dialog and check your printer again.
If this fails, leave te printer on and reboot the computer.
Hope this Helps!
SOURCE: Windows 7 cannot download hp
If you are looking for a driver, then try the vista versions. If your windows 7 is 64-bit download this (under Universal Print Driver):
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=29790&prodTypeId=18972&prodSeriesId=29789&swLang=8&taskId=135&swEnvOID=2100
If it is 32-bit:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=29790&prodTypeId=18972&prodSeriesId=29789&swLang=8&taskId=135&swEnvOID=2093
