Question about JVC Televison & Video
Is the jvc model # av-36950 Hd compatible with hd comcast service
I think the ? is pretty straightforward.
    Sergeant:
    Champion:
  • 282 Answers
If it has an HDMI cable then it is.
Posted on Nov 26, 2014
  • 1694 Answers
SOURCE: JVC AV-36950 TURNS OFF
Replace C953 1000mf / 35v in power supply....capacitor
top will appear slightly bulged or will check bad with
ESR meter...........................T.
Posted on Dec 11, 2007
jerryg50
  • 1667 Answers
SOURCE: hd compatible?
The instructions for your TV set should answer that! From what I remember, I believe your set is not HD compatable. I am guessing from memory with this.
Jerry G.
Posted on May 27, 2008
ButtFuzz
  • 463 Answers
SOURCE: is this TV HD capable?
This is not an HDTV. However, that does not mean you cannot use it to view the HD channels with DirecTV, you just wont be able to view them in hi-def. Use the component inputs from the directv tuner and plug those into the proper component inputs of your JVC. Once you see the DirecTV picture on the screen, go into menu... setup (with the directTV remote) and make sure that the only resolution checked is 480i. DirecTV with 'downconvert' those cannels to standard def, and they will still look pretty good though the component connection...
... now, in answer to your next question: "What exactly do I need to view HDTV with DirecTV?"...
1. A television that will accept 720p or 1080i signals.
2. A DirecTV HD Tuner.
3. Any DirecTV service BUT you must purchase the HD pack so that they will 'unlock' the HD channels
4. The proper cables to hook in between your DirecTV HD receiver and your HD-capable TV/Monitor. You may use either HDMI or component video cables, so long as your TV will accept them. Tune your TV input accordingly. When using component video cables, you must also run a separate cable(s) for audio...
Take care,
Rob
ps. DirecTV HD tuners do not have an RF 'out'. ("coaxial or ch3/4 connection")
Posted on Mar 05, 2009
DerStrom
  • 103 Answers
SOURCE: My Trinitron Model KV-32FS210--Is it HD rated?
According to the website, the KV-32FS210 is a SDTV (Standard Definition Television). This means it is in standard definition, not high definition (HD). I don't know why your Comcast installer told you that it had HD, but according to my sources, he was wrong. I'm sorry to be the bearer of bad news, and I hope everything works out. Good luck! Sincerely, Der Strom
Posted on Apr 27, 2010
  • 8 Answers
SOURCE: jvc av 36950 went off
This TV has a common problem. I've found dozens of owners with the same complaint. See the following blog for a simple fix for your set. I tried it and it worked and I spent under 2 bucks to fix it myself at home!
Good Luck......Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Posted on May 25, 2010
JVC av-32360 HD compatible?
It should be. I have the same TV as you, and we have used Dish and Direct TV for years.
Dec 03, 2011 | JVC AV-32360 TV
My tv will not turn on and the on timer light is
Try the following blog. It has detailed instructions on how to fix a common problem on this JVC TV series. I did and I fixed my TV for 2 bucks at home.
Good Luck...Kim
Jan 14, 2010 | JVC AV-36950 TV
MY XBOX WONT PLAY ON MY JVC TV MODEL AV-25F1EK BUT WILL PLAY ON MY SONY TV
Is your JVC a HD TV? If not, it may because you haven't switched the xbox av plug in the back to regular tv instead of HD?
Nov 28, 2009 | Microsoft Xbox 360 Console
Is this tv model number HD-compatible?
that tv has 3-inputs digital comb filter
component video input
tv,vcr,and dvd
and also a S video input which can be connected to hp for video transfer.
yes it is compatible.
Apr 07, 2009 | JVC AV-36D303 36" TV
Is this TV HD capable?
Take care,
Rob
Mar 05, 2009 | JVC AV-32D502 32" TV
JVC AV-36950 TV won't turn on
In this case wat u can do is try to Turn On the set without the memroy card inserted....
If still same Problem u can try replacing the batteries.......
If the set turns on without the Memory card replace the memory card....
Good Luck.....
Jan 20, 2009 | JVC AV-36950 TV
Jvc av 36950 went off while watching, the same sound that you get when you turn set off. No sound, no picture, no red power light
Good Luck......Kim
Dec 09, 2008 | JVC AV-36950 TV
Dec 02, 2007 | JVC AV-36950 TV
Hd signal not being picked up
your comcast box is not hdcp compliant.this signal tells the tv it isok to display the image.It is similar to video copy guard
Oct 30, 2006 | JVC AV-48P775 48" HDTV
Televison & Video Logo
47 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
