Question about Sharp Televison & Video
Good moring ! Ma'am or sir I'm repairing my TV set sharp 21V-W70M the problem is green picture, ill try to changes the degosing coil, and then try to testing to open to picture to become fufull over just like pad of peper . wat I do pls help me!
    New Friend:
  • 87 Answers
If this were a degaussing issue then I would expect to see red, green, and blue but with distortion. That isn't what you're reporting. As has been suggested already, you likely have a component area (like vertical or horizontal sweep) that is malfunctioning because of a failure. The failure could be system voltage oriented or a component board or combination of both. Here is the bottom line, how much are you willing to spend to fix an older TV? If you aren't willing to spend a few hundred dollars then consider why a repairman would want to work for less? By the time a technician puts the set on his bench, opens it, and does preliminary system check you've got an hour invested. If a system power voltage failure caused other components to fail then the problem along with cost to repair quickly escalates.
Posted on Nov 26, 2014
Testimonial: "Thanks sir I'll try to find all you've say thanks gud morning"
    Problem Solver:
  • 10 Answers
If Your Picture Is All Green You Might Want To Inspect Your CRT Or Picture Tube Socket For Loose Connections First...
Testimonial: "Ill try tosolder the loose contact but no happen the pictury be come strype like a pis of paper wat I do?"
  • Sharp Master
  • 1,249 Answers
Foldover is most likely the vertical ic bad solder and or bad caps. green screen is most likely bad crt or video drive circuit
Testimonial: "We're I found the video circuit? Sharp primo my TV set"
  • jeff5may32 Nov 26, 2014
    If you are going to try to fix this set yourself, you had better know how to. You can't just poke and hope.These sets are very fragile on the inside and aren't padded with parts you don't really need. They are mostly plastic and glass and transistors. If you're not careful, you'll fry something or get shocked.
    If you can troubleshoot electronics, get a service print or manual for the set. If not, take it into any TV shop and they should be able to shoot you an estimate just looking at it operate.a good service tech will be able to fix one of these sets in a couple of hours tops.
Ask for a resistor value of r704 on sharp model 21v-fk200m
Sharp 36C-230 36" TV Repair Questions,... - Fixya - Answer
www.lpjaz.com/support/p217124-sharp_36c_230_36_tv
I forget my password TV sharp model 21s-fx10a · Sharp Standard. ... What is thevalue of resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
[WML]sharp 21v-fk200m flat screen crt
www.elab.ph/forum/index.php?topic=41147.0;wap
sharp 21v-fk200m flat screen crt. Pages: (1/4) > >>. bobet20: pahelp po mga master,may problema ako malaki,,,sunog po resistor sa power supply r704,,syaka
Dec 28, 2015 | Sharp Televison & Video
My sharp tv model 21V-W70M has no sound, the speaker is ok but no soumd coming out.
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Check the voltage goes to audio amp circuit section.
Check speaker/s [If there is two speakers, both of it should be checked for coil continuity]
Check whether the audio is muted.
If all these are OK, check and replace the audio output IC.
Oct 02, 2015 | Sharp Televison & Video
Sir do u have an example of sistimatic diagram of sharp primo 21V-W70M ?
http://elektrotanya.com/sharp_20lk31_20lk61_chassis_sn-70a.pdf/download.html
Nov 26, 2014 | Sharp Televison & Video
Sir pano ma repair ang tv shark na 21v-w70m pag saksak q mg on yung light nya tapos mamaya mamatay?
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 16, 2014 | Televison & Video
Sharp primo 21V-W70M service manual
Service manuals are in PDF and cannot be included here by this window. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts.
Mar 30, 2014 | Audio Players & Recorders
I have a crt tv sharp model:21v-fw150m blk.. is
Try to download the repair manual to this TV by internet. It has all details.
Oct 05, 2013 | Televison & Video
Sharp service menu model 21v-fk220m and model 21v-fk200m
Sharp, Fisher & Sanyo will have same configuration to circuit. So, the service menu entry method to these sets will also be the same. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/
Jun 02, 2013 | Televison & Video
SHARP TV 21V-W70M CHILDLOCK RESET
TV sharp premo ret race line model no 20 W 70M
Aug 25, 2012 | Sharp Televison & Video
21V-W70M primo sharp black out
check the regulator maybe its busted
Mar 04, 2010 | Sharp 25R-S100 25" TV
Televison & Video Logo
60 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
