Question about Samsung Televison & Video
I have a Samsung HL-T5676S 56inch TV, For some reason it wont come on once i press the power button. It will not come on then shut off, then i have to turn the power on again, I will have to repeat th
I have a Samsung HL-T5676S 56inch TV, For some reason it wont come on once i press the power button. It will not come on then shut off, then i have to turn the power on again, I will have to repeat this process for about another 10 times by the time it actually shows me a picture. Please Help
  • 61 Answers
You certainly have a power supply failure. Bad capacitors in the power supply can cause this.
Posted on Nov 26, 2014
  • 62 Answers
It's probably some problem in the TV, however it could also be some trickster around your home using a TV-B-Gone
TV Gone Universal TV Power Remote Control Keychain
4 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: The tv will not turn on
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 14, 2009
  • 16 Answers
SOURCE: Picture & sound suddenly shut off. power light blinks red 5X...5X
http://www.sonya20tvclassaction.com/main/home.sfx MAKE SONY FIX IT
Posted on Dec 03, 2009
toolkits
  • 1099 Answers
SOURCE: My Samsung HL-T5676S Television comes on, then
The power light may be flashing or if you are runing with a series light bulb it may be cycling on and off continuously. There may be a chirping or clicking sound from inside the set. (Note: using too small a series light bulb load during testing for the size of the TV may also result in this condition.)
If there is a low voltage regulator or separate switching supply, it could be cycling on and off if the horizontal output, flyback, or one of its secondary loads were defective.
Does this TV have a separate low voltage regulator and/or switching power supply or is it all part of the flyback circuit? For the following, I assume it is all in one (most common).
Some simple things to try first:
Verify that the main filter capacitor is doing its job. Excessive ripple on the rectified line voltage bus can cause various forms of shutdown behavior. An easy test is to jumper across the capacitor with one of at least equal voltage rating and similar capacitance (make connections with power off!).
Use a Variac, if possible, to bring up the input voltage slowly and see if the TV works at any point without shutting down. If it does, this could be an indication of X-ray protection circuit kicking in, though this will usually latch and keep the set shut off if excessive HV were detected.
Good Luck....
Posted on May 21, 2010
Tv will turn on, for about 30 seconds, then it will shut down
Hello
There are two main reaons for this fault. The first is with its power regulator board itself. If it has any loose soldering points developed, this type of intermittent fault can occur. The second is with its light engine. If you want to do this work by yourself, you must have thorough knoledge in electroncis, and must have all tools and ability to follow its schematic diagram. The most you need is patience. If you have these all, and want to do the repairwork by yoursef, inform me. I've the schematics of your tV, and all repair adjustments and proceedings. The power supply board and lamp ballast boards for Samsung (HL-T) series are shown here for your referecne. The lamp ballast board also may need to be checked.
Nov 16, 2011 | Samsung HL-T5676S Television
How do i reset my lamp hour hl-t5676s
There should be a blue switch behind the lamp cover on the rear of the unit.
Feb 28, 2011 | Samsung HL-T5676S Television
Now the power shuts off consistently. Says on for a few seconds and the picture looks Ok but it powers down and powers up again on its own.
Tv "LAMP" LED light is flashing?Yes.Projection lamp might have to be replacing?LAMP been iside the tv like 1 1/2 or 2 years,tv used daily like 4 or 5 hours a day?Yes,replaced the projection lamp,will solved the problems.
Feb 14, 2011 | Samsung HL-T5676S Television
The tv wont turn off without unplugging it
power button sticky ir remote sensor bad or dmd board problem most failures with samsung seem to be dmd board related if not the bulb or ballast
Jan 02, 2011 | Samsung HL-T5676S Television
Our 55" Samsung DLP television has white dots all over the screen. Day after day, more seems to appear.
The DLP tv projection light engine is the cause.This problems,very expensive to repair or replaced the projection light engine.Samsung know about this flaw in the tv design.Talk to them,make a deal with them about it.Help u repair it.
Sep 27, 2010 | Samsung HL-T5676S Television
Good Luck....
May 21, 2010 | Samsung HL-T5676S Television
I have a Samsung HL-T5676S DLP TV and the picture just recently started to look curved. In the middle of the screen it's straight but on the sides it starts to curve up. Any idea of what could be causing...
make sure you do not have anything sitting on the top of this tv. I have seen this on my tv by just gently putting pressure with my finger on top the screen starts to curve up at the edges.
Jan 14, 2010 | Samsung HL-T5676S Television
What is causing white spots on my 56inch DLP Samsung Television. It started with on spot 2 days ago and now there is 15
the dlp chip needs to be replaced. samsung will cover the cost of the part and labor. call 1-800-samsung to set up service.
Dec 28, 2009 | Samsung DLP HL-P5663W 56" TV
Projection tv
Take it back, it will only get worse.
Feb 12, 2008 | Samsung HL-T5676S Television
Televison & Video Logo
47 people viewed this question
Jerry Greenberg
Jerry Greenberg
