Question about Electrolux EI28BS56IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator
How do I get ice from model #E128BS561S5?
We moved into a house with this model but no manual. Water comes from water feature but no ice. Door alarm comes on pretty regularly also... Even when it's closed!
    Habit-Forming:
  • 61 Answers
How do I get ice from model #E128BS561S5? - 25297176-1xulv4qsxv1r1rrcaio2eatt-5-1.jpg
I hope this page from the manual helps. It might be that you must hold down the button for 3 seconds as stated in the manual, or a stuck bale arm. Otherwise, it may be a bad feed valve to the ice maker.
Posted on Nov 26, 2014
4 Suggested Answers
geterrollin
  • 277 Answers
SOURCE: We have an Electrolux S/S side by side
check and see if there is a built in filter pack inside the back of the fridge or it could possibly be that one of the lines has froze internally and or the open close valve at the water inlet inside has worn out
Posted on Jan 18, 2011
  • 257 Answers
SOURCE: eletrolux side by side. temp
Sounds like the touch pad has a jammed button or is shorted , if it dose not release by depressing a few times firmly, the touch pad on the door may have to be replaced. The temperature problem may be unrelated or the ice maker door flap may be remaining open lowering the temperature. Hope this helps.
Posted on May 02, 2011
fudge_david
SOURCE: Ice maker not working
my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
Posted on Feb 10, 2012
What would cause the airflow to stop to fridge when freezer door is closed? (kenmore model 106)
Ice in the path of air flow to fridge. The freezer also kkeps the fridge cold via a fan that blows the cold air from feezer to fridge.
Aug 21, 2011 | Kenmore Refrigerators
Ice maker dont work
There are several things that can prevent and icemaker from working.
1- Temp in freezer. If the temp in the freezer is higher than 6 degrees the ice makers thermistat will not call for water.
2- Water inlet valve. If the inlet valve is malfunctioning the silinoid may not be opening. Even if you are getting water through the door.
3- Faulty ice maker. If the internal components of the ice maker are no longer functioning it wont make ice.
To test the inlet valve. In the back of the fridge is and access panel near the bottom remove this panel and look at the inlet valve. now you should see 3 hoses. One is usually copper and runs directly from the house water supply. There will be two other hoses from the inlet. One leads into the fridge for the water in door feature. The other is for the icemaker. Switch the two hoses from the ice maker ( water in door and icemaker) than push the water in door feature and see if the water goes into icemaker. If it does not than replace inlet. If does and temp in freezer is below 6 degrees replace icemaker.
If you need further assistance please comment me back.
Jul 30, 2011 | Kenmore 53642 / 53644 Side by Side...
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house in June. The change filter light came on a few weeks ago and I can't get it...
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house the change filter light came on and I can't get it to go off. How do I reset the change filter light (it's not time to change the filter)? The model # is MSD2732GRW and I don't have a manual for this refrigerator. Thanks!!
Sep 07, 2010 | Maytag Refrigerators
How do I shut off the ice and water feature on a model mzd2766ge? The house I'm moving into is not plumbed for it yet. Thank you for your help.
Hello. All you need to do is to raise the wire arm inside the ice maker, and above the ice bin. It will lock in the up position which turns this feature off. J.
Jun 27, 2010 | Maytag MZD2766GES Side by Side...
Maytag MFI2266AEU Water and ice dispenser locked, control panel
Door Panel Locked
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue pressing Freezer "-". You will see PE _ _ _ _.
Press Freezer "-" until PE # # # # shows on the panel.
Using Freezer "+" to move cursor, Refrigerator "+" and "-" to change numbers, bring all numbers to "0". Press Freezer "-" until PE and numbers blink. Unplug refrigerator for 45 seconds, never beyond 1 minute or you'll have to start over.
Look inside refrigerator door and locate the serial sticker. To the right of the serial number is the CODE ####. Plug in your refrigerator.
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue to press Freezer "-". Using the same method as above, enter the four digit CODE number you found on the serial sticker. Press Freezer "-" until PE and numbers blink. You have just reset your panel. Unplug for 45 seconds. Plug in refrigerator and you should now have full use of your door panel.
This unit has a built in safety timer mechanism. If it dispenses water for two minutes, it assumes it is flooding your house and shuts the panel down. If you are filling a pitcher of water, just stop dispensing halfway through to reset the safety timer.
Feb 01, 2010 | Maytag MFI2266AE Side by Side Bottom...
Ice maker in door not making ice
make sure the switch is turned on on the icemaker if it is then see if there is water in the icemaker it could be either water valve or icemaker
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Apr 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE TFX27PFS Always makes crushed ice.
The crushed ice sounds like the solenoid in the back of the freezer may be frozen and moving the mechanism (rod) even though you can move it by hand. Take a hair dryer and heat the area where the ice bin rod fits into in order to thaw the solenoid out. You can take the whole thing apart and put a little petrolium jelly on the shaft to keep it from freezing and sticking again if you have the tools. The door alarm may be the door out of adjustment... hold the light switch down and see if that stops the alarm, if it does you can always glue an extension piece on the switch in order to reach the door again vice adjusting the door. Some of these models were very close to being out of adjustment and a few years of wear on the hinges could do that. I've even seen someone glue an extension on the door so it would press the switch better on closing. As for the water leaking, is it continuous leak or say every 12 hours you notice a little bit of water? Continuous leak is likely a solenoid valve letting water by, small leak every 12 hours or so usually means the defrost drain line is clogged and the defrost water is not making it to the holding pan but leaking out the freezer compartment instead.
Jan 28, 2007 | GE Profile CustomStyle PSI23NGR Side by...
Electrolux EI28BS56IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator Logo
131 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
