Question about Eforcity CAR CHARGER PLUG FOR SAMSUNG VIBRANT GALAXY S T-MOBILE
How to charge tab on 12 volts?
Took the charger sector remove the 240 plug and stuck the key in cigarette lighter adaptor
  • Dave Larson Nov 26, 2014
    Hi leclercq , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    New Friend:
    Problem Solver:
  • 12 Answers
I am assuming that you are in Europe. I am in the US, however, if you have a charger that plugs into the wall. You would need an adapter of some sort. Just buy a car charge. They are cheap and work well.
Posted on Nov 26, 2014
    New Friend:
  • 36 Answers
Why are you trying to destroy your phone it runs on 5 volts and charges on a maximum supply of 7 volts
if it hasnt stopped yet it soon will go to tescos by the charger you need fort a few £s and have a long and happy relationship with your main meens of comunication its not built to take 12volts in the same way your not built to handle 250volts
12 volt cigarette lighter socket
the lighter socket will be straight 12 volts and the GPS may require less (5.5 volts) and the different size is to prevent the over voltage and damaging the GPS unit. There may be an adaptor that will do the job and it may have a built- in transformer for the purpose.
Jan 01, 2014 | 2001 Kia Sportage
Can i use tomtom in 1996 ford mondeo cigarette lighter
So long as it is a 12 volt negative ground system then yes. Plug ins are designed for cigarrette lighters in cars.
Nov 24, 2013 | Tomtom GPS
I am having trouble charging an invacare portable oxygen concentrator in a 12 volt adaptor ( cigarette lighter plu in) without it blowing fuses
the plug in unit is probably drawing more amps than the lighter socket will cater for. Check that the fault is not in the unit. Check for total current draw of the machine. As a last resort use the machine directly coupled to the battery
Jul 14, 2013 | Cars & Trucks
Hi, i had a flat battery and took it off to charge it up,i came to put it back on but realized i had no key to get in the boot and obviously have no power and my car is now stranded on my drive going...
Go to any Automotive Parts Supplier (Advance Auto Parts) and tell them that you want a 9 volt battery backup that plugs into the cigarette lighter.......Or if you have a jump box,you with a 12 volt outlet plug on it,buy the cord that connects the outlet plug on jump box to the cigarette lighter outlet plug in the car.......Either option will give you the juice that you need.....I just hope that your boot is electronically operated
Mar 28, 2011 | 2000 Mercedes-Benz CLK
My cigarette lighter is not charging in my car what could it be?
You mean there seems to be no power to the vehicle's lighter unit outlet.
This lighter unit outlet is normally wired through its own fuse so check the fuse panel in the car for a blown fuse. If blown it must be replaced with a fuse of the correct amperage. The owner's manual will show you where the fuse is located.
Before you check the fuse just check the cigarette lighter outlet with another plug-in device if you have one such as a portable 12 volt tire compressor or a 12 volt plug-in auxiliary light. It could be that if you are using a charger from the outlet, the charger plug or wiring may be faulty rather than the car's power outlet itself. (These outlets don't usually give trouble unless the wiring has been messed with or the outlet itself has been damaged or abused).
If no device works from the lighter power outlet check the fuse as it may be blown.
Sean
Voluntary contributor.
Dec 27, 2009 | 2006 Ford Taurus
Nokia 3310 charger.. won't charge help me..
if its the car charger check the cigarette lighter fuse and also the charger fuse
Sep 25, 2009 | Nokia Car Charger: 3310 3360 3390 3395...
I need to charge my Eee PC notebook from a 12volt supply.
very cheap $10 solution!
buy a "car charger" (fits in cigarette lighter socket)
for the eeepc. Many people sell these on Amazon and EBay for about $10.
This thing converts the 12 volts available out of the cigarette lighter socket,
to about 9.5 volts for the eeepc input..That's exactly what you need,,, right?
if you need a different connector for the 12 volt side, go to Radio Shack and
get a socket adapter or socket adapter into just two wires (red and black).
You didn't say where you are getting the 12 volts from (car battery?)
Mar 25, 2009 | ASUS Eee PC 701 Notebook
Cigarette lighter not working properly in Pontiac...
This is a very common issue, either the ground at the back of the lighter socket is pulled off, or more likely the socket is defective, they are very easy to change, u can use a generic replacement from any parts store, the factory part will be at least 2X as much..
Jan 05, 2009 | 2003 Pontiac Grand Am
Zumo 450 Power Through Cigarette Lighter
You should be, Check to make sure the fuse isnt blown on either the cigarette lighter plug or in the plug that has the wires coming out of it.
Nov 24, 2008 | Garmin zumo 550 GPS Receiver
12 Volt Cigarette Lighter / Accessory dead
Most likely just replace it. You could pull the fuse and then use a small screwdriver to try and pull the tabs inside the receiver in toward the center a little. It could be that repeated insertion and extraction of the lighter or accessory plug has bent them outward enough that they're not making sufficient contact to power what you plug in. If that doesn't work, replace it and then put the fuse back in.
Jul 21, 2008 | 2001 Volvo S40
Eforcity CAR CHARGER PLUG FOR SAMSUNG VIBRANT GALAXY S T-MOBILE Logo
55 people viewed this question
Top Eforcity Cell Phones Experts
Ken Scott
Level 1 Expert
Computer Repairing
Computer Repairing
Are you an Eforcity Cell Phone Expert? Answer questions, earn points and help others
