It coming on and after a couple of seconds cut off
    Problem Solver:
  • 8 Answers
Without a brand AND model number or a better description of the problem, any suggestions would be nothing more than a guess.
Unless you are prepared to repair the TV yourself, professionally performed repair, even simplest ones, will probably exceed the cost of a new LCD replacement set.
Due to X-ray and other safety concerns (equipment and/or people), CRT TVs constantly check the voltages and signals required to make a CRT work. A few seconds grace is allowed during start up but after that, any excessive high voltage (real or imagined) or loss of beam deflection circuits will cause the TV to turn off.
Please do the following:
1. Move the TV to a quiet and preferable totally dark room.
Wait until night if necessary.
2. Stand within an inch or closer to the TV screen.
3. Turn on the TV and look and listen for the following:
a. Whoosh sound and/or head hair attracted toward TV screen
Yes. High voltage activated and charged CRT screen.
No. High voltage failed to activate.
b. Hissing or normal sounds from the speaker(s) while set is on.
Low voltage circuits probably okay. Defective low voltage regulator can cause high voltage to exceed limits.
c. Entire screen briefly lit up or single bright spot at center of TV screen
High voltage worked for a moment then the TV shut off due to over voltage or current problems.
d. Brief bright line from top to bottom or single bright dot on TV screen
horizontal deflection circuits bad
vertical deflection circuits ok
TV shut off due to bad deflection/sweep circuit
e. Brief bright line from left to right on TV screen
It would be helpful for you to perform the above "up close and personal turn the TV on test" and report what happened.
Posted on Nov 26, 2014
  • 5,568 Answers
Make, model and type?
Stalls & Cut off!
If that light comes on, you should take it to a big autoparts store and they can give the code for why the light is on. They do this free. Then you can have some idea what is wrong. The problem is most likely related to the intake manifold and something akin to the EGR.
Feb 14, 2014 | 1993 Chevrolet Lumina
I turn on the power, set the mode, press start and it cuts out in a couple of seconds
MACHINE IS NEW MODEL,, ITS PROBLEM WITH MAIN POWER CONTROL BOX,, KINDLY CALL SERVICE TEAM....
Dec 15, 2013 | LG Washing Machines
Yamaha YBR 125 keeps cutting out
Hy a have a 2007 yamaha yber 125 it starts first time but then cuts off after 10 seconds anyone know what this is am struggling
Jul 19, 2012 | 2010 Yamaha yBR 125
Switch on my acer 5630 and the power light comes on and the fan kicks in for a couple of seconds and then shuts off. There is no output/no bios/ nothing like the machine has died? help please
It sounds like it has overheated and the cut-out is turning it off before it will start. Depending how ow the machine has become it can take a while for it to restart. My worst case for overheating was a couple of hours before the machine would start.
Please let me know how you get on.
Dec 18, 2010 | Acer Aspire 5630 Notebook
My sony wega keeps cutting off then coming back .
a couple of years old can be a long time:
has the TV been on 24\7
It's the amount of hours that matters..
electrolytic capacitors typically last 3000 to 5000 hours....
Special "long life" caps last close to 7000
but the caps in most consumer electronics, even broadcast equipment 3-5K hours.
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Motor will not cut on
check the motor resistance, check the connection to the motor. Thermistor may be cut the connection.
Jun 14, 2009 | DeLonghi DE500 Dehumidifier
Sonamp 260 cuts out
Normally this denotes a protect condition. Remove the speaker wires from the back of the amp and see if the green light stays on. If this fixes the problem, then there is a short circuit in your wires, speaker level volume control or speakers. The amp sees the short and goes into protect. After a couple seconds it closes the connection again and if the short is still present it goes back into protect.
Aug 03, 2008 | Sonance Sonamp 260 MKII 2-Channel...
Drum track
From your description it sounds like you recorded the midi drum patterns to a track first and then playback from that track is giving you problems. If this is the case it sounds a lot like a bug that existed in the firmware prior to release 1.02 where edits could cause gaps on tracks. You can check your firmware version on bootup and if you don't have version 1.02 installed you can get the firware and instrustion on how to upgrade it here:
http://www.tascam.com/details;8,16,5,19.html
Feb 13, 2008 | Tascam 2488 Portastudio Multitrack...
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
