I have a separate unit for ac then I do for heater
I have a separate unit for ac then I do for heater I'm trying to install a new Honeywell in from the old intertherm both are electric the problem is I have 4 wires connected on my old one they are the R,Y,W and A what is the A wire for help please
  • 1,253 Answers
My guess is antocipator... not used on new thermostats.
Posted on Nov 26, 2014
  • 1 more comment
  • david walter Nov 26, 2014
    What is the antociptor
    I can't send a pic but all it shows is GYWR going to its location 9n the thermostat that's it
    I tried searching up what it was or what all the wires meant and we're used for and nothing I seemed mentioned anything about the A wire
How can I connect an Intertherm furnace with a heat pump to a new Honeywell thermostat?
Ensure that that thermostat is for a heat pump and has connections for the emergency heat strips.
Feb 02, 2016 | Heating & Cooling
My Honeywell Themostat is no longer controlling the systems after a battery change, but otherwise looks fine. Help!
The replacement batteries could be defective or installed incorrectly. Also, if the thermostat has to be removed from its mounting base for installation of replacement batteries, it may have been reinstalled incorrectly.
Nov 07, 2015 | Honeywell Heat/Cool Thermostat
Honeywell how to install
Did you try E too aux and x1 to c?
Jul 20, 2014 | Honeywell RTH6580WF Wi-Fi Thermostat
Intertherm Heat Pump
Some of the old heat pumps made the reversing valve in the heating mode. On your new thermostat the orange wire will need to be on the B terminal. If it was color coded? I hope you made notes of how it was.
Jan 05, 2010 | Heating & Cooling
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
As I was cutting weeds away from my outdoor ac unit, I accidentaly cut through a small wire that has a red and white inside of it, we wired them back together and still have no ac or heat or air, we just...
first try turning off the power to the furace for 15 sec and tunr it back on (reset the computer) you may have blown a control fuse on the contol board inside the furnace, turn off power and becareful of hazardous voltage conditions
Aug 15, 2009 | Intertherm P3RA-048K Air Conditioner
Intherterm retro fit kit
Intertherm lists dealers here: http://www.intertherm.net/
Depending on how old you may be out of luck.
Apr 26, 2009 | Procom (177653) Utility Heater
Change thermostat
You have caught me without my old books, but I can tell you the orange wire is for the reversing valve on a heat pump. Almost all manufacturers, except for Lennox, are: R=Power (24volts), G=Indoor fan (Blower), Y=Cooling (A/C), and W=Heat. Some t'stat's are set up to use 2 separate transformers (24 volt), that is why you will see Rc, Rh. This is power for cooling and power for heating. If this is what you have, just take the Red wire and strip it back far enough to go under both screw terminals if the unit is a residential one. I've been doing commercial work for over 20 years and have never seen an "A" terminal, so I can't help you there. You may want to double check that. If I'm reading you correctly, I would put the orange wire on the "O" terminal. Don't understand why the "Y" terminal is not used. It turns on the compressor. The "O" goes to the reversing valve to "Tell" the outdoor unit that it is either in the cooling or heating mode.
Good Luck and let me know if I can help any further.
Feb 19, 2009 | Honeywell Programmable Thermostat Heater
Household Thermostat Replacement
you have to configure the thermostat to run the fan when there is a call for heat. look at the installation instructions and they shoud ask you if it is gas or electric heat if its electric then you are gong to have to configure it to makr e the fan come on with the heat. Good luck
Jan 25, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
