Question about Sennheiser Hsl10 Handset Lifter
My lifter wont lift
Its all set up but wont lift
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 61 Answers
Check the battery level.
Posted on Nov 26, 2014
Wanting to put new cam in my 95 ranger xlt v6 4x4. What RV cam can i put into it with out changing the lifters
I would change the lifters as well as thay will have wear on them, if your going for a high lift cam wouldn't you fill better that you've renewed both and fill you wont suffer any problems in the near future that both have been done together good luck colin
Jun 10, 2017 | Cars & Trucks
How do I set the lifters on a 1995 GMC pickup?
Before starting first put engine on #1 TDC compression stroke. Adjust #1 rockers such that you have zero lift (push rod will spin by hand but just barely), then tighten additional 1/2 to 3/4 turn in 1/4 turn increments with time for lifter to pump down between turns. A shop manual will tell you which others you can set at this same time (I forget). Then rotate engine one full turn and set the rest. I like to then run engine until warm and while at idle and using clips that cover the hole in each rocker arm where oil squirts out, I loosen each rocker one at a time (engine running) until rocker starts to click, then in 1/4 turn increments I tighten them for final preload depending on what lifters I am using--some need 3/4 turns to center lifter, some need total 1 turn. All this will be found in any cheap shop manual.
Jun 23, 2015 | GMC Cars & Trucks
ERROR 0X00000709 PRINTER HP CM6040F MFP
hi,
Error related tray lifting....just check which tray is not lifting and find "is there any kind of abstraction to lift the tray".
Then just refix the tray lifter assy. connector otherwise replace lifter assy.
hope it will help.
Feb 04, 2014 | HP LaserJet Office Equipment & Supplies
HP LJ 4200 does not lift the paper deck, but goes to ready state
If the paper does not lift, remove tray 2 and look inside to your right and you will see the paper lifter. Make sure the spring has not fallen off the lifter. You may need to replace the lifter. Also try lifting the paper deck by hand to make sure there is no obstructions in the tray itself.
Jul 30, 2013 | HP LaserJet 4200 Printer
Power liftgate will not open with remote, instrument panel control or button in rear cargo on lincoln mkx
It can be faulty switch or its issue with lift gate latch.Its got stuck up hard or cracked inside.It has to be inspected.-----------
There are few help links with proper solutions for these problem.I suggest you to refer the links.
Click the link below:----
2007 Mercury Mountaineer: Liftgate will not Unlock or Open? http://whoisbyme.blogspot.in/2012/06/2007-mercury-mountaineer-liftgate-will.html
Adjust Hydraulic Lifters? http://schematicsdiagram.blogspot.in/2012/04/adjust-hydraulic-lifters.html
How to open rear lift gate? http://repairhelpcenter.blogspot.com/2011/12/how-to-open-rear-lift-gate.html
--------- Power Liftgate Shuts Down http://whoisbyme.blogspot.in/2012/07/power-liftgate-shuts-down.html
------------ Power Lift Gate Will Not Remain Open http://whoisbyme.blogspot.in/2012/07/power-lift-gate-will-not-remain-open.html
----------- Power Lift-gate will not Operate http://whoisbyme.blogspot.in/2012/07/power-lift-gate-will-not-operate.html
------------- Liftgate will Not Stay Up Open? http://whoisbyme.blogspot.in/2012/07/liftgate-will-not-stay-up-open.html
---------------- Rear Door will not open http://whoisbyme.blogspot.in/2012/07/rear-door-will-not-open.html
------------ 2000 Toyota Corolla: Rear Door wont open from outside or inside? http://whatisbyme.blogspot.in/2012/05/2000-toyota-corolla-rear-door-wont-open.html
These details will help.
Thanks.
Nov 25, 2012 | 2007 Lincoln MKX AWD
What is a hydrolic lefter
Never heard of it. Perhaps you are referring to a "Hydraulic Lifter," which is a hydro/mechanical device that transfers lift from the camshaft via a push rod to a rocker arm that pivots to open and close the intake or exhaust valve. Oil pressure fills the lifter with engine oil to automatically set the valve tappet clearance, which would otherwise be done by hand if the lifters were solids.
Don't know if this helps, but I tried. Youse welcome from Minnesnowta.
Aug 05, 2012 | 2003 Ford Explorer
I have an activa 130 and the foot won't go all the way down
Is your machine fitted with a knee-lifter ? If so, its possible the knee-lift mechanism has got stuck, which will prevent the foot from coming all the way down. It's also possible that the foot lifter bar has slipped which will require re-setting. When the foot is lifted and the feed-dogs are dropped, there should be a clearance of about 7.5mm between the underside of the foot and the stitch plate.
Mar 02, 2012 | Bernina Activa 130
Lifter moves, but doesn't reach the tonearm
it was probably lifted with the arm locked in the cradle.there is usually a set screw on the side of the arm lifter to adjust the height.it is on the lower half on most,so removing the bottom cover of the turntable is needed.loosen the screw and slide the piston up until it almost touches the arm in the down position.that way when you raise the lever,it will raise the arm. lift up the rubber mat and tape the platter to the side of the unit so it does not turn or fall,if you do not want to remove it .
Oct 23, 2009 | Numark TT200 Turntable
The Headset will no longer activate the handset lifter module
A few things you can do: 1. Make sure that the lifter isn't lifting the phone too high.  To change this, look at the back of the lifter, there is a switch that goes from low to high.  Make sure that's at the lowest setting.
2. Try a reset.  To re-set this unit hold down the minus button on the headset and the call answer button at the same time.  Hold them both until you see the orange light by the call answer button flash a few times.  It should then go off.  If it doesn't go off after 10 seconds release both buttons and push the minus button once more.  The light should now be off.  Put the headset back in the cradle and try again, it should work now.
Mar 19, 2009 | Plantronics CS70 Wireless Headset
Won't Stay Connected to Calls
It's probably a problem with the lifter.  Try a re-subscription on the system (refer to user manual).  Also make sure that the lifter is lifting the handset far enough off the base so that there isn't much weight pushing it back down.  There are 3 settings on the lifter (Look at the knob on the back of the lifter).  Low, medium and high.  Try setting it to medium.
Aug 01, 2008 | Plantronics CS70 Wireless Headset
Sennheiser Hsl10 Handset Lifter Logo
176 people viewed this question
Top Sennheiser Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Sennheiser Radio Communication Expert? Answer questions, earn points and help others
