Comcast dc50xu - need instruction book for the remote control, i can change channels with it , but must use the tv remote to turn on/off and volume,needto use one remote- comcast to do all functions
All
  • 1,249 Answers
Go to xfinity dot com. they have a well designed web page that will help you find your codes and program your remote.
Posted on Nov 26, 2014
  • 3 Answers
SOURCE: Need set up code for universal Comcast controller
I had to buy the Sony Rm-AX1400 and it learned the codes from the old remote. I found it at Bestbuy for 20 bucks. Look on ebay for one.
Mike
Posted on Apr 03, 2008
futureloginn
  • 734 Answers
SOURCE: Remote Codes for new Sony Bravia
0000 worked for my XBR4 using the remote called: Comcast Custom DVR 3 Device found here:http://www.comcast.com/corporate/customers/customer_support/remotes.html
Posted on Nov 17, 2008
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
waynejamescm
  • 67 Answers
SOURCE: LG TV renote not worknf on 4 new sets
If you have a cable box (otherwise known as a set-top-box) that you have to turn on when you turn the tv on, and you use to change your cable channels, the LG remote will not control it. The LG remote is strictly for the tuner built into the television, and is not capable of controlling the cable box.
You probably see "function not available" because you are viewing the picture on an external input of the tv (component, composite, etc). Your tv cannot tune stations in when it is set to an external input that you use to watch DVD's, cable boxes, games, and other devices. The tv is telling you that you can't change channels if it is on an input.
I hope this helps you...
Posted on Jan 20, 2009
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
Olevia channel setup
With the remote of dish you will control the dish box. The tv control is only necesary to set the signal on channel 3 or Aux to get the signal from the dish box.
Now Your main remote will be dish remote control. Set your tv on channel 3, then turn on the dish box, and use normally.
Oct 02, 2008 | Olevia LT26HVX 26 in. LCD Television
Trying to connect with Comcast using comcast remote. have idetified correct code and and can turn TV on & off with remoet but can not get channels to change .... just get static no picture ??? Can...
The Comcast remote only changes channels on the cable box. not the tv itself. If you have a cable box then the tv will need to be turned to channel 3 or 4.
Apr 11, 2011 | Quasar VV-1302 13 in. TV/VCR Combo
How do you remove closed captioning from a Durabrand DWT2405 24'' TV with a comcast universal remote control?
jess_in_tene, Comcast, or for that matter most other universal remote controls are limited in their capabilities to control other devices! They will at best have only the basic three functions: ON/OFF, VOLUME up/down, Channel up/down, and maybe channel change by numeric keypad entry. Nothing More! The COMCAST set top cable box sends the CCs to the TV regardless. It does not have the capability of "striping-off" the CC information from the signal that enters the TV. You will need to find out who turned-on CC mode for the TV and WHAT remote they used to do it with. Please note that some TV's go directly to CC mode when the TV is in the MUTE mode. Hope this was of some help. 12fixlouie Please rate this response on fixya if you found it to be helpful. Bye for now.
Oct 26, 2009 | Televison & Video
Need code for Audiovox LCD TV (Model LCD1900W) for COMCAST DTA
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off
Aug 28, 2009 | Televison & Video
Need codes for a comcast universal remote (for a symphonic tv)
I have trouble changing channels in my tv please somebody help me
Jun 24, 2009 | One For All URC-3021 Remote Control
Where to get remote codes for Comcast?
there are a couple of ways to go about it... you can either do a code search with the remote by pressing the tv button then hold down the setup button until the tv button blinks twice. Then press 991 the tv light will blink again then press 1 and then power. then you would press the channel up button until the tv turns off. Then press set up and that will lock in the code. If you pass the code and the tv will not power back on through the remote repeat the same process but press the oppisite channel direction. The other option is search google for your tv code.
Jun 23, 2009 | Insignia 720p Widescreen LCD HDTV
I was able to program my Comcast remote to control the volume of my tv, but was unable to get it to change channels. Is there something else that I should do?
Controlling the TV power and volume is probably all you'll be able to do with that control. The Comcast remotes are meant to be used with their converter boxes, and normally people want to change channels on the box while the TV stays on the box output channel (usually 3, sometimes 4). The remote's channel up and down buttons and number keypad only send out the codes recognized by the converter box. You'll need to fall back to the TV remote if you want to control more than power and volume.
May 04, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Remote control codes
how do activate sharp tv to a comcast remote to change the regular channel on he tv im trying to turn to channel 3 but when i turn from the tv it skip from 2 to 5 then so on.
Feb 19, 2008 | Televison & Video
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
Electro Med Services...
