Question about Garden
Starts and runs well but the longer it runs it lacks more power, after an hour or so it barely revs up.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,917 Answers
Bad valves need valve job done on engine
Posted on Nov 25, 2014
BMW 320ci. Runs perfectly 1st start can run for 1000's miles no issues. 2nd start car takes longer to start,delayed throttle response,lacks power climbing hills prone to cutting out as revs drop.
sounds like crank sensor or cam shaft sensor. Internal resistance due to heat, hence why you can start and run car in morning, ie cold. When the heat build errors start. Get codes read first but I would suspect these 2 sensors. Yo can also get fault new parts, so you might be one the right track.
Dec 22, 2016 | BMW 320Ci Cars & Trucks
My ed falcon 5.0l runs but won't rev & lacks power Have replaced air flow meter as it runs better with it did connected Checked computer for damage & condensation & foreign debree But can't find the...
have the fault codes read as it may be a combination of faulty sensors causing the problem. The ECM fault reporrting process is there for a purpose and that is to pinpoint the fault and to save money.
Jan 24, 2015 | Cars & Trucks
I have a pw50 it starts fine and runs fine but doesn't seem like it has any power it barely pulls itself when I run my nitro fuel from my rc car through it it does a lot better but still not very good...
Its probably getting too much or too little fuel or air. if the intake filter and passage are clean, then you might wanna get a kit to rebuild the carb. There's a little jet that allows a certain amount of fuel in and the arm that holds it can bend over time making lack accel during rev. when you pull it apart it looks kind of like a mini metal pencil generally with a rubber tip. you need to the kit to fix it, but sometimes old gasket will come apart.
Jul 23, 2012 | Cars & Trucks
Husqvarna 266xp issues.
As the saw runs out of fuel the revs increase due to lean fuel mix, so would guess the saw is not hitting its 12500rpm at full revs, this is either a blocked air filter or the carb adjustment, the revs should be checked with a suitable tacho before leaning off the H screw on the carb, increasing the revs beyond 12500 could result in a cylinder seizure.
Jul 15, 2012 | Husqvarna Garden
Sometime car barely starts runs rough till rpm's build up
Check everywhere for air leaks. If it has a carburettor start the car and spray butane gas around it, if the revs increase then you have a leak somewhere as it is sucking in this extra fuel.
Mar 18, 2012 | 1995 Buick Park Avenue
92 accord engine/rpm/lack of power problem
i had the same prob on a toyota check out the fuel presure if its good its prob the fuel regulater i think it should have around 32 psi but call and double check that
Feb 27, 2012 | 1992 Honda Accord
Dt 230 low on power.bike gets half revs then runs
Hi there, you likely still have the restrictor in the exhaust header. Mine was the same, they are shipped like that as standard. Take the exhaust off the engine and remove the the concentric tube that's in there (you need to cut it out). Instant +100% power, if that is your problem.
Jul 18, 2010 | 2002 Yamaha DT 125 R
GE TBF 17DB 17,2 cu.ft. refrigerator/freezer runs continuously.
Set both controls to their middle settings. Put a glass of water in the frig with a thermometer in it and check the temperature in 48 hours. I is normal for the newer appliances to be on longer than off. Power consumption is highest during start up and it is more efficient to start less often and run longer. When adjusting controls ONLY change one by one number and wait 24 hours before making another change.
Eric
Apr 18, 2010 | Refrigerators
My gfs 1999 blazer starts up, revs very high then shuts down. Any suggestions?
Sounds like a possible lack of fuel problem. Remove air intake hose from front of throttle body, then try spraying (carefully ) a little WD-40 into front of throttle body when it starts just to see if it will keep it running a little longer. If it does, your lacking proper fuel supply. Do you hear pump cycle (hum) when you turn the key to on position? I guess a good place to start if it is lack of fuel would be to change fuel filter. If it turns out to be something worse like pump, your going to want that filter changed anyway.
Let me know what you find.
Aug 04, 2009 | 2000 Chevrolet Blazer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
