Question about GPS
How do I replace battery in my GE 214 light meter?
I have it apart but see no pace for battery. Does it take a battery? What is the number and where may purchase it. Tom
  • 36 Answers
Tom,
Just do a yahoo search for ge 214 light meter manual and you will find a list where you can download the manual for free. (I just did it but didn't download the manual) It should tell you in there. Garcuda
Posted on Nov 26, 2014
    Sergeant:
  • 271 Answers
It does not need a battery. It uses the light to generate the power like a solar panel to make the needle move.
Hi. I have a GE range model CGS985SET2SS. I need a new valve assembly due to over tightening the appliance connector hose. I see conflicting info on the web. Is WB19K10043 the correct part?
Hello. The valve, part designation 1600 on the exploded parts diagram is called a "lockout valve" and has the part number WB19K10059. It may cross-reference to another part number--that is common. The control valve, part designation 214 on the diagram is part number WB19K10079. I hope I helped you!
Aug 03, 2015 | GE Kitchen Ranges
I'm trying to find the correct battery pack for a Commtel com 214 scanner.Unit says 12v dc.??
The 12vdc refers to the charger you need,
The battrey is a rechargeable internal battery and you just need to find a 12v charger,
ebay "commrel 214 scanner charger" to buy it
if you do need a new battery the model number is bp-120
here is a link to pictures of the battery and EVERYTHING you need to know about the scanner
http://radiopics.com/Commtel/Commtel_COM214.htm
Dec 26, 2014 | Office Equipment & Supplies
Ge spacemaker laundry dryer does not heat
All dryers have states to control heat GE has a safty stat that is comon problem small round stat at top after removing lid check with ohms meter with wire unpluged if no continuity changed then check venting of dryer inside and out improper venting will cause dryer to over heat
heat element is the next go to same check but must take dryer apart more send model Number we can give you a diagram and location of everthing you will need
Jan 30, 2013 | GE Spacemaker Washer and Dryer Electric...
Im a shopkeeper,... 1100 model mobile does not work properly when battery is paced on it but it works when i test it from the meter which section should i cheak first
check battery connectors of your phone,clean and pull carefull to better contact with battery.also clear battery connectors of corosion.
Dec 10, 2009 | Nokia 1100
MY GE mircrowave runs & light comes on but does not heat food, wh
Sounds like the magnetron has failed. This is the component that produces the microwave that heats the food. The cost of the magnetron is about 95% of the cost of a microwave . Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing. There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Jun 25, 2009 | GE Microwave Ovens
My GE Turntable microwave has power, lights come on, and timer works, the heating device doesn't come on
moz-screenshot-2.jpgSounds like the magnetron has failed. This is the component that produces the microwave that heats the food. The cost of the magnetron is about 95% of the cost of a microwave . Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing. There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Jun 21, 2009 | General Electric Microwave Oven
GE Profile Convention Light Bulb Not Working after Replacement
With a volt meter you must verify power to the door light switch and the light socket.
You can also unplug the oven and do this with a meter set for continuity.
Feb 17, 2009 | GE Profile JTP18 Electric Single Oven
Changing the LCD
that is usually caused by a message waiting light being turned on from an extension, the message waiting feature can be used to call voicemail or to call another extension, enter code #409 on ext 214 to cancel the msg waiting light
Mar 18, 2008 | Toshiba DKT-2020 Corded Phone
GPS Logo
96 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
