I have a jvc 32inch tv and the on and off power button is missing i cant turn my tv wont turn on or off i bought a universal remote and my tv is still not coming on
    Habit-Forming:
  • 86 Answers
Program the universal remote following the instructions manual for that model TV. Usually holding the power and TV button until the TV power light comes on. Or, try the combination codes for that model TV.
Posted on Nov 25, 2014
    Scholar:
    New Friend:
  • 104 Answers
Can you use a toothpick to turn the power on. The remote will not work if the t.v. is off. CAUTION: Do Not use anything metal! Use insulated gloves to do it. Then follow the instructions for your remote, and you should be fine.
Thank you for contacting Fixya.
Does this help? Let us know.
Mary Oliveau Xx's
  • james turner Nov 25, 2014
    its missing the whole insert inside the tv
  • 28 Answers
SOURCE: universal remote
try http://www.chunghop.com/en/customer.asp and download the instructions and code for your tv. you'll need WinRar to open the files, search google to download it.
Posted on Nov 09, 2007
  • 95 Answers
SOURCE: RCA universal remote
This is the eastest way to program your remote. To program a component using the Automatic Code Search method, perform the following steps: 1. Turn on the component you want the remote control to operate. 2. Press and release the component button that corresponds to the component you want the remote control to operate. info.gif The illuminated ON-OFF button turns on and remains on.
aud_remote_on-off.gif 3. Press and hold both the component and ON-OFF buttons. info.gif The illuminated ON-OFF button turns off. 4. After the illuminated ON-OFF button turns back on, release both buttons. info.gif The illuminated ON-OFF button remains on. If you press an invalid button during Auto Code Search, the illuminated ON-OFF button blinks four times and turns off. The last programmed code under that component button is retained. 5. Press and release the PLAY button. aud_remote_play.gif 6. If, after five seconds, the component does not respond, continue to press the PLAY button every five seconds until the component turns off. info.gif Each time the PLAY button is pressed, the illuminated ON-OFF button blinks ten times while a block of 10 codes is sent to your component. This process continues until all of the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited. 7. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again. info.gif If the component does not respond, continue to press the REVERSE button every two seconds until the component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks. aud_remote_reverse.gif info.gif If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again. 8. To save the new code, when the illuminated ON-OFF button turns off, press and release the STOP button. aud_remote_stop.gif info.gif If some of the features of your component do not work, different codes in the list can be tried until you find the code that allows the remote to control the majority of your component’s
Posted on Mar 16, 2008
  • 5 Answers
SOURCE: RadioShack Universal Remote (Cat. 15-2147) - to use with JVC TV
programming a device: make sure batteries are installed correctly. Turn device on(for ex., your TV). Press TV button next to Power button on your 15-2147...Press and hold the little P button until the red LED lite blinks twice...enter the first four-digit code for your device(in your case,JVC TV...first set of #s is '0463' ) note: the LED will blink once as each number is entered. If the number is correct the LED will blink 2x. Note if the LED doesn't blink twice after entering the 4 digit code, begin again with the next set of numbers. For JVC the codes are 0463 and 0053. Once your remote blinks twice after entering in your TV code, press the power button. This should turn off your TV. Just use like any other remote. Hope this helps you.
Posted on Oct 12, 2008
SOURCE: rca big button universal remote
Go to: www.rca.com then .... accessories..... (On the left of the page) go to owners manual ..... also check for your code under .... code look up.... if your TV is not listed, use the search feature outlined in the owners manual
Posted on Jan 30, 2009
  • 52 Answers
SOURCE: Need code for Jvc tv by using RCA remote
google the remote model number and you should find all the codes
Posted on Jun 30, 2009
I jus bought a universal remote for my HiSense 32inch full hd LCD32v88peu and can't seem to find the code any help pls.
Hi, Try this and good luck
1. Turn the TV on.
2. Press the TV button on the top of the remote.
3. Press and hold SETUP until the LED light blinks twice.
4. Press 9 9 1 and the LED should blink twice again.
5. Press the POWER key on the remote.
6. Press CH+ repeatedly slowly until the TV turns off.
7. Press SETUP when the TV turns off.
Jul 26, 2011 | Televison & Video
I just bought this tv with no remote. did some research online and bought a vizio universal remote. it works but i cant change the aspect ratio the tv wont go into widescreen
Tvs universal remotes u get what u get there alway somethings missing or funsctions improperly.That why u don't exspect perfection on those tvs univeral remotes,just the tv remote basic funsctions only all of the times.Try website like Remotes.com to buy the tv original remote.
Jun 18, 2011 | Sylvania LC320SLX 32 in. LCD TV
I have a jvc television and bought a universal remote. i dont know the code for the remote. do you know the code?
These are the steps on how to program your Universal Remote Control to your JVC TV even without the list of code.
1. Manually turn ON your TV.
2. Press and "HOLD" CODE SEARCH
3. Press and release the TV button you want to set up
4. Release CODE SEARCH.
5. Press OFF/ON repeatedly until the TV turns off (you may have to press up to 100 times at a rate of once per second).
6. Once the TV turns off, press and release ENTER.
7. With the TV on, press any other button. If the TV responds, no further programming is required. If the TV does not respond, repeat steps 1-6.
Jun 14, 2010 | JVC RM-C18G-1H Remote Control
Programming problem
a universal remote control is programmable without codes using this general process:
  • push and hold 3 sec the button set up
  • select the device to control (TV DVD etc)
The tv has to be ON at this step (use the power button in the tv front panel
  • use the remote control power button and try to get your tv pushing the button again and again and again
  • Caution! Go slow because when finally the tv turns on you have to push enter in the remote control to save this code that actually is the one the tv needs,
Apr 14, 2009 | Radio Shack 15-2142 Remote Control
JVC AV-32870 Power button is missing
I had a friend that had the exact same problem! We did use a remote to turn the tv on and then it was a matter of setting up the menu settings. It was trial and error, but it was worth it. As far as getting the power button replaced, I would recommend call and ask a TV repair person - but the remote worked just fine for my friend.
Jan 06, 2009 | JVC AV-32820 32" TV
Jumbo Universal Remote
I have a Motorola DVR from Comcast. Code 051 will make all the cable functions work. Haven't figured out how to do anything with the DVR bits,
Dec 26, 2007 | Universal Remote Control NspireGear MP3...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
