Question about Kitchen Appliances - Others
How do I stop rice water from boiling out of the closed rice cooker. it is very starchy.
I have thoroughly washed the rice to avoid starch & cleaned the cooker always. I do not have a manual. All writing on the machine except "Sharp" is Asian.
  • 57 Answers
Check the voltage of the cooker is not being exceeded. .
Posted on Nov 25, 2014
Testimonial: "Thanks Henry. I think thats okay, good thought though. I'll get my son to check it."
  • 1 more comment
  • Henry OTani
    Henry OTani Nov 26, 2014
    Japan apparently has 100 Volt domestic supplies whereas the USA is120 Volts. If its.
  • Henry OTani
    Japan apparently has 100 Volt domestic supplies whereas the USA is120 Volts. If its supposed to be 600 Watts then connecting a Japanese rice cooker to 120 Volt will make it run at 900 Watts which I imagine could make it a bit more 'vigorous' than normal. South Korea, China and Europe are in the 220 - 230 range... Japan must have the lowest domestic voltage anywhere in the world... but it is very safe and does make the calculations easy I suppose . :)
  • Henry OTani
    There may be Arabic Numerals buried in with the Asian Script written on the service label. 50 or 60 Hertz (Hz). The Wattage (typically 600W) The Voltage (120V) ... ~ denote Alternating Current (AC) ...
SOURCE: Rice burning at bottom of cooker
I also have this problem and I fixed it by adding in a little more water and by removing the power cord from the outlet immediately after the cooker finishes it's cycle. Not ideal, but it does save my rice.
Posted on Apr 28, 2008
SOURCE: Salton RA3 3-Cup Rice Cooker Question
Put equal amounts rice and water (up to 3 cups only) in liner pot, plug in, put lid on, flip little front switch. 10-15 minutes later it will be done and the pot will switch to "warm" mode by itself. Gently fluff with paddle before serving. You can also add salt or other seasonings to the water/rice mixture before starting.
Posted on Dec 10, 2008
ginko
  • 19396 Answers
SOURCE: Wolfgang Puck 7 cup rice cooker instruction manual missing
Here the standard manual : WOLFGANG
However you can read and print recipes online from their website , click below:
Rice Cooker Recipes Cookbook : Recipezaar
Rice Cooker Creations Cookbook
Posted on Feb 27, 2009
pabloloco
  • 2335 Answers
SOURCE: Rice Cooker Instructions
For Queenmom and anyone else looking for the manual for a Black and Decker Flavor Scenter Handy Steamer Users Manual, I just stumbled across one. Here's the link:
http://useandcaremanuals.com/pdf/HS90038.pdf
I hope that helps.
Posted on Sep 19, 2009
SOURCE: english usermanual Sharp KS ZA 101 ricecooker
The solution is that I will find a thai friend that will translate the manual for me....and not ask money for a service that should be delivered with the cooker!!!!!!!!
Posted on Oct 15, 2009
Testimonial: "so, I helped myself and you sent me an email saying somebody had a solution for me! Very helpfull indeed!"
I just bought a rice cooker at a garage sale. It had no instruction manual
To make rice, remove the trivet if you have one as this is only for steaming food.
Wash rice to get rid of excess starch and put in pan. Then add the same amount of water as rice (2 cups water to 2 cups rice etc.) then shut lid and switch on and leave it.
Once it has switched off do not open the lid for a further 20 minutes (the machine will keep the rice warm do not worry) Stir rice and serve. Most rice cookers will keep the rice warm for a couple of hours.
If you find the rice is a bit dry then add a little bit more water, the amount of water really depends on the quality of rice used.
Sep 20, 2014 | Krups Kitchen Appliances - Others
The cooker clicks over to "keep warm" before the
You're probably using too much water. Rice cooks primarily while sitting in hot water, not while its boiling. That's why the cooker switches to Keep Warm so quickly. The correct way to cook rice is to pre-soak the rice for about 30 minutes, drain to get rid of the excess starch, combine the rice and cold water and bring the water to a boil and turn off the heat and let it stand for 15-30 minutes. That's why*- rice cookers take 45 minutes or more.
Sep 06, 2011 | Aroma ARC-914 8-Cup Rice Cooker
Do you use hot or cold water. It doesn't say in the manual
I have used both hot or cold water....but have found that hot water works best to rinse the starch off and also makes the cooking process go faster...
Here is a tip that will help you figure out about using a rice cooker...
How much Rice and Water go in the Cooker
heatman101
Feb 23, 2011 | Black & Decker Black Decker RC3406 6Cup...
Breville RC3 Rice Cooker and Steamer Leaves starchy mess on work top when cooking rice, am I doing some thing wrong?
Thats normal when cooking rice!
If you dont want these starchy mess, try to cook less rice so that boiling water won't come off from the cover!
Nov 06, 2010 | Breville Kitchen Appliances - Others
Whenever I make rice, water comes bubbling out the top while it's cooking, making a huge starchy puddle on my counter. I've replaced the lid, but to no avail. Any suggestions?
Probably too full. Try a smaller amount of rice and water and see if that corrects the problem. The rice swells and fills the pot quickly... Recheck your quantity.
Apr 19, 2010 | Wolfgang Puck BDRC0010 10-Cup Rice Cooker
Governor's Table Rice/Veggie Steamer
The link was broken. It is now at
http://www.rivalproducts.com/manuals/MANUALS/RCS200_43_68557881.PDF
Apr 09, 2008 | Salton RA7 7-Cup Rice Cooker
Wolfgang Puck 7 cup Rice cooker
THIS is a generic manual and can be a guide for most cookers/steamers.
The rice and water go into the Inner Pot, Not the steamer basket.
Some useful tips:
  1. How can I reduce or stop the rice from sticking to the bottom of the pan or browning excessively?
    • Before cooking, rinse rice in warm water until water becomes clear. Then place the rice in the inner pot with fresh water.
    • Take care to use proper water to rice ratios.
  2. How can I stop the water in the inner pot from boiling over the lid?
    • You may be using too much water.
    • Use a 1:1 ratio of rice to water plus ½ cup of water for white rice and a 1:1 ratio plus ¾ cup of water for brown rice.
  3. How can I clean my rice cooker?
    • Unplug and allow to cool completely.
    • Always exercise extreme caution as the unit becomes hot during operation.
    • Soak the inner pot in hot, soapy water for a few minutes.
    • Wash with a non-abrasive pad.
    • Wipe the heating base with a damp cloth.
    • All other items can be washed with soap and hot water.
    • NEVER use an abrasive cleaner or steel wool.
    • Note: This unit SHOULD NOT be put in the dishwasher,
  4. How does a rice cooker know when to ‘Keep Warm’?
    • The boiling temperature for water is 212°F.
    • As soon as all of the water has evaporated the temperature inside the inner pot immediately rises.
    • Rice cookers have a Keep Warm Setting that can detect when the temperature rises above the 212°F.
    • When this happens it automatically turns to the Keep Warm Setting.
    • This helps to ensure perfect rice every time.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Apr 01, 2008 | Kitchen Appliances - Others
6 cup rice cooker
its very easy if you put 6 cups of rice= 6 cups of water
5 cups rice = 5 cups water ...equal proportion
Jan 06, 2008 | Rival RCS200 20-Cup Rice Cooker
I hope that helps.
Dec 26, 2007 | Cuisinart CRC-400 4-Cup Rice Cooker
Kitchen Appliances - Others Logo
67 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
