Question about Samsung Televison & Video
My Samsung tv hp-t5054 no picture, not sound blue light blinking 5 time an stop keep on
    Master:
  • 373 Answers
The capacitors on the power supply need to be replaced. When you take apart the TV, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video on how to replace capacitors. Check for warranty service first if still under the mfr warranty or extended warranty.
Posted on Nov 25, 2014
lukster
  • 217 Answers
SOURCE: blackout problems
It could be the LVDS cable that is connected between the logic main board and the main board, sometimes this cable is too short and comes loose from one of the boards, it could also be a sign that the logic main is going out or the panel itself is shorting out
Posted on Feb 17, 2007
electronick
  • 505 Answers
SOURCE: pioneer elite 50 plazma tv
this is a power supply.. you have to replace the board to fix. price depends on model but on the old ones its $$
Posted on Jan 09, 2009
  • 34 Answers
SOURCE: lg 42inch plasma
Sounds like main board failure and or power board failure. You need to contact manufacturer and describe problem for tech support. Some of the parts in Samsung TVs have lifetime warranties. Change out of two board is about an hour job and service call is usually comped. Hope this helps. J
Posted on Apr 09, 2009
redgs95
  • 15 Answers
SOURCE: 50 inch Plasma Samsung HP-T5054 appears to have power however...
check the power inverter on the power strip. also check the caps on the board and if any of those caps have a round top it is bad and needs to be replaced. i hope this helps.
Posted on Jul 28, 2009
SOURCE: Samsung LCD TV doesn't power on, just blinks 5 times
After about 5 years the Samsung LCD televisions backlight fails which prevents the TV from coming on and the powerlight just flickers the backlight can be changed but it is often alot easier and cheaper to buy a new Television
Posted on Sep 23, 2009
I have the Samsung model: LN46E550F6FXZA, I can hear it power on, the red light on the front blinks 5 times then goes off. There is no sound or picture.
You will need to have it repaired, looks like the inverter board is broken. Google Samsung tv blinks 5 times, there's tons of threads.
Mar 09, 2015 | Samsung Televison & Video
50 Samsung plasma turns on got sound fuzz picture
Go in the service manual , find it on the internet and find what they say about the light blinking 5 times. Best of Luck! Serge Lavallee.
Oct 14, 2014 | Samsung 50 in. Plasma TV
Front Led Lights but No Clicking, Picture or Sound when I Plug it In.
If the front led is lit, the TV is on standby. Did you place the batteries in the remote correctly?
There might only be one button that turns the TV on/off (usually the red one in the top of the remote)
Did you plugin the picture feed cable correctly (VGA, DVI, Antenna etc.)?
Jul 06, 2014 | Samsung HP-T5054 Widescreen 50 Plasma HDTV...
Samsung hp t5054 light comes on but it has no pic, sound and does not click when plugged in
Check that all cables are intact and plugged in correctly. (VGA, DVI, Antenna etc.) Did you place batteries correctly?
There might only be one button that turns the TV on/off (usually a red button in the top of the remote).
TV power comes on but then I just get a blinking green light. No picture or sound.
Make sure your cable input is in properly. The TV might be going into a sleep mode if it not getting an input signal
Apr 03, 2012 | Philips Televison & Video
Samsung LA40A550 no picture and sound
Power supply board is dead.That the board,the power a/c cord go into it.Replaced the power supply board will solved ur tv power lite LED light indicator blinking and ur tv power will be stable and work again.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 04, 2010 | Samsung LA40A550 40 in. HD-Ready LCD TV
Jul 28, 2009 | Samsung Televison & Video
No Picture, power button blinks 5 times and just clicks
If you dont have the manual, download it from internet. It should tell you what the blinking light is indicating. My friends tv was blinking 3 lights around power button and the manual I downloaded correctly stated it was the lamp that needed to be replaced. I also found some other interesting info via the internet. There is a way to get into the Service Mode of a Samsung TV. Try doing a Google search for Service Mode for your model... Good Luck. PS the lamp itself was pretty expensive but installing it was not hard to do.
Jun 23, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Blue light on bottom of tv
This problem can be caused by a bad main board. I have only seen it one other time though. If the unit is under warranty I would have the board replaced, If not, it is fairly expensive and you may want to live with the light. Hope this helps
Mar 02, 2008 | Samsung HPT5054 50 in. HD-Ready Plasma...
Samsung hp-t5054
use the blue (p.size) button on lower left of remote control
Jan 13, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Televison & Video Logo
74 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
