Question about Intertherm Heating & Cooling
I have a 1987 Intertherm FEH-015HA electric furnace. The issue I am having is that my blower will not shut of unless I pull the disconnect. My thermostat will operate the heating elements like normal,
I have a 1987 Intertherm FEH-015HA electric furnace. The issue I am having is that my blower will not shut of unless I pull the disconnect. My thermostat will operate the heating elements like normal, the blower just never shuts of whether the switch is set to "auto" or "On" There is no AC on my unit
    Sergeant:
    Champion:
  • 234 Answers
You most likely have a bad fan limit / cycling switch. If you kill the power to the furnace see if you can trace the wires from the motor to where the connect to the switch. It looks like a round button with tabs sticking out of it for the wires to connect. Mark down where the wires were connected and take it to a HVAC business or furnace supply house. Be sure to have the model off the furnace with you so you can get the correct parts.
Posted on Nov 25, 2014
Testimonial: "Thank you. So this switch is different then the main switch that controls on and auto? from the motor the wires go into a 12 plug connector, from there it looks like they connect to sequencers or something?"
  • 49 Answers
SOURCE: Intertherm E1EH-015HA FURNACE no heat
Sounds like a downflow electric furnace? If so it sounds like you have 15kw worth of electric heat, you might have a defective heating sequencer, witch is what they call a dual on one plate.
Posted on Nov 28, 2007
flatech
  • 111 Answers
SOURCE: I NEED A FILTER FOR MY 1991 HOBILE HOME FURNACE
Best things to do is find your Return grill in the home.
Get a measuring tape and measure the Hole size with the grill removed, Or filterback grill whatever the case.
Then simply go to a home retailer with the size, or in rare cases you may want to consider a Hogs hair washable filter that can be cut to size, to fit it perfectly.
Posted on Oct 24, 2009
  • 6 Answers
SOURCE: I have an intertherm electric furnace FEH-A020,
The model of T-stat you gave comes up as a discontinued model on Honeywell's web site, but it looks to be a manual stat that type of stat would have to be wired with a summer winter switch with electric heat, allowing it to turn on the fan with a call for heat. If yours is a programmable T-stat you would need to select electric heat or in the installers set up change the default setting for fan from unit controls fan in heat to thermostat controls fan.
Posted on Nov 02, 2009
  • 127 Answers
SOURCE: Intertherm model# FEH-015HA It is no longer blowing heat
High limit safety device is probably tripped, it should reset automatically, also check other safety's for tripped condition, they look like small round device located in a variety locations through out the unit with two wires to each one, some have small push button resets located in the burner compartment area. If all the safety's are reset and check out OK the main control board may need replaced. One of the most common causes of high limit safety device trip is lack of air flow, Dirty filters, evaporator coils, malfunctioning blowers, closed supply air registers etc.
Note: High limit safety switches also go bad after being tripped to many times.
Posted on Dec 01, 2011
  • 12 Answers
SOURCE: I NEED A WIRING DIAGRAM FOR INTERTHERM FEH-015HA WITH ONLY 2 WIRES AVAILABLE FOR HEAT ONLY. THE WIRE ARE CONNECTED TO "W" AND "A" POST BUT THE FURNACE WILL NOT SHUT DOWN AT SET-POINT.
If it's only a two wire system, it should be on the R/RC and W. Fan should kick on automatically.
Not too familar with that unit
A is usally for a heat pump pick-up coil or heating element
Pay attention once you've rewired the t'stat. Make sure the blower goes on automatically. The most it should take is apx five min, even if house is really cold
Also, check the heater. It may have way more options for control. You will just have to run new t'stat wire to take advantage
Posted on Mar 06, 2013
Have 84 model feh-015ha heater comes on but motor wont start
should come on with first stage heat bad sequencer or motor.
Jan 30, 2014 | Intertherm E3EB010H Electric Furnac
Intertherm feh 015ha
Look at the "klixon" style heat actuated switches mounted on the fire box of the heater. One of them is not working.
Dec 29, 2013 | Heating & Cooling
either the heat strips, fusible links on elements or sequencers.
Sep 21, 2013 | Intertherm E3EB010H Electric Furnac
Mar 05, 2013 | Heating & Cooling
My furnace will not turn on it is a intertherm feh 015ha. Every time I turn on the breaker the fuse pops really loud in the furnace and turns it off again. How can I figure out what is wrong if I cant even...
I would suspect your evaporative motor (located in the furnace) is shorted.
To prove it - just disconnect the electrical wires to the motor and turn the breaker back on.
Most likely the breaker will stay on - which will tell you for sure that the motor is shorted.
Note: it's possible that the capacitor on your motor is shorted - but I doubt it. i would bet on the motor. In any event - you have a 'direct short' which is causing your breaker to pop, and I would bet it's the motor.
If it isn't the motor you will just need to find the 'short' to keep the breaker from popping.
Aug 06, 2011 | Heating & Cooling
I have a mobile home with Intertherm electric furnace model FEH-015HA. It will not stop running whenever it has power. We have to switch off the circuit breaker to stop it. The thermostat has been replaced...
You could possibly have a bad sequencer. Turn off the power and check the normally open connections with an ohmmeter. If they are not open then it is bad.
Dec 20, 2010 | Heating & Cooling
Disconnect assembly has overheated and needs replacement. where can I find a new puul-out disconnect assembly for my intertherm furnace model FEH-015HA-03
Those parts are readily available. You can get them at intertherm.com or google hvacparts.com and have your model and serial number ready. You are talking about the pullout at the bottom left of the unit correct. If you have a breaker within six feet of the pullout you can remove it. But be very careful and turn off all power before you try.Rus
Dec 04, 2009 | Heating & Cooling
I NEED A FILTER FOR MY 1991 HOBILE HOME FURNACE IT IS A INTERTHERM MODEL FEH-015HA-04 NOROYNE SERIAL FEH 9105-00229
Oct 21, 2009 | Intertherm P3RA-048K Air Conditioner
Blower will not shut off on furnace. I have a Intertherm FEH-015HA Central Electric Furnace
If your blower will not shut off from the thermostat, you either have a bad thermostat or your red and green thermostat wires are exposed to each other.
Feb 20, 2009 | Heating & Cooling
Nov 26, 2007 | Heating & Cooling
Heating & Cooling Logo
261 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
