Some of the buttons on my fx-9750 are not responsive and I bought a month ago, the keys are: (the up and right keys, f2, tan,log, x^2) please help, I already tried to reset it.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 147 Answers
You should return it to the store since it might still be covered by the return policy. Don't wait too long.
Posted on Nov 25, 2014
4 Suggested Answers
  • 8073 Answers
SOURCE: How to find the "!" button on Casio fx-9750 PLUS?
  • In RUN screen enter the number
  • Press OPTN
  • Then press F6> to go to next page pf TABs
  • Press F3:PROB
  • Press F1:x! and EXE
Posted on Apr 07, 2011
Elessaelle
  • 122 Answers
SOURCE: A week ago I bought
That because you're in GRA mode (so you're entering angles in gradians, not degrees). To go back to DEG mode (where angles are in degrees) press Shift, then press Mode and finally press 4.
Posted on Sep 05, 2011
  • 8073 Answers
SOURCE: my casio fx-9750 is stuck on T when I use the x, theta, T button. How do I get it back to x?
T is the default (independent) variable name in parametric function graphing. Change the graphing mode to function y=.
Posted on Jun 14, 2012
How come when i try to do inverse trig function on my fx-9750 gii calculator it says Ma error?
Just wondering if the other functions are working.
The manual references setting up angle unit and setting up the "comp for mode" in the setup.
The keys you should be pressing to do this calculation are on page 51 (2-31) of the attached manual.
http://support.casio.com/manualfile.php?rgn=5&cid=004002013
Good luck. If unsuccessful, please repost.
Paul
Nov 03, 2016 | Casio FX-9750GII Graphing Calculator
How to use tan^2(55)
It's a quirk of notation. When a book says tan^2(x), it actually means (tan(x))^2. Only the trigonometric and hyperbolic functions seem to get written this way. If one wants the square of a logarithm, for example, one doesn't write log^2(x).
The short answer: if you want tan^2(55), calculate tan(55) then square it.
Oct 15, 2014 | Casio Office Equipment & Supplies
How do you compute this using scientific calculator log tan 36 degrees 20 minutes?
You may want to insist on using the DMS (degree, minute, second) notation but since 20 minutes is 1/3 of a degree the value of the argument of the tangent function is just 36 and 1/3.
Make sure the angle unit is set to degree.
Set the calculator IO mode to MathIO: Press [SHIFT][MODE ][ : Degree]
Press the[ log] button: log(
Press the [ tan] function key tan (
You see on the screen log ( tan (
Type in 36 [a b/c] 1 [a b/c] 3
Close the two parentheses ))
Press [EXE]
You should get -0.13344355615
Aug 15, 2011 | Casio FX-115ES Scientific Calculator
  • Press OPTN
  • Press F3:PROB
Mar 26, 2011 | Casio FX-9750GPlus Calculator
How do you find sine cosine and tangent on a fx-9750g2 calculator?
First you must setup the correct angle unit (as required by the problem you are solving).
  1. Open the [Run] application screen.
  2. Press [SHIFT][MODE] to enter (SetUp)
  3. Use down arrow key repeatedly until you see the line Angle:
  4. Press the F1 key to select Degree as angle unit. or F2 for Radian.
  5. Quit the setup configuration screen to return to the main Calculator screen (RUN/MAT).
Once the angle unit is correctly set,
  1. Press the function keys [SIN], [COS], [TAN]
  2. Depending on what function you pressed, the command sin( or cos( or tan( is displayed.
  3. Type in the angle value,
  4. close the right parenthesis and
  5. press [EXE]
A result should be displayed.
Feb 13, 2011 | Casio FX9750GII Graphic Calculator
WHICH BUTTON SHALL I USE FOR EE OR EXP ANN ALSO FOR(+/-)
To enter an exponent of ten (EE), use the x^10^x key on the bottom row of the keyboard, between the decimal point and Ans keys. To raise a value to another value, use the x^ key to the right and below the circular cursor pad, between the x^2 and log keys. To raise e to a power, use e^x, the shifted function of the ln key on the rightmost column of the keyboard, between the logab and tan keys. To change sign (+/-), use the (-) key on the leftmost column of the keyboard, above the RCL key.
Feb 13, 2011 | Casio FX-115ES Scientific Calculator
How to solve for a factorial problem on a casio fx-9750g plus or buttons to press to get the ! how to solve for a combinations problems on a casio fx-9750 plus
There is no button but a menu tab.
In Run screen, enter the number whose factorial you want to calculate ( number can be at most equal to 69), press [OPTN][F6] to get to next page of menus.
For factorials
  • Press then [F3](PROB) then [F1] (x!) followed by [EXE].
For combinations
  • Press then [F3](PROB) then[F3][nCr][EXE]
For permutations
  • Press then [F3](PROB) then[F2][nPr][EXE]
Oct 01, 2010 | Casio FX-9750GPlus Calculator
How do you doo antilog on casio fx-115w?
For natural antilogarithm use e^x (shift ln). For common antilogarithm use 10^x (shift log). The ln and log keys are on the right side of the keyboard, just above the tan and cos keys.
Jun 25, 2010 | Casio FX-115W Plus Calculator
Which keys do i use to put in a logarithmic equation on a Casio fx-300MS?
For logarithms one uses one of two keys
  1. [LOG] for logarithms in base 10. It is in the same column as the F1 key, on 4th row
  2. [LN] for natural logarithms. It is in the same column as the F2 key, fourth row, to the right of the [LOG] key.
No, that is not right. This is for the FX-7400G (as specified in heading). Well too bad. The information is still valid, except for the location on the keypad. That should not be too difficult to find on the FX-300MS keypad.
Jul 25, 2009 | Casio FX-7400G Plus Calculator
41 people viewed this question
k24674
jasbo
jasbo
