Question about Hoover Washing Machines
Hi, i have ONHF 6117 Hoover washing machine which dropped out of my van while moving house the problem is there no motor action, i had someone look at it he changed the pcb module board, motor and pre
Everything else seems to be working, door locking, water valve, pump, just no motor action
  • 64 Answers
All washing machines have a switch that is activated when the lid or door is closed. This tells the machine its safe to run the motor. If this thing dropped out of a van, it's possible the housing twisted and the little metal bracket on the door is not making contact with the safety switch or the switch may now be broken.
Posted on Nov 25, 2014
Testimonial: "When i put it on to spin the door is locking the pump is working but no motor action"
  • Rob
    Rob Nov 25, 2014
    Ok,,, have you ever started the machine before and it fills with water and your soap while you're loading it with clothing? Yes, I'm sure,,, the motor will never start until the door is closed properly. It will not agitate the clothing until the door is closed. Again,, it goes back to what i stated before,,, a warped machine housing, broken switch, or the switch and "key" not lining up properly now. If its a front loader then this may be tested on "fluff or something like that. Use a screwdriver or something flat and a few inches long to enter the opening where the door "key" goes into to see if it works. Just do it safely of course. The motor is not supposed to turn on fer a very good reason!
Hi, i have ONHF 6117 Hoover washing machine which i dropped while moving house the problem is there no motor action, i had someone look at it he changed the pcb module board, motor and pressure switch
door switch comes to mind, how far was the drop ? does the lights or motor buzz ? did the power cord get pulled on ? check with a volt meter at were the power cord attaches to the unit. GOOD ? = then check every last plug in the unit, to make sure it is seated properly into it' respective socket.
Hope this gets ya running again. ask if you need more help, and don't forget to vote if i was of help
Nov 25, 2014 | Heating & Cooling
Hoover 1400 AAA washing machine tripping house fuse
Possible that the control panel is short and so is tripping the fuse. Remove the connection to the panel and check if there is short , also remove the motor and check and this can confirm the case.
Jul 03, 2012 | Hoover Washing Machines
Not working at all. my washer was on working and i heard a big bang and my electrics went off, i turned everything back on and the washer started up again but then stopped and now will not work. when...
The ticking that you hear is probably the timing motor for the dial.
Was the "bang" from outside the house? If so, then a transformer probably blew and hit your house with a power surge. Motor is likely damaged, and will need replacement.
If the bang was inside the house, the capacitor on the motor probably blew (unusual failure mode though), and will need to be replaced, motor is likely damaged as well.
Sep 18, 2010 | Hoover Washing Machines
I have a Hoover top load 610 and it wont start wash cycle
These are a great little machine,I dont know why they have to go changing things.Anyway this sounds to me like the timer.It fills & the water cuts off so the inlet valve is ok.It drains so the pump is ok.It spins so the motor should be ok.Try it on other cycles like gentle or delicate & see if it agitates.I'm sure it will be the Timer.
May 22, 2010 | Washing Machines
Hoover AL 120 washing machine won't spin
i would check the motor carbons it could be your problem if it fills goes through the programme until the end but has motor action
Apr 12, 2010 | Hoover AL120 Front Load Washer
Hoover error E08
hi I had this fault, google said it was tachometer fault. the e08 fault on my hoover optima was not the tachometer, i checked it, but the fix was very easy, the motor brushes were worn out and i changed them for 10 quid, I made a video of it its on youtube http://www.youtube.com/watch?v=xYn-f78GB4U and it shows you how to test the tacho and how to change the brushes, hope this helps someone
Oct 02, 2009 | Washing Machines
Hoover Elite 1205 washing machine
Does an Hoover elite 920 gearbox fit the hoover elite 1205 thanks
Sep 18, 2007 | Washing Machines
How to use hoover ac121
normally the numbers are the same for all uk machines, if the previous washer you used had numbers on it, just remember them and use them as you would, so if a number 2 was a 90 degree boil wash them it would be the same number for all uk machines, that is my experience, or older machines had letters example letter D = non fast coloureds
Aug 30, 2007 | Hoover Nextra HNWL 3136 Front Load Washer...
My Hoover Model Not listed/stops during the cycle
the cycle timer is beginning to sieze because it needs oil. disassemble washer to the point where you can apply small drops of 30W machine oil to the timer's bearings
May 20, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
46 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
