Question about Zyxel ZyAIR G-4100 Wireless Router (ZYAIRG4100)
ZyXEL n4100 : users do not want to ping each other. How?
ZyXEL n4100 : users do not want to ping each other. I want to isolate the local network . So can not access my server Cafe customers .
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 61 Answers
You need to get into the admin of the router and disable "Allow remote user to ping device"
Posted on Nov 25, 2014
  • salih mazlum
    salih mazlum Nov 25, 2014
    I tried it . Did not work ..
2 Suggested Answers
SOURCE: how to secure zyxel 600 wireless network
My nissan p 11 swithces off when in motion. plz asstst
Posted on Jun 06, 2009
Zyxel n4100Vinternet
YOU NEED A BETTER ISP DATA PLAN LIKE 3G,4G,DSL,ETC...
Mar 27, 2012 | Zyxel N4100 80211n Wireless HotSpot...
Tip
Why can Networked Devices not be used when a VPN connection is active?
With most VPNs, as soon as the VPN connection is established, it will take precedence over all other network connections. Access to the Internet (other than to keep the VPN connection itself alive) will go via the VPN and the corporate network you are connected to, rather than the local ISP. Furthermore, access to the local network is temporarily disabled.
As a result, your local print server may not be accessible,
you cannot use devices via the Network USB hub, or the USB ports on your router (if it has these), you may not even be able to access your local router's configuration page or ping the router or other machines in the local network.
This is done because of security reasons.
When a computer is connected to a corporate network via a VPN, the administrator needs to make sure that that machine can not act as a some form of a gateway enabling other machines in the local network to access that corporate network in any way. For that reason, the machine connecting via the VPN must temporarily be isolated from the local network.
on May 05, 2010 | Computers & Internet
I have by cannon 6570i moddel ihave continew error {chek the network conection chek the tcp ip the defalt key is curruptedor invelid}
1) Select the following service mode COPIER>TEST>NETWORK>PING, and select PING.
2) Enter the IP addressof your PC using the numeric keys on the control panel, and press OK.
3) Press the start key.
- OK is displayed if Ping succeeds, but NG is displayed if it ends in failure.
Perform this procedure only when connecting the machine to networks.
If the machine fails to be connected to networks, any of the following causes is probable.
a. Connection failure between networks and the machine
b. TCP/IP setting failure of the machine
c. User network failure
d. Main controller PCB failure
The detailed check methods are as follows.
Checking with Loopback Address
you can check whether TCP/IP settings of
the machine are appropriate by executing Ping with this address.
1) Enter the loopback address (127.0.0.1) in PING.
- If NG is displayed, check TCP/IP settings of the machine again, and re-execute Ping.
- If OK is displayed, perform the next check.
Checking with Local Host Address
The local host address is the IP address of the machine. Since the local host address returns in response to the network controller by executing Ping with the address, you can check whether the network controller (main controller PCB) is in a normal condition.
1) Enter the IP address of the machine in PING.
If NG is displayed, take the following actions, and re-execute Ping.
- IP address error of the machine: Check to see again if the IP address settings of the machine are appropriate. Ask the system administrator whether the allocated IP address is valid.
- Failure in the main controller PCB: Replace the main controller PCB
If OK is displayed, a cause may be user's network environment. Inform the system administrator of the current situation, and ask for measures.
Apr 16, 2011 | Canon imageRUNNER 5570 Copier
The 4 network connection are blinking al the time The connection led home is not on
The 4 Network connection are blinking means there is some traffic passing on those ports.
Please try to do some ping test between the 4 PCs which are connected to that switch.
If ping test is fine that means some problem with the LED Home but not with the entire box
Oct 28, 2010 | Zyxel PLA470 HOMEPLUG AV SWITCH WRLS4PORT...
Zyxel220 can't be reaced via webbrowser
Here few things that you could try:
1. Try to check if there is a proxy server configured in your web browser. Tools>>Internet Options>>Connections>>LAN settings..>>make sure nothing is checked.
2. Disable anti-virus and firewall temporarily and check if you can access it using your web browser.
3. Possible that the IP address of your zyxel has a conflict with another device in the network (i.e. router,switch, etc)
4. You could also use firefox as an alternate browser.
Hope this helps.
Oct 11, 2009 | Zyxel NSA-220 (NSA220) Network Storage...
I can't acces the Zyxel router web interface. Ping works. Can I try snmp?
Login into the router with 192.168.1.1
User Name: admin
Password: 1234
All the best!
Aug 10, 2009 | Computers & Internet
I have zyxel zywal 35 have two wan port, wan1 connected to t1 line, wan2 connected broadband line , now the firewall configured on active/ passive mode,it was working fine but some times. fire wall lan ip...
This is due to some bad packets on your network. Check the network for any worms/spywares. Also check if the ethernet connections/card donot malfunction.
Jun 19, 2009 | Zyxel ZYWALL 35 Firewall
After configuring network TCP/IP automatic Dns server automatic or preferred and alternate dns as given by isp, setting router to mode router encaps..pppoa (second trial RFC1483) multiplex..llc virtual...
ftp://ftp.zyxel.com/
this the web site download the user manual from this site what ur configuration go thought it i think you get it and maybe the problem in the pppoa line its working or not just check it
Apr 02, 2009 | Zyxel Prestige 660HW Wireless Router...
What is the difference between the internal IP and the real IP from my ISP?
Internal IPs are sometimes referred to as virtual IPs. They are a group of up to 255 IPs that are used and recognized internally on the local area network. They are not intended to be recognized on the Internet. The real IP from ISP, instead, can be recognized or pinged by another real IP. The Prestige 310 Internet Access Sharing Router works like an intelligent router that routes between the virtual IP and the real IP.
Feb 19, 2006 | Zyxel Prestige 310 (AM406100) Router
How can I manage the Prestige 310 ?
# Menu driven user interface for easy network management Local and remote console management # Windows configurator Telnet remote management # TFTP (Trivial File Transfer Protocol) firmware upgrade and configuration backup and restore
Zyxel ZyAIR G-4100 Wireless Router (ZYAIRG4100) Logo
97 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
