Question about Honeywell HCM-315T Humidifier Replacement Wick Humidifier Filter HC-
How to fix my honeywell hcm-315t humidifier - Honeywell HCM-315T Humidifier Replacement Wick Humidifier Filter HC-
    Problem Solver:
  • 16 Answers
What is wrong with it?
Posted on Nov 25, 2014
Humidifier does not turn on
if your saying that the voltage drops to around 4 volts at the supply transformer at anytime , then id say the load (device connected) is too much for the transformer to supply this most likely is caused by an internal fault in the load (humidifier) also since its a water appliance id say a water leak might be a factor in that as well , taking a look under the cover of the humidifier 4 signs of a water leak (or past one) would be where id start
Nov 11, 2015 | Aprilaire Model 700 Automatic Whole-house...
Why dose drum spin when furnace is not on?
Usually the unit is mounted to the cold air return (cold or intake air) and the round hose is then attached to the plenum (hot or discharge air). The humidistat is usually mounted just above the unit onto the meta plenum, unless you have a control somewhere else or your main t/stat has that capability built in. Its usually wired in with the furnace 24Vac control (or whatever yours happens to be) so that the unit only comes only when the furnace is on.
Dec 08, 2014 | Honeywell HE120A Whole House Humidifier
Water does not fill in the Aprilaire humidifier on my furnance
It sounds like the feed has been shut off or pluged. Be sure the feed is off, remove the feed from the humidifier. open the fill valve slowly and run water into a bucket or whatever. If it does not run you found the problem, if it does then it is probably the fill solenoid valve on the humidifier.
Mar 21, 2014 | Edison 40 Pint Dehumidifier
On the HUT200 model. Does not produce the mist
I have read elsewhere on this site that overheating of compressor may be low gas level, but does that mean there is a leak? I have had the machine about 3 years, used over 1000 hours.
Dec 15, 2013 | Kaz Inc Honeywell HUT200 Easy-Care Cool...
Water is no longer collecting in bucket, but appears to leak out of humidifier. Humidifier also ices up.
Basically there is a drainage blockage from the humidifier to the bucket. Take one for the boys and **** hard on the pipe which very possibly will release the blockage.
May 23, 2010 | Kenmore 54351 Dehumidifier
543515 humidifier runs but doesn't collect any water.
try checking the setting of your humidifier, if the actual humidity level matches, what is set on your unit.
Aug 01, 2009 | Kenmore 54351 Dehumidifier
Humidifier does nto turn on.
It sounds like the Dehumidifier has a problem somewhere on the circuit board. You could try and find a local humidifier repair shop in your area otherwise it may be cheaper to purchase a new replacement instead of having it fixed. Good luck.
Tech - 101
Jun 23, 2008 | Whirlpool AD40USR Dehumidifier
Adjusting dehumidifier on furnace
This model furnace does not come with a built in humidifier. Humidifiers are normally an optional add on. If you have a by-pass type humidifier it is none adjustable. Water level is normally float controlled and operation is control by blower circuit. When ever the blower runs the humidifier operates when in the heating mode.
Jan 24, 2008 | Dehumidifiers
Maytag M7DH45B2A freezing problem
Is this a humidifier or dehumidifier?
Nov 15, 2007 | Maytag M7DH45B2A Dehumidifier
Honeywell HCM-315T Humidifier Replacement Wick Humidifier Filter HC- Logo
130 people viewed this question
Top Honeywell Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Honeywell Dehumidifier Expert? Answer questions, earn points and help others
