Question about Alcatel Alpha Novus 2000 Xti Ups - Part 017-156-26 - Lucent Comcode 408646297
How do I get "menu" on Alcaltel 2000x
Pressing various keys, reading instructions,accessing the menu does not seem to be mentioned
    New Friend:
  • 151 Answers
There is no "MENU", there is a "SETTINGS". Use that I think. Remember these are Chinese, they dont eat at menus. Luck !
Posted on Nov 25, 2014
How can I open the service menu?
Press the helpful button and check link below for various models
First power off your TV using the remote, then press following buttons quickly on your TV remote:
Display (or i+) + 5 + Volume Up + Power
It'll show the hidden service menu on your TV screen.
Once you enter into service menu, you can press Menu (or Options) button again on your remote to switch between various service modes such as Digital, Chassis and VPC.
To navigate between available options press 1 or 4 buttons. To change or modify their values press 3 or 6 buttons.
To save your changes, just press Mute + 0 (or Enter) buttons on the remote.
To restore settings to factory defaults, press 8 + 0 (or Enter) buttons.
PS: For some new models the above mentioned method might not work. You can try following key sequence to access service menu in those new models:
While TV is on, press Left + Right + Mute + Center button + Mute + Menu buttons.
Hidden Secret Service Menu Codes for Sony Samsung LG and Philips TV
TV Service Menus Hidden features you didn know about
Jan 31, 2016 | Televison & Video
I am trying to tune an old phillips 14PT1342/20 tv. I have lost the original remote and have tried various other remotes all to no avail. I have purchased a replacement remote but still I cannot access the...
please read carefully the instruction manual for to access to the menu. However you can try to go to R.Schack and get the support.
God bless you
Oct 14, 2013 | Televison & Video
How do I enable a compaq laptop's keys
Compaq Presario computers provide users with a row of function keys for added keyboard functionality. Function keys can serve a dual purpose as well.
Function keys are located at the top of Compaq Presario keyboards.
By learning how function keys work on a Compaq Presario you can take advantage of time saving keyboard shortcuts.Purpose
Use function keys to access menus, save changes and create shortcut keys.
Various applications, including Microsoft Office, allow you to select a function key as a shortcut key for running specific tasks. These settings are usually found under the Tools, Settings or File menu.
Each Compaq Presario computer has twelve function keys.
The most common used keys are "F2," "F8," "F10" and "F12."
The first three are used mainly to access and use the Compaq BIOS. "F12" is used to access a set of run from options during the boot process.
How to Access
Access function keys on a Compaq Presario by pressing any of the keys on the top row of the keyboard. Access the key's dual purpose by first pressing the "Fn" key located on the bottom row of keys.
Use function keys as shortcut keys by pressing them anytime while in the desired application. Remember, you must set them as shortcut keys first.
Note that some programs may already have certain function keys set as shortcuts.
Open menus and view the shortcut keys beside each menu item before setting your own shortcuts.
Dual Uses Each function key has a dual use. Press "Fn" plus the desired function key for the key's other use.
Below each function number is a small picture within a square or rectangle.
This dictates the dual use. "F1" opens help and support. "F2" serves as a printer shortcut.
Open your homepage by pressing "F3."
If you use dual monitors, switch between monitors by using "F4." "F5" puts your computer in stand-by mode.
Quickly lock your computer by pressing "F6." "F7" and "F8" adjust the screen's contrast.
Play and pause your music in Windows Media Player or other default media player by using "F9."
Press "F10" to stop playing media. Skip ahead or rewind media by using "F11" and "F12."
Other "Fn" Keys
In addition to function keys, the "Fn" key is also provides other keys with a dual use.
Any key with a small square on the key has a dual purpose such as the "scroll," "insert" and "delete" buttons.
Since laptop keyboards have no number pads, certain keys serve as the number pad by pressing the "Fn" key.
Jan 08, 2012 | Compaq Computers & Internet
How disable my bios memory dump and bluescreen thans you
These controls are located in a part of the system called "BIOS Settings", "BIOS Menu", "CMOS settings", "CMOS setup" or some similar variation. This should be covered in your user manual.
You usually enter "BIOS Settings" menu by pressing a specific key or keys during the beginning of the boot-up process. The specific key(s) to press are usually mentioned in a corner of the display as the system boots. They should also be in the manual. It is sometimes the "F2" key, or "Del", or a combination like "Ctrl+S" keys.
Once you've entered the menu, you'll see it provides many parameter settings organized in "pages". Basically, walk through the on-screen prompts until you see the settings having to do with cacheing and shadowing.
Every system and even current BIOS version has a different way to present these data, so we generally can't give you a specific keystroke-by-keystroke set of instructions. Again, your user manual should detail this information.
If you don't have a current user-manual, you should be able to go to the motherboard or system manufacturer's website to download a copy. It will usually be in .pdf format which will (in order to be able to read it) require a free .pdf reading application like Adobe Reader or Foxit.
Mar 31, 2010 | Computers & Internet
How do I retune DMTech TV Freeview with DVD video please?
Please fallow bellows instruction to retune your TV.
Could you please follow that EEPROM RESET INSTRUCTION OR FIRST TME INSTALLATION.
Also please don’t forget that MENU BUTTON from your remote, it’s not the one in the middle of remote.
There are the other MENU BUTTON in left down bottom side.
Cannot access Digital TV and am asked for a Lock code Key?
If you cannot access the Digital TV option then conduct an EEPROM RESET as mentioned above. If you are prompted to enter a lock code key enter three / four zeros.
Alternatively when prompted to enter the lock code key conduct a FIRST TIME INSTALLATION also mentioned above.
There are two options available. The first option is to conduct a general reset that will reset all user preferences. The second option would be to conduct an EEPROM RESET. An EEPROM RESET would reset all the internal hardware.
Instructions - Please refer to your DMTECH remote control and user manual provided
1. Turn the Television ON ? Button on front of Television / Power button on remote control.
2. Make sure that you are on Analogue television by pressing the TV/DVB-T button until you see PR and the channel number selected in the top right corner of the screen, e.g. PR 1.
3. You must then Press the button labelled Display until a window titled INFORMATION is displayed on the screen.
4. Only when the window titled Information is present can you continue by pressing the digit (1) twice and then pressing the button titled LINE. If you make a mistake then press Display again to remove the window titled INFORMATION and repeat the process. (Display - 1 1 - Line)
5. Once you have successfully completed step four you will notice that a menu appears on the left of the screen. You can then select which option you want, either RESET or an EEPROM RESET using the arrow keys. To execute an instruction please use the RIGHT ARROW KEY and not the ENTER button.
Make sure you have properly conducted a FIRST TIME INSTALLATION and an AUTOMATIC SEARCH. If having done this you can try conducting a manual search in an attempt to force / lock the channel.
This will erase the DVBT tuner memory and reset the interface card. This may resolve poor channel reception, the inability to store channels or even receive certain channels.
1. Turn the Television ON and select digital television by pressing the button labelled TV / DVB-T located under the power button on the remote control.
2. On the remote control locate and press the button labelled Menu, found at the extreme bottom left of the remote control.
3. A Menu should now appear displaying options. Scroll down and select the option labelled SETTINGS using the ARROW KEYS and the enter key located in the middle of the remote control. On the next menu you must select INSTALLATION to move on to the next menu.
4. On this last menu scroll down to the last option labelled FIRST TIME INSTALLATION and select it pressing the enter key. You will then be prompted to delete all channels, using the left arrow key to select yes and press enter to execute. The television will reset and prompt you to commence an AUTO SEARCH. Follow these instructions to tune in channels.picture
Digital Television requires much more from existing aerial systems. Having more than one digital TV may reduce signal quality and strength depending on how the aerial system is set up. It is therefore recommended that if you decide to use more than one digital television you use a booster and or at least make sure you are using a digital ready aerial. Using an existing Aerial that is split may reduce signal strength depending on how many times it is split. Please see the diagram below. The best solution when using an existing aerial is to purchase a booster device. Aerial Splitting - Why a booster is recommended. A booster is used to apply a small current that boosts the existing signal. A booster can be purchased from all main TV/HI-FI - consumer electronic product retailers.
Jan 16, 2010 | Televison & Video
Unlock boot without key
No such thing as a universal key. I would remove the rear seat and crawl through to release the trunk latch.
May 01, 2017 | 1998 Mercedes-Benz C-Class
How do you save mia's science game when you want to quit?
Q: How can we save our progress in the game?
A: You can access the save menu by pressing the F3key on your keyboard. In the save menu screen, all you need to do is click in one of the available game slots. The next time you play, the introduction menu will be changed and you will be able to load back your saved game(s).
Macintosh Specific
Q: We do not seem to be able to use the F1, F2, F3 keys mentionned in the instructions. What is the problem?
A:
If you have a MacBook or a slim Apple keyboard, you need to hold down the fn key on your keyboard in order to use the F1 through F15 keys. Alternatively, you can use the q, w, and e keys in place of F1, F2, and F3.
Dec 28, 2008 | Kutoka Interactive Mia's Science...
I WANT TO FIX A PCI VGA CARD IN MY SYSTEM P5GD2-TMX/SUSING JUMBER
Hi again. As I mentioned in my other note to you, when installing a video card in a PCIe slot, you will need to tell the system (via Setup) which video to use. It will be somewhere in the various screens of BIOS settings for the motherboard. ASUS isn't really supporting this motherboard any longer, so the documentation I'd need to give you specific instructions is no longer available. Still, it is there in Setup (accessed at boot, by pressing the key prompted on your very first screen), you just need to look for it.
Once you've told the system which video to use, boot into Windows, and install the video drivers that came with the card.
Cheers
Nov 13, 2008 | ASUS P5GD2 Deluxe Motherboard
Alcatel Alpha Novus 2000 Xti Ups - Part 017-156-26 - Lucent Comcode 408646297 Logo
Top Alcatel Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
