Question about Plumbing
SPRAYER HEAD A11218 1M 2.2 GPM NEED TO FIND REPLACEMENT FOR THIS ITEM.
THE SPRAYER HEAD HAS ONLY THE ABOVE MARKINGS THAT I CAN MAKE OUT. SILVER SINGLE HANDLE WITH RETRACTABLE SPRAY HEAD.
  • 28 Answers
The A11218-1 is merely a plumbing standards number. Look further to try and find a manufacturer name or model. Or take it into a local professional plumbing supply store.
Posted on Nov 25, 2014
Replacing Sprayer on Kitchen Sink?
Should be able to purchase sprayer head only at any store that sells taps and hardware to go with them. I got a replacement at a plumbing store in Chatham Ontario.
Feb 09, 2015 | Moen 7310 Legend Single-Handle Kitchen...
TRYING TO FIND REPLACEMENT SPRAYER HEAD A11218 1M 2.2 GPM IS ALL I CAN MAKE OUT
What is the manufacturer of the sprayer. The part you describe is the aerator that screws in. If you are looking for an aerator, any hardware store will have a replacement.
Nov 25, 2014 | Plumbing
Just installed a Jado Basil Single-Handle Pull-Down Sprayer Kitchen Faucet and the water flow is incredibly slow! Removed the check valve from the sprayer and it didn't help. Any other suggestions? Flow is...
The specs say that there are two check valves but the diagram does not show them. Take the weight off the hose and see if it is causing the restriction. If it is not, what is the water pressure in the house? The 2.2 GPM is the maximum flow rate.
Aug 25, 2013 | Jado 803800355 Basil Single-Handle...
Hansgrohe Solaris faucet will not return from spray to stream. The shuttle stays in the spray position
I would try cleaning the sprayer with CLR to break up and remove any deposits. If cleaning does not reolve you may need a new sprayer. The part number for the sprayer is 14893801 in steel optic. It is available through your local dealer or online dealer. Feel free to call me at Hansgrohe 1-800-334-0455. Press #2 for tech. Ask for David.
May 11, 2012 | Hansgrohe 06649860 Solaris Single Hole...
Leaking blanco single handle faucet with sprayer
minarl deposit bildup in the handol best to just replace the sprayer any hardwer store hose is still good only sprayer head needs replaced comen threds
Mar 11, 2012 | Blanco Plumbing
Replaced delta valve with moem. when water to toub is turned on at high pressure water comes out of the shower head. Valve is installed correctly. Took cartridge out of valve and blew back through shower...
The pipe going from the main valve to the tub spout(not the sprayer above)needs to be a full 1/2" pipe if you used a pex 1/2" to the tub spout-the inside is usually smaller and causes it to back pressure and make water release thru the sprayer above-needs to be installed with a full 1/2" ID PIPE-AND DONT USE GALVANIZED
Sep 29, 2017 | Moen Posi-Temp Single HandleTub And Shower...
Looking to replace triger (leaks)
NorthStar brand equipment comes from Northern Tool. You can't replace the trigger, but they sell the replacement spray wand here and it's only $11.99. There are other wands, some longer, etc. They are pretty universal -- you just slide them onto the hose and tighten the band clamp. Good luck! If this is helpful, please rate my answer, thanks!
Jun 02, 2010 | Northstar ATV Tree Sprayer 16 Gallon, 1...
How do I change the gun filter on Campbell hausfeld airless sprayer?
Assuming it is detached from hose, I would first unscrew the skinny end of the filter housing that goes into the gun at the gun handle. That's cause it looks fragile and allows easier access to the wrench positions where you break down the hex fitting from the filter housing. After unscrewing the hex fitting the filter cartridge should pull out easily for cleaning or replacement.
Apr 26, 2010 | Campbell Hausfeld Airless Spray Guns &...
Not much pressure on fimco 15 gallon sprayer - purchased new 2.1 gpm motor - it sprays but not a lot comes out - seems not much pressure - Thanks.
Is it possible that the pick-up tube inside the sprayer is clogged up, or the hose it damaged? Maybe dirt in the spray handle/wand?
Oct 26, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Fimco Sprayer , 25 gallon, 2.1 gpm, 12 Volts - Blowing fuses
Soiunds like you either have one of two things. Either the pump motor is bad or you have a wire that is shorted out. look for chaffed or bare wires or burnt spots on the sprayer and the machine towing it. one of the two is your issue. Hope this helps!
Sep 19, 2008 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Plumbing Logo
185 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
