Question about Drills
The instruction manual says to insert a drill bit all the way but small drill bits, such as my 3mm masonry bit are to short to do that and still function. Then when I use the hammer drill function, t
The instruction manual says to insert a drill bit all the way but small drill bits, such as my 3mm masonry bit are to short to do that and still function. Then when I use the hammer drill function, the bit gets pressed back into the drill. Is there a way to remedy this?
  • 74 Answers
If you are drilling in masonry with a masonry bit you don't need to have the hammer function on
Just put it on reg drill and just apply a little pressure you will start to see dust come up when you have applied the correct amount.
Have a Great Day.
Posted on Nov 25, 2014
danny_murray
  • 55 Answers
SOURCE: keyless chuck will not tighten down enough to hold bit
What size bit are you using if it is real small it may be below the min sixe require for that chuck .If it is say 1/8 or larger it may be time for a new chuck .They are easy to replace open the chuck as far as you can there is a screw inside them most of them are left hand threads just back it out and tap the chuck loose with a hammer .Make sure you know the threads of your chuck when you buy the new one most are 1/2-20 but some can be 3/8-24 tpi
Posted on Dec 05, 2008
muttandjeff
  • 359 Answers
SOURCE: drill bit came out, won't go back in. Dewalt 12v XRP
grasp the chuck and put drill in reverse position and pull trigger gently this will open chuck and re-insert bit do same in forward to tighten bit into chuck
Posted on Jan 11, 2009
  • 6 Answers
SOURCE: Black and Decker KD950K drill - how to insert drill bit
most keyless chucks have a button on top that you push in near the chuck it locks so you can tighten or undo
Posted on May 27, 2009
  • 142 Answers
SOURCE: locked drill chuck
i have the same tool and have had the same problem
i use 2 large prs of channel locks(water pump pliers) to break the bond
Posted on Jul 06, 2009
SOURCE: Bit or chuck type for a Skil 717 hammer drill
I have a Skill 717, too. It has a hex shank. Here are a couple places that I've located that carry (some) parts:
www.icscuttingtools.com (pages 155 & 157)
www.bamanufacturing.com/page_15.htm
also try:
www.ereplacementparts.com
www.toolpartsdirect.com
Posted on Mar 09, 2010
Can you recommend the best site that offers reliable drilling tools at reasonable rates?
As there are a number of sites that offer drilling tools, it becomes difficult to choose the best one for you. I also wanted to boy one drill bit tool to be drilled into the concrete. I was wondering which drill bit would be most appropriate for this purpose. One of my friends recommended me to use masonry bits as they are suitable to be drilled into the concrete smoothly. You also need to find the right tool based on the material to be drilled on! Check the latest drill bit tools at Best Masonry Drill Bits.
Apr 16, 2018 | Best Computers & Internet
I want to buy a masonry bit. Can you recommend the best place for its purchase?
Masonry bits are used to drill through bricks or concrete. These bits are also used to drill through stones. Several sites are there which you can prefer to have a masonry bit. I was also searching for the appropriate place for its purchase some months back. Choose the site for the purchase of Best Masonry Drill Bits carefully.
Apr 16, 2018 | Drills
I purchased a Black & Decker DR260B drill to drill masonry but there's no info in manual about brick. Can I use this drill to drill holes in brick mortar?
This corded drill has enough power to drill normal brick masonry without issue as long as you're using a masonry bit.
http://www.homedepot.com/b/Tools-Hardware-Power-Tool-Accessories-Drill-Bits-Masonry-Percussion/N-5yc1vZc23f
Nov 07, 2014 | Drills
What speed would i need to set my cordless drill at to put hole in wall
Your drill will drill a hole at any speed, the drill bit needs to be sharp to drill the mateirial.The type of wall material is important.Drywall is soft but a masonry bit should be used.A masonry bit has a flat bar accross the point and slower speeds are best.Wood walls / studs you need wood bits that are sharper and medium to high speeds are used.Concrete or Block walls again require Masonry bits.If very hard concrete as in foundation walls or filled block the use of a Hammer drill will work much faster.Good Luck
Jul 29, 2011 | Drills
I bought a GSB 10 RE Kit. I am not able to differentiate between wooden drill bit, metal drill bit and concrete drill bit. Please help
that is easy, drill bits have different angle on the starting end, often have little protruding screw and you can have virtually any possible type in existence pictures in this link:
http://www.google.com.au/images?q=wood+drill+bits&oe=utf-8&rls=org.mozilla:en-GB:official&client=firefox-a&um=1&ie=UTF-8&source=univ&ei=PNRTTMLtHYHZcY6_rMAM&sa=X&oi=image_result_group&ct=title&resnum=4&ved=0CEUQsAQwAw&biw=1280&bih=831
and in short explanation here:
http://www.diydata.com/tool/drillbits/drillbits.php
your metal bits are available here:
http://www.google.com.au/images?um=1&hl=en&client=firefox-a&rls=org.mozilla%3Aen-GB%3Aofficial&biw=1280&bih=831&tbs=isch%3A1&sa=1&q=metal+drill+bits&btnG=Search&aq=f&aqi=&aql=&oq=&gs_rfai=
and in bit more info here:
http://www.thesitebox.com/Category/4141/metal-drill-bits.aspx
masonry bits in pix:
http://www.google.com.au/images?um=1&hl=en&client=firefox-a&rls=org.mozilla%3Aen-GB%3Aofficial&biw=1280&bih=831&tbs=isch%3A1&sa=1&q=masonry+drill+bits&aq=f&aqi=g1&aql=&oq=&gs_rfai=
in bosh catalogue you have this picture:
http://www.bosch-do-it.com.au/bosch-do-it.com.au/diy/diyknowledge/tipsandtricks/7891/tipsandtricks.shtml
from left: wood, metal, masonry
welcome to my world :-) i hope you like your advice, if you find it helpful, please leave feedback for me, thanx!
Jul 31, 2010 | Bosch Drills
How do I bolt down Sentry Safe S3310 to the floor?
All of the instructions can also be found at www.SentrySafeShop.com
The link is:
http://www.sentrysafeshop.com//kb_results.asp?ID=7
Required Tools:
Drill, Wrench, 7/16" (11.0mm) bit, for wood anchoring: 9/32" (7.20mm) bit, for masonry
anchoring: 3/8" (9.5Omm) masonry drill bit.
The steps are as follows:
1. Tip the safe on its right side. (Door hinges horizontal with the floor)
2. Unlock the safe and open the door.
3. Look on the bottom (outside) of the safe for two indentations in opposite corners. Using a
7/16" (11.0mm) bit, drill a hole through each indentation perpendicular to the bottom of the
safe.
4. Close the door and tip the safe upright. Place it where desired and reopen the door.
5. Use a screw or drill bit to mark the floor through both holes.
6. Move the safe aside to clear both marked spots for drilling.
7. Drill into the floor:
a. For wood:
i. Using a 9/32" (7.2mm) bit drill a hole 2 Y2" (64mm) deep in each marked
spot.
b. For masonry:
i. Using a 3/8" (9.50 mm) bit drill a hole 2 Y2" (64mm) deep in each marked
spot.
ii. Install a masonry anchor in each hole.
8. Replace the safe in the desired position, with the holes in the safe aligned with those in
the floor.
9. Securing the safe:
a. For wood:
i. Pass each lag screw through a washer, then through the safe and into a hole. .
ii. Tighten with a wrench. ,
b. For masonry:
masonry anchor.
Jun 27, 2010 | Sentry FIRE-SAFE Combination Safe DS3431,...
Anchor won't fit in suggested drill size
If you are not using a masonry bit then you need to increase th size to 1/4 ".
The reason why is with masonry bits it will say 3/16 but you are actually making a hole 1/4" with the tip of the bit.
Good luck and please rate 4 thumbs for the free answer
Mar 06, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Drill hole in China Plate
Normally you would use a masonry bit to drill into ceramics eg tiles or bricks. if the plate is glazed it is better to stick some masking tape or adhesive backed paper on the area to be drilled to stop the drill bit slipping around. also i would be inclined to use a hand turned drill or a small battery powered drill if you have one to avoid breakage of the plate.
Oct 13, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drills Logo
130 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
