Question about Waring WMK300 Pro Belgian Waffle Maker
Fix the thermal fuse - Waring WMK300 Pro Belgian Waffle Maker
    Sergeant:
  • 391 Answers
Teresa:
It's a thermal fuse, (in this case it's a thermistor) and like any other fuse that has blown, it needs to be replaced. (The thermistor doesn't cost much... a few dollars at the most.) To replace the thermistor, the bottom of the waffle iron will have to be removed, and the thermistor de-soldered from the wiring (make sure that you note which way the thermistor connects to the wiring... you don't want to solder the new thermistor backwards!). Take the thermistor to an electronics shop and buy another identical thermistor. Solder the new thermistor to the wiring the same way the old thermistor came out. Reassemble the waffle iron, and don't leave the waffle iron on when you're not making waffles!
Posted on Nov 25, 2014
Fix rowenta dg5030
Send it in for repair.
Google Rowenta Repair Center
Jul 22, 2014 | Rowenta DG5030 Iron
MY BLACK & DECKER D2030 DOES NOT POWER ON?
my black nd decker iron lights up but will not heat.
Jan 01, 2013 | Black & Decker D2030 Iron
Change the thermal fuse inside iron that's why not getting hot. thermal fuse blown up due to overheat inside
An iron should be calibrated to 410 degrees on wool setting to get the other settings to work correctly.
Dec 26, 2012 | Irons
My iron just stopped heating What can I do
You need to check the following for circuit contintinuity:-
The plug and wall socket
The leads, both the live and the neutral
The temperature selector (Thermostat)
The thermal fuses
The element
To do this testing you will have to strip the iron and get to the wire ends, the thermal fuses and the element terminals. (My guess is that it is the thermal fuses. They are little metal tubes wires attached and are usually insulated in white fibre glass tubing and attached to the element plate).
Feb 21, 2011 | Black & Decker Steam Xpress AS250 Iron...
I GET NO HEAT IT JUST STOPPED
U got a busted thermal fuse or the thermostat switch is not functioning.
If u have a knowhow in replacing and adjusting the thermal switch, u could fix it by urself!
Better check also the power cord, mostly flat irons main prob, if there are no lights on ur iron, it means internal probs!
Better take that iron in ur friendly hungry technician to fix that!
Dec 02, 2010 | Rowenta Professional DE880 Iron
Is there a thermal fuse in a RUSK STR8 flat iron (problem: no heat ,but LED lights ) THANKS !
yes there is a thermal fuse in series with the heating element inside the unit
Mar 19, 2010 | Irons
Same Issues with my Black/Decker 2030
change the thermal fuse inside iron that's why not getting hot. thermal fuse blown up due to overheat inside.
Aug 19, 2009 | Black & Decker D2030 Iron
Shark euro pro x
We fixed ours today. Take the iron plate off (bottom of the iron shaped like a triangle). You are looking for a thermal fuse (or thermal-protector fuse) pictured here for less than $2 at Radio Shack(http://www.radioshack.com/product/index.jsp?productId=2102788&CAWELAID=107599331). You will need needlenose pliers to gently remove the old fuse and the wire cutters to trim the long wires to the same length as the old fuse (less than 1/2"). Also, since the old fuse was 240 C and we only could find a 228 C replacement - we cannot use the iron at the same high temp. So we limited the dial by marking out a portion of the dial. The iron stopped working after I kept the iron on high for an extended period of time. My electrician husband explained that I over heated the iron - breaking the fuse. Not time I'll turn the iron off or down when I'm not using it. This was so easy, I'm going to check out our other broken irons.
Jul 05, 2008 | Euro-Pro Shark GI490 Iron
Red indicator doesn't turned on
where is the thermal fuse for this iron? mine has the same problem, I don't know what to look for.
Jan 04, 2008 | Panasonic NI-H10NS Iron
Waring WMK300 Pro Belgian Waffle Maker Logo
136 people viewed this question
Top Waring Irons Experts
Are you a Waring Iron Expert? Answer questions, earn points and help others
